Turbosmart MegaSonic BOV including HKS SSQV adaptor
sparkystav
Selling this LOUD BOV
Comes with the standard 38mm adpator and a HKS SSQV adaptor i bought separately.
That means you can undo the circlip on your SSQV and fit this straight in its place, no messing or welding.
More info from Turbosmart here:
The loudest BOV in the Turbosmart range
If extreme performance and spectacular sound are priorities - the Megasonic is the BOV for you
Aimed at the serious racer, its also ideally suited for show cars that want to stand out from the crowd
Tech Tip
To adjust the Turbosmart BOV, rotate the cap in the SOFT direction up to, but not beyond, the indicator groove. With the engine at idle, the exhaust port should be closed off by the piston. Free rev the engine and back off quickly. The engine should return to normal idle speed - if the revs drop below idle or engine stalls, increase the spring tension by half a turn. Repeat until the engine free revs and returns to normal idle speed. Test drive the car. If the engine backfires or stalls upon deceleration or gear changes, check all BOV connection, prior to increasing the the spring tension again.
Couple of pics:
Looking for £150 plus postage
thanks for looking
