Ian C 13 Posted April 3, 2005 Share Posted April 3, 2005 Name: BOV Also known as: Blow Off Valve Dump Valve What is it? When you take your foot off the accelerator to change gear or whatever there is suddenly a lot of pressurised air from the turbos that has nowhere to go as the throttle plate is shut. A BOV is a valve that is triggered by the pressure difference in the manifold and gets rid of this excess air. If this didn't happen it would cause the turbos to suddenly stop spinning, which would not only knacker them in short order but mean they had to spin up from a standstill when you got back on the throttle again. There are two types of BOV, one vents the air to the atmosphere (atmospheric) and the other vents it back into the air intake (recirculating). The standard BOV is a recirculating job and is generally regarded to work fine up to around 18psi of boost. After this or when they get a bit old, they have been known to leak. The main reason for changing to an aftermarket one is to make a nice loud whoosh when you back off the throttle as nearly all of them are the atmospheric type. Sometimes it’s out of necessity, such as with a single turbo conversion which removes all the stock BOV plumbing. You can mount them in the same place as the stock one (kits are available to do this for most BOVs), or have a flange welded to a hard pipe somewhere (typically the one that goes into the throttle body, but anywhere between turbo and throttle body is OK). You can also keep the stock one and add an aftermarket one as well. Pros: Makes a cool whoosh noise when you back off the throttle . A well made one can hold more boost than the standard one without leaking. In theory recirculating the hot pre-intercooled air back into the intake like the standard BOV could heat up the intake air whereas venting it does not but this is very unlikely to make any difference in practice. Looks 'bling' under the bonnet. A necessity with a single turbo conversion due to removing all the stock plumbing. Cons: If you have a UK car, an atmospheric BOV can confuse the ECU because they use a MAF airflow sensor which is ahead of the BOV. This sensor registers that a certain amount of air is flowing in, so the ECU reacts accordingly by supplying the correct amount of fuel. That air then gets vented by the BOV, so the engine runs very rich. This creates two problems – one, the car may stall if the throttle doesn’t come back on, two, if the throttle does come back on the ECU is trying to compensate for an over-richness and may lean the mix off to undesirable levels, potentially causing detonation. The j spec cars have a manifold pressure sensor and don't suffer from this problem. -Simon B Quote Link to post Share on other sites
MarkTheBoy 0 Posted June 14, 2006 Share Posted June 14, 2006 Hi all, Just wondered if there is a guide available for fitting an aftermarket bov. I have just bought one from importpimp (nic) and am pretty sure that I could fit it but wanted to have some kind of instructions with pictures to make sure I don't cock it up Any help would be appreciated, I've done a search but not really found anything helpful and the instructions that came with it are japanese... Theres nothing else I need to do when fitting one is there regarding setup of the engine, turbos etc? I assume its just a straight swap.... Ish Cheers all Quote Link to post Share on other sites
Daston 20 Posted June 15, 2006 Share Posted June 15, 2006 Yeah would be usful as well as how to fit them on IC pipes for us lot who are going NA-T Quote Link to post Share on other sites
supra sam 0 Posted June 16, 2006 Share Posted June 16, 2006 Hi all, Just wondered if there is a guide available for fitting an aftermarket bov. I have just bought one from importpimp (nic) and am pretty sure that I could fit it but wanted to have some kind of instructions with pictures to make sure I don't cock it up Any help would be appreciated, I've done a search but not really found anything helpful and the instructions that came with it are japanese... Theres nothing else I need to do when fitting one is there regarding setup of the engine, turbos etc? I assume its just a straight swap.... Ish Cheers all Iv had the hks bov for about a year now, it should be very simple to fit only took me about 25 mins, the instructions are in japanese but if you take a good look at the pictures then you should be able to work out what you need to do. I am assuming you have the specific valve with fitting kit for the supra? if so everything you need is in with the kit, it goes in where the existing valve is, you wont need to do anything with the engine setup or turbos. some people have these welded onto the IC intake piping i am not sure what the pros/cons of doing this are? I can post a picture of mine fitted if it helpes. Quote Link to post Share on other sites
