The mkiv Supra Owners Club Wheels in Motion
Go Back   The mkiv Supra Owners Club > Technical > FAQs and Guides > Technical Glossary
Notices
Reply
Thread Tools Display Modes
Old 02-11-09, 09:43   #76
tDR
Record Breaking
Super Moderator
tDR's Avatar
Sales Feedback: 100% (6)
Quote:
Originally Posted by Suprafly View Post
Right I'm currently ordering parts from whifbitz for a full BPU.
I've got a 96 J-spec RZ-S, I already have a Blitz Nur spec cat back system fitted, so I'm after:
HKS FCD
Question is what grade plugs do I go for?
Grade 7's. Check out the spark plug FAQ for well documented info on the subject.
I'd always go with a GReddy BCC (another name for an FCD) over the HKS FCD because of the method it uses to fool the stock ECU on the airflow signal.
Cheers,
Brian.
__________________
ex '97 TT (non vvti) | Standard Engine, Turbos & Fuel System | A Few Choice Mods inc. MAP2 ECU Self Mapped
11.5 @ 114MPH (Supra Pod '08) | Club & European Drag Class Record Holder
USSC Champion 2007/8 (RWD & Overall Classes)
Supra Pod Champion 2008/9 (Stock or Stock Based Twins Class & Best 60ft Time Class)
"TDR is a law upon himself" - Matt H, Feb 2010
tDR is online now   Reply With Quote
Old 05-02-10, 00:44   #77
deathmonkey
I'm addicted now!
MEMBERSHIP EXPIRED
Sales Feedback: 100% (1)
Massive apologies if this has been answered either on this thread or elsewhere, I've searched solid, I promise !
Anyway, as I'm hoping to go BPU by the summer, I was just wondering what type of fuel I should be aiming to use? Does it not change from what I've always done - use the best at whatever station I'm at, or should I really be looking to use v-power for example, when I do eventually go BPU.
Thanks guys, again apologies if already answered.
deathmonkey is offline   Reply With Quote
Old 05-02-10, 01:06   #78
Homer
Hmmm.... Donuts
Super Moderator
Homer's Avatar
Sales Feedback: 100% (44)
Simply use the higest octane fuel available to you. Shell v-power, BP Ultimate, etc. As always, ensure you have an AFR (worry gauge) to keep an eye on the levels and if it gets beyond limits back off.
I wouldn't recommend it though if only low octane is avaiable, unless the car has an aftermarket ECU & map at higher boost pressures (1.1 and above) it's *needed* to use high octane fuel. Peak power is not the issue, it's the switch-over point that causes det.
__________________
Beer, the source of and solution to, all of lifes problems
94 GZ NA 5spd Aero
93 RZ Boostlogic T67dbb 6spd (sold)
Homer is online now   Reply With Quote
Old 05-02-10, 11:33   #79
deathmonkey
I'm addicted now!
MEMBERSHIP EXPIRED
Thanks for the reply Homer, good to know .
Old 11-03-10, 23:36   #80
BABZ988
I'm a newbie
MEMBERSHIP DUE
Sales Feedback: 0% (0)
i think:
if i buy a tanabe full decat system (usually a 4"); i'll need a restrictor ring !
but if i buy a 2.5 decat system from whifbitz ; will still need a ring?
looking for BPU at the moment!
BABZ988 is offline   Reply With Quote
Old 12-03-10, 00:36   #81
Homer
Hmmm.... Donuts
Super Moderator
Homer's Avatar
If it'a a jspec then yes, you will need the restrictor ring and the other mods before decatting, regardless of the exhuast diameter.
__________________
94 GZ NA 5spd Aero
Old 14-05-10, 17:15   #82
Pudsey
Say Ello 2 My Little ...>
Club Member
Pudsey's Avatar
Sales Feedback: 100% (7)
Can someone answer me this, as there seems to be some differences of opinion.
I am BPU'ing my 1998 VTT-i Twin Turbo.
