Ian C 13 Posted April 3, 2005 Share Posted April 3, 2005 Name: Solar Sensor Also known as: "the round dome thingy on the top of the dashboard" What is it? It's the round dome on top of the dashboard. It's part of the aircon system and detects strong sunlight coming through the windscreen. Quote Link to post Share on other sites
swandip 1 Posted May 11, 2007 Share Posted May 11, 2007 I never new what this was for. You learn somthing new all the time. Quote Link to post Share on other sites
brettjones 39 Posted May 11, 2007 Share Posted May 11, 2007 i too thought it was for something else cheers matey Quote Link to post Share on other sites
sparkyspar 1 Posted June 26, 2007 Share Posted June 26, 2007 got mine 2weeks ago now it all starts,also wondered wat it was.cool:cool: Quote Link to post Share on other sites
downimpact 14 Posted June 26, 2007 Share Posted June 26, 2007 hmm and what does it do? Besides detect strong sunlight? Quote Link to post Share on other sites
Lewis 6 Posted June 26, 2007 Share Posted June 26, 2007 hmm and what does it do? Besides detect strong sunlight? nothing Quote Link to post Share on other sites
SimonB 4 Posted June 26, 2007 Share Posted June 26, 2007 hmm and what does it do? Besides detect strong sunlight? Basically it makes the climate control work to a lower temperature to compensate for the fact that the sun through the glass is heating everything (including you) up and causing it to radiate more heat. Quote Link to post Share on other sites
Lewis 6 Posted June 26, 2007 Share Posted June 26, 2007 Basically it makes the climate control work to a lower temperature to compensate for the fact that the sun through the glass is heating everything (including you) up and causing it to radiate more heat. nope, the system does that - the dome is just a light sensor. Quote Link to post Share on other sites
SimonB 4 Posted June 26, 2007 Share Posted June 26, 2007 nope, the system does that - the dome is just a light sensor. Well obviously that's the case, but there's no need to be deliberately obtuse and unhelpful about it is there? The questioner was obviously asking what role the sunlight sensor has as part of the function of the system as a whole. Quote Link to post Share on other sites
Lewis 6 Posted June 26, 2007 Share Posted June 26, 2007 Well obviously that's the case, but there's no need to be deliberately obtuse and unhelpful about it is there? The questioner was obviously asking what role the sunlight sensor has as part of the function of the system as a whole. Sorry mum Quote Link to post Share on other sites
JamesG 0 Posted June 26, 2007 Share Posted June 26, 2007 According to some website I found, there's a moisture sensor and a solar sensor. In conjunction with each other, the relative humidity on the windscreen is calculated so the air-con operates to reduce fogging. From looking at what the climate control does in the supra, it appears to be able to change the fan speed and change whether the air is on outside or recirculate. Quote Link to post Share on other sites
MarkR 23 Posted July 3, 2007 Share Posted July 3, 2007 how much does it weight? maybe I can save 2grams of weight by removing it Quote Link to post Share on other sites
sparkyspar 1 Posted September 24, 2007 Share Posted September 24, 2007 Sorry mum Quote Link to post Share on other sites
Guest Scotty 88 Posted September 11, 2014 Share Posted September 11, 2014 Ohhh well am happy I know that it's been annoying me what it was Quote Link to post Share on other sites
Abz 7 Posted September 11, 2014 Share Posted September 11, 2014 I had no idea what it was! Quote Link to post Share on other sites
mike33 2 Posted September 17, 2014 Share Posted September 17, 2014 So if its a light sensor could we wire this upto the lights to make them come on automatically when it gets dark like modern modern cars!!!!!!!!!! Quote Link to post Share on other sites
Kaan W 54 Posted September 17, 2014 Share Posted September 17, 2014 So if its a light sensor could we wire this upto the lights to make them come on automatically when it gets dark like modern modern cars!!!!!!!!!! That's not a bad idea actually, I would have thought wiring it to the relay on the same circuit as the switch so you can still switch the lights on manually. Quote Link to post Share on other sites
David P 205 Posted September 17, 2014 Share Posted September 17, 2014 So if its a light sensor could we wire this upto the lights to make them come on automatically when it gets dark like modern modern cars!!!!!!!!!! There's a plug & play Toyota component for that. Quote Link to post Share on other sites
mike33 2 Posted September 17, 2014 Share Posted September 17, 2014 Cheers For this David.. May have to make a phone call to Toyota Quote Link to post Share on other sites
Dragonball 76 Posted September 17, 2014 Share Posted September 17, 2014 There's a plug & play Toyota component for that. I used to have one in my first Supra...aftermarket but not sure it was Toyota Quote Link to post Share on other sites