Daston 20 Posted June 16, 2006 Share Posted June 16, 2006 I have to put mine on the IC pipes its an NA-T Quote Link to post Share on other sites
Jake 24 Posted June 16, 2006 Share Posted June 16, 2006 If you have a UK car, an atmospheric BOV can confuse the ECU because they use a MAF airflow sensor The j spec cars have a manifold pressure sensor and don't suffer from this problem. Worth noting that the VVTi Supras also have a MAF, unlike the other J-specs. Quote Link to post Share on other sites
MarkTheBoy 0 Posted June 17, 2006 Share Posted June 17, 2006 Iv had the hks bov for about a year now, it should be very simple to fit only took me about 25 mins, the instructions are in japanese but if you take a good look at the pictures then you should be able to work out what you need to do. I am assuming you have the specific valve with fitting kit for the supra? if so everything you need is in with the kit, it goes in where the existing valve is, you wont need to do anything with the engine setup or turbos. some people have these welded onto the IC intake piping i am not sure what the pros/cons of doing this are? I can post a picture of mine fitted if it helpes. If you have piccies that would be great!! Thanks Quote Link to post Share on other sites
supra sam 0 Posted June 17, 2006 Share Posted June 17, 2006 should look something like this when you are done...... http://img126.imageshack.us/img126/1415/bov0019nd.jpg http://img233.imageshack.us/img233/7919/bov0028fo.jpg You can spin it round so that it faces forward, it just would not quite fit under the strut brace on mine. This is the bit you need to take out..... http://img221.imageshack.us/img221/825/bov6aq.jpg Hope these pics help mate Quote Link to post Share on other sites
MarkTheBoy 0 Posted June 17, 2006 Share Posted June 17, 2006 should look something like this when you are done...... [qimg]http://img126.imageshack.us/img126/1415/bov0019nd.jpg[/qimg] [qimg]http://img233.imageshack.us/img233/7919/bov0028fo.jpg[/qimg] You can spin it round so that it faces forward, it just would not quite fit under the strut brace on mine. This is the bit you need to take out..... [qimg]http://img221.imageshack.us/img221/825/bov6aq.jpg[/qimg] Hope these pics help mate Fantastic mate, perfect pictures. Cheers Mark Quote Link to post Share on other sites
MarkTheBoy 0 Posted June 17, 2006 Share Posted June 17, 2006 Fitted, Was a lot simpler than I expected, it took about half an hour, would have taken 10 mins but the bolt that goes into the "manifold" (?) that you mount the bracket to, was seized. Looks and sounds the bee's knees. Well Pleased !!! Thanks nic for supplying it and thanks to sam for the piccies and the encouragement. Quote Link to post Share on other sites
supra sam 0 Posted June 17, 2006 Share Posted June 17, 2006 well done mate enjoy, glad you got it sorted:d Quote Link to post Share on other sites
Ruff_Rider 0 Posted June 18, 2006 Share Posted June 18, 2006 Hi guys. Bought my car a year ago with BOV already fitted. It's situated on the pipe between the intercooler and throttle body, pictured below on the right as you look. The original pipes and BOV have been removed and blankes as in second picture. I've had no problems with this but obviously it's different to yours. Is this fitted correctly? Does it affect performance or need refitting? Quote Link to post Share on other sites
MarkTheBoy 0 Posted June 18, 2006 Share Posted June 18, 2006 Hi guys. Bought my car a year ago with BOV already fitted. It's situated on the pipe between the intercooler and throttle body, pictured below on the right as you look. The original pipes and BOV have been removed and blankes as in second picture. I've had no problems with this but obviously it's different to yours. Is this fitted correctly? Does it affect performance or need refitting? Strange one that is mate? Definitely fitted differently to ours but if its been running fine and dumping ok then I suppose its ok where it is, thats only a guess though. Anyone else have any ideas? Quote Link to post Share on other sites
Scoboblio 9 Posted June 18, 2006 Share Posted June 18, 2006 That's perfectly normal AFAIK, the BOV's just been welded onto the hard pipe rather than put into the stock location. edited: Taken from Ian's original FAQ post; You can mount them in the same place as the stock one (kits are available to do this for most BOVs), or have a flange welded to a hard pipe somewhere (typically the one that goes into the throttle body, but anywhere between turbo and throttle body is OK). Quote Link to post Share on other sites