I need to know if I need a Fuel Cut Defender or not.
If I don't fit it and run the car without it will it get damaged?
Any advice would be appreciated and is rather urgent due to attending Japfest tomorrow.
Pudsey is offline   Reply With Quote
Old 14-05-10, 17:34   #83
Thorin
Genius
Club Member
Thorin's Avatar
Sales Feedback: 100% (3)
You need one, otherwise you'll hit fuel cut >1.0bar
__________________
Michael
http://www.kulthea.net
Black '94 J-Spec mkIV 6 Speed TT
Thorin is offline   Reply With Quote
Old 18-05-10, 16:07   #84
Shane
BPU happy
Club Member
Shane's Avatar
Sales Feedback: 100% (9)
2 questions relating to BPU and the restrictor ring
Just about to go BPU and I have a couple of questions both relating to the ristrictor ring.
With the restrictor ring in with a hole of say 2 inches, is there any real point or advantage with a 3" exhaust, surely the ring becomes the most restrictive point and any advantage of a big bore exhaust after the ring is lost?
If I use 3" decat pipes and then have the ring between the second decat and the exhaust, surely when the engine is suddenley revved hard, until the pressure is built up between the turbos and the restrictor ring it is possible to overboost?
I know this is all proven territory and don't question it works as of course it does but as I was looking at the 3" decat pipes I bought for mine these questions just sprang to mind.
__________________
Great minds discuss ideas,
average minds discuss events,
small minds discuss people.
WIP: Satin black BPU.
J spec N/A auto, Red, soon to be for sale.
Daily commute Vauxhall corsa van diesel. 180k miles, 85k on SVO .
Shane is offline   Reply With Quote
Old 29-06-10, 20:20   #85
supra-ireland
Work... what work?
Club Member
supra-ireland's Avatar
I've a question about my BPU setup.
I've got an Apexi S-AFC, it came with the car uninstalled.
I'm happy to install it myself but having read through the foum some people suggest that there's no point fitting one with a BPU setup.
Can the S-AFC improve things or should I just forget about it?
I've got stock turbos and was hoping to usually limit boost to 1.0 bar and occasionally go up to 1.2 bar.
supra-ireland is offline   Reply With Quote
Old 29-06-10, 23:26   #86
tDR
Record Breaking
Super Moderator
tDR's Avatar
Sell it and do things properly if you want to get into tweaking maps IMO.
__________________
Old 29-06-10, 23:31   #87
supra-ireland
Work... what work?
Club Member
Quote:
Ok, thanks.
So at a BPU level is there much point with aftermarket ECUs and the like
or are you as well to stay with stock?
Old 29-06-10, 23:32   #88
tDR
Record Breaking
Super Moderator
tDR's Avatar
I'd say there's definitely gains to be had but the ECU or piggyback needs to have decent resolution mapping wise to really get the most out of the sequential setup to optimise the fuelling and timing across the rev range.
__________________
Old 29-06-10, 23:58   #89
supra-ireland
Work... what work?
Club Member
Is there anything you could recommend?
I want to keep costs down but at the same time I'm willing to spend enough to get something proper.
Thanks for the advice.
Old 30-06-10, 00:08   #90
Peter P
Whifbitz Monkey
Club Member
Sales Feedback: 100% (5)
Would recommend looking at one of the SYVEC ECU's that Ryan does as these seem very comprehensive and would be future proofed if you went single at a later date.
The Whifbitz Time Attack cars both run this ECU to good effect and it also has goodies such as traction control and boost control involved.
Have a look under 2 bar tuning as a trader and see what you think.
There are other options but Ryan sets these up perfectly and the piece of mind having UK support both with the manufacturer and tuner appeals to me.
Will be what I go for when I get my next one!
Just my opinion by the way.
Pete
__________________
Supra-less and going mad!
Peter P is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
vBulletin - Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright © 2004 - 2010, The mkiv Supra Owners Club (mkivsupra.net)
