gear box oil
mikerunner
hi all, i am having trouble finding gearbox oil for my 6 speed tt.
i have checked prevous threads which reccormend the following
Manual 6-speed V160/161 Gearbox
Stock = Toyota V160 oil (PART No. 08885-01306)
Capacity 1.8l's when dry
Toyota V160 Oil (comes in 1L cans - require 2 cans)
Alternative:
Esso Dextron D21065 - R34 Skyline has same box and uses this, however this too is in short supply
BMW oil called MTF-LT-1 or LT-2 - Feedback required from testers
Castrol Transmax Z - Feedback required from testers
Royal Purple SynchroMax - Feedback required from testers
Mobil ATF 220 - Feedback required from testers
I recommend you stick with stock but in recent times this has been hard to get hold of, so it's the Esso now...
Interval = 2 Years / 30,000miles depending on use/power levels
but i can not find any of these oils.
can someone suggest where i should go to buy and which one i can get.
thanks
whifbitz has some stock left I think...
Thats where i got mine from :)
But its expensive as hell
Not really IMO when you consider the mileage to £'s
No one seems to moan about the £50 per x,000 miles for an oil and filter but £80 for 2l's of gearbox oil that will last over 20K miles gets a few moans.........(mind you I was the same until I sat down and though about this and that the gearbox is at least - possibly more - as important to look after as the engine). It might be a rip off/unnecessary expense but at the worst it's £50 'wasted' over alternatives.