Ruff_Rider 0 Posted June 19, 2006 Share Posted June 19, 2006 Thanks for that, was worried for a minute. AFAIK? Explain please. Attached detailed pic of current BOV. Can anyone tell me which make it is as there are no apparent markings on it. Thinking of switching to an HKS SSQV. May fit it to stock position if i can and replace the hard pipe with chrome bling pipe. Any views on this? Quote Link to post Share on other sites
supra sam 0 Posted June 19, 2006 Share Posted June 19, 2006 Thanks for that, was worried for a minute. AFAIK? Explain please. Know i didn't say this but AFAIK is short for As Far As I Know. Iv seen that Bov somewhere before? But i cant for the life of me remember who makes it:rolleyes: Quote Link to post Share on other sites
MarkTheBoy 0 Posted June 20, 2006 Share Posted June 20, 2006 Not sure what you have already but I can vouch for the HKS SSQV, its a good honest dumpvalve. Not stupidly loud but sneezes like hell when you give it lots of welly. I have a very limited experience of bovs I admit (SSQV being my first) but have been really impressed with it. Quote Link to post Share on other sites
Alex 13 Posted June 20, 2006 Share Posted June 20, 2006 A Bov has to be mounted between the throttle body and the turbo...it doesn't really matter where between those two items it is...the SQV kit just reuses the stock point. Quote Link to post Share on other sites
ben1985 0 Posted December 31, 2006 Share Posted December 31, 2006 Are atmospheric BOVs only available to make one sound? I don't want one of those BOVs that chirps (tweets?) and am looking for one that sounds like the one on the Supra in Fast and Furious. You know the ones that have repetitive whoosh sound (like chh chh chh chh) rather than a single whoooosh. Does that make any sense?? I was under the impression that this was a re-circulating dump valve? Am I wrong? If not can you get aftermarket Re-circulating dump valves? And if so, anyone know of any good models? Any advice would be very welcome! Cheers, Ben Quote Link to post Share on other sites
uzthedentist 10 Posted December 31, 2006 Share Posted December 31, 2006 that bov looks like a hks racing type ii im pretty certain. theres a company called turbosmart from australia that make pipes like the one seen in the pic leading off the throttle body which you can connect a bov to, i had one on my soarer. http://www.turbosmart.com.au/index.php?id=49 Quote Link to post Share on other sites
uzthedentist 10 Posted December 31, 2006 Share Posted December 31, 2006 the one that makes the ch ch ch sound is the blitz dual drive with the little metal filter on it Quote Link to post Share on other sites
dini_the_owl 14 Posted January 1, 2007 Share Posted January 1, 2007 hi. just a quick question,because ive heard it mentioned in various forums that BOV is a bad idea ..when the bov has let out the pressure from the system the turbos will then have to spool up again to pressurise the system therefore it is causing your turbos to work harder to keep the pressure in the system(ie. lag) and the stock one is there to protect the stock ic not to sound nice. would anyone agree here,never had much to do with them but it does seem feesable to me? also dosent the actuators control your turbos spooling? so when you decelarate or change gear your actuator stops the turbo accordingly,but it dosent stop dead? so why use a BOV? Quote Link to post Share on other sites
Guest Nic Uk-Ridez Posted January 2, 2007 Share Posted January 2, 2007 cause when the preasure ur creating to go one way into ur block cant go there anymore there is only one way the presure will go and thats straight back thro ur turbos cusing the fans to spinn backwards?? so instead of them sppoiling up harder they will endure a very quick change in direction every gear or lift off which is worse than the fans spinning the same way faster n slower if that makes sense Quote Link to post Share on other sites
buster 15 Posted February 10, 2007 Share Posted February 10, 2007 Yup Lol Quote Link to post Share on other sites
edge 16 Posted February 10, 2007 Share Posted February 10, 2007 I have a hks one on mine. It seems to make 2 noises When using alot of throttle i get the usual whoosh noise but when just plodding about it makes chatter noise if you know wat i mean and sometimes it seems like it does a bit of both. Quote Link to post Share on other sites
