Ian C 13 Posted April 3, 2005 Share Posted April 3, 2005 Name: Speed delimiter Also known as: Speed Limit Defender (SLD) Speedo convertor What is it? The Japanese import verion of the Supra is limited to 180km/h, which is 112mph. The SLD bypasses this limit so that you can go faster than 112mph. It usually also serves the function of converting your speedo so that it reads in mph rather than kph (and the odometer counts up in miles). Pros: You can go faster - woohoo! Your speedo reads in mph Your odometer counts up in miles Cons: A good SLD has no cons. This is because it takes the input from the vehicle speed sensor and sends three outputs. One output is unchanged and it goes to systems like the speed sensitive power steering and the active spoiler etc. A second output is scaled so that it reads mph instead of kph - this goes to the speedo and the odometer. A third scaled output goes to the ECU and this is clamped at around 179mph, which stops the ECU from ever engaging the speed limiter function. If the SLD doesn’t have this third output, the limiter will kick in at 180mph instead of 180kph. A crap SLD has various cons. Usually it's electrical-quality related, a lot of problems are caused by poor construction or wiring as the ECU starts seeing a zero speed signal. The main problem with poor SLDs though is if it acts as a speedo convertor as well. Usually they emit only a scaled Vehicle Speed Sensor output to everything, meaning all the speed-dependant systems like the power steering and active spoiler (and especially the autobox!) get an incorrect speed signal and behave eratically. Quote Link to post Share on other sites
Guest SupraTTAeroMatt Posted April 10, 2006 Share Posted April 10, 2006 Hi, Have recently bought an imported Supra and seem to be having problems that seem associated with the SLD. First of all it seems to be limited at approx 122mph???? Also some basic electrics appear to be suffering (Electric Mirrors/Active Spoiler/Stereo folding mechanism). Any tips on whether this may be to do with the SLD or not/where to get a decent one. Matt Quote Link to post Share on other sites
Jake 24 Posted April 10, 2006 Share Posted April 10, 2006 Without a SLD the Supra is limited to 112mph (112 mph = 180 kph) With a SLD fitted it's limited to 180mph. To test for a faulty SLD simply remove it. Good quality SLDs are available from Thor Racing Quote Link to post Share on other sites
miko_supra 19 Posted April 11, 2006 Share Posted April 11, 2006 mine tops out at around 125 too. also when i fold in the electric wing mirrors the speedo goes crazy, managed to get 200mph indicated speed Quote Link to post Share on other sites
SuperSupra 11 Posted April 12, 2006 Share Posted April 12, 2006 mine tops out at around 125 too. also when i fold in the electric wing mirrors the speedo goes crazy, managed to get 200mph indicated speed With regards to the 'topping out' speed, this probably means your speedo is out by a bit, as is mine. Mine appears to go off the scale (which only goes up to 115mph, and then a bit more before hitting 'the wall', so pos due to aftermarket wheels, which sometimes mess the speedo up if you go up a size or 3, and if like mine yours has been converted to mph from kph this could also affect it. Quote Link to post Share on other sites
Guest verbal Posted August 31, 2007 Share Posted August 31, 2007 since I live in Canada we meausre everthing in Metric units. with a SLD can I still have my speedo and ODO read in Km's? Quote Link to post Share on other sites
L33_SUP 0 Posted October 8, 2007 Share Posted October 8, 2007 mine will only go too 125 and reads miles,even though i hav 19s it was the same the day i picked it up on its standard 16s Quote Link to post Share on other sites
Kranz 31 Posted October 8, 2007 Share Posted October 8, 2007 What size tyres on the 16" and 19" wheels?? They could be the same rolling radius, so read the same incorrect speedo reading (spedos always over read, up to 10% more than actual). Quote Link to post Share on other sites
L33_SUP 0 Posted October 21, 2007 Share Posted October 21, 2007 245/45/16 and 265/30/19 Quote Link to post Share on other sites
amigo5 0 Posted October 24, 2007 Share Posted October 24, 2007 i have one but i don't know how to fit it (which wire to which . . ) any suggestion?? Manuals?? Quote Link to post Share on other sites
SteveR 13 Posted October 24, 2007 Share Posted October 24, 2007 i have one but i don't know how to fit it (which wire to which . . ) any suggestion?? Manuals?? I did a guide, but apparently people are having trouble getting hold of Thor deilimiters at the moment; try some 3rd party suppliers maybe? Quote Link to post Share on other sites
gtylerroberts 5 Posted November 7, 2007 Share Posted November 7, 2007 can anyone tell me where to get a good one from? And also where and how to fit it? Quote Link to post Share on other sites
Lebsteif 22 Posted November 7, 2007 Share Posted November 7, 2007 Hi mate, i have one for sale http://www.mkivsupra.net/vbb/showthread.php?t=129827 Quote Link to post Share on other sites
supraman.chris 2 Posted November 12, 2007 Share Posted November 12, 2007 Sold! Quote Link to post Share on other sites
markus99 1 Posted November 15, 2007 Share Posted November 15, 2007 im also having problems that sound related, when i put the car into to drive after reversing out of the drive suddenly (according to the speedo) im doing 120mph! lol. same problem when putting the car into park! Quote Link to post Share on other sites
SteveR 13 Posted November 15, 2007 Share Posted November 15, 2007 im also having problems that sound related, when i put the car into to drive after reversing out of the drive suddenly (according to the speedo) im doing 120mph! lol. same problem when putting the car into park! Any idea what delimiter you've got fitted? Quote Link to post Share on other sites
markus99 1 Posted November 19, 2007 Share Posted November 19, 2007 i don't honestly know it came on the car, suppose im gonna have to rip the dash out to find out?! Quote Link to post Share on other sites
SteveR 13 Posted November 19, 2007 Share Posted November 19, 2007 i don't honestly know it came on the car, suppose im gonna have to rip the dash out to find out?! AFAIK, the only way you can delimit the car (ignore the khmph conversion for now) is to get at pin 2 on the ECU. As that's easier to get to and less hassle than ripping the dash out, I'd have a sneeky peek there on the off chance someone fitted the conversion & delimit chip down there. It's a long shot but you're not investing much time & effort so worth a go - if it's not there, you can attempt to follow the wire to the chip. Take some photos and we can have a go at seeing what's what. Quote Link to post Share on other sites
markus99 1 Posted November 21, 2007 Share Posted November 21, 2007 pulled back the carpet in the footwell last nite and can find absolutely no evidence of any cables etc being cut and connected. could it be fitted elsewhere? Quote Link to post Share on other sites
SteveR 13 Posted November 21, 2007 Share Posted November 21, 2007 pulled back the carpet in the footwell last nite and can find absolutely no evidence of any cables etc being cut and connected. could it be fitted elsewhere? The chip could in theory be fitted anywhere, but from what I've experienced the most usual places are: behind the dash (like mine); under the dash (for easier access if for some reason you wanted to get at it); under the gear surround (again easy access as that's a 1 minute job to remove); ...or sometimes... near the ECU ...but like I say I don't know of any other way of tricking the ECU (i.e. bypassing the 180kph speed limiter) without getting at pin 2, so I'd expect to see some wiring chopped & altered there. However I'm no expert on ECUs (or anything for that matter lol), I just fitted my delimter/convertor & took pics to try and help others - so maybe someone with more technical knowledge can shine a light. Ian C, Matt Harwood spring to mind and I'm sure there are others - maybe drop them a 'pretty please can you offer advice' PM? Quote Link to post Share on other sites
Guest FassTer Posted June 24, 2016 Share Posted June 24, 2016 could it be fitted elsewhere? Quote Link to post Share on other sites
tayr 3 Posted July 2, 2019 Share Posted July 2, 2019 (edited) sorry to bump an old thread - if i already have a mph converter but it doesn't do the delimit - can i fit an SLD aswell or will it interfere? Edit: I currently have the speed m8 converter . Is this a delimiter too? Edited July 2, 2019 by tayr (see edit history) Quote Link to post Share on other sites
