Page 9 of 9 FirstFirst ... 56789
Results 121 to 128 of 128
Thread: Blitz Twin Turbo Installation
  1. #121
    Work... what work? Club Member dk_supra's Avatar
    Join Date
    Apr 2004
    Location
    Greece
    Posts
    610
    Feedback
    11 (100%)
    Quote Originally Posted by TRD3000GT View Post
    Tony,
    They never tell anyone this but you should take out all the wrap and bung it in a bucket of warm/hot water let it sit overnight and cool and in the morning fit it to the pipes. After fitting leave somewhere warm and the wrap tightens and leaves NO seams..
    And then spray it with the COOL IT thermal paint to make it absolutely perfect and you will never see it deteriorate. That's how we do it. All you have to do is ask about it.
    Cheers
    Dk
    Dimitri the Greek (aka Mad Scientist)
    AEM Factory Trained Tuner
    T51 SPL BB Supra MKIV @ 2.5 bar (3 bars i'm coming)
    TO4Z Supra MKIV @ 1.65 bar (we need this to last for a long time)
    TO4Z EVO VIII @ 2.5 bar w/methanol
  2. #122
    Now owns a two three.. Club Member b'have's Avatar
    Join Date
    Sep 2002
    Location
    England - Hampshire
    Posts
    3,680
    Feedback
    17 (100%)
    Quote Originally Posted by dk_supra View Post
    ....and some really different piston rings.The most important is the crossing of the piston rings to be done as toyota instructs, otherwise you will be loosing compression after some miles.
    Could you tell us more regarding the rings?Also, unsure what you mean by "crossing"
    Now Datsuned (GTR R35 640 BHP Litchfield stage 4+)
    GT4088 .81ar 610 bhp controlled by PowerFC pro. Mapped by Ryan G.
    Now sold http://www.mkivsupra.net/vbb/showthr...-(may-p-x-auto)
  3. #123
    Join Date
    Apr 2004
    Location
    Greece
    Posts
    610
    Feedback
    11 (100%)
    i will look at my supplier for the brand, as far as the crossing, just look at the manual and it says everything pretty clear.
  4. #124
    Join Date
    Apr 2004
    Location
    Greece
    Posts
    610
    Feedback
    11 (100%)
    We are putting my brother's car inside the shop for the following maintenance today, and some other goodies.
    TRD differential with new bearing and seals, with Castrol RS diff fluid
    TRD strut brace
    Goodridge brake lines and fluid change
    New Boostlogic turbo blankets
    Oil Change
    Oil filter change
    Boost solenoid install, and tuning at 1.5 bars
    New tyres 235/35/19 front, 295/30/19 rear
    inspection of every nuts and bolt on the front and rear subframe
    Allignment check
    Brake system complete check up
    TEIN suspension check and rebuild if neccesary
    HKS midpipe (he had an exhaust shop made one, but it looks like $hit)
    Air filter clean up
    IK24s replacement
    Compression check, leakdown check and shimming check of valves.
    HKS triple clutch check and retighten
    Complete instrument cluster carbon kit install
    HKS manifolds retighten, turbine housings retighten, wastegates retighten.
    Inspect all the t-bolt clamps on the IC pipes.
    The one year basic maintenance and some more stuff.
    It should be interesting to see if at 1.5 bars, we run out of injectors on pump gas. I'm pretty sure we will, so we might reduce our target to 1.4 or 1.3. We'll see and act accordingly. Should be back on the street by mid next week, hopefully a lot faster.
  5. #125
    Me? Post? Never! Club Member
    Join Date
    Apr 2003
    Location
    England - Oxfordshire
    Posts
    5,675
    Feedback
    8 (100%)
    Cheers
    Dk
    I was specifically told by Zircotek NOT to wet the wrap. They said the reason is that it retains moisture, which then obviously boils off when the manifold get's hot, and can cause the manifold to crack.
    Otherwise yes it would be much better to wet it, as it's a real MOFO to come into contact with when it's dry.
    Tony License
    Oxford UK
    '93 JDM BTT GZ 6Spd conversion
    Pushing for the championship....
  6. #126
    Join Date
    Apr 2004
    Location
    Greece
    Posts
    610
    Feedback
    11 (100%)
    How many days were you itching after the wrapping, I hate wrapping, that's why i charge the customers about 300-400 euros plus the wrap in order to do the job.
  7. #127
    Me? Post? Never! Club Member supra_ufo's Avatar
    Join Date
    Sep 2012
    Location
    England - West Yorkshire
    Posts
    4,292
    Feedback
    14 (100%)
    Wish I had come across this thread when I was removing my stock twins! OMG what a pain in the ass!
    Thanks OP, I'll use this as a guide to install the refurbed ones
  8. #128
    I'm a newbie
    Join Date
    Oct 2016
    Location
    (Top Secret)
    Posts
    4
    Feedback
    0
    Quote Originally Posted by TLicense View Post
    I finished the installation of the fuel pump assembly today.
    I had a couple of issues though.
    First of all, when I went to fit the banjo fittings after putting the pump assembly into position and fitting the retainer ring (here's a tip, if you're struggling to re-fit the retainer ring try running some grease on the thread. Not too much mind, you don't want to be getting it in the fuel tank!) I found that as the banjo fittings sit very close to the top of the retainer ring, they fouled it. So I had to relieve some of the upper portion of the ring around each fitting:-
    http://img.photobucket.com/albums/v6..._1871Large.jpg
    http://img.photobucket.com/albums/v6..._1872Large.jpg
    http://img.photobucket.com/albums/v6..._1873Large.jpg
    I then found even when just using banjo fixings and not the 90 degree bends that I'd originally hoped to use, it still fouled the inspection cover. To get around this I initially tried turning down the head of the -8 feed bolt. But it still clashed with the inspection cover, so there was nothing else to do than grind a small hole into the top of the cover. By the time I'd finished it was a not so small hole. It's not very neat but it's got the job done. If I were doing it again, I would just drill a hole just big enough to fit the bolt head through. I also drilled a 6mm hole through the inspection cover and fitted a gromet for my ground strap to go through:-
    http://img.photobucket.com/albums/v6..._1877Large.jpg
    I've fitted the ground strap to the ground point on the rear bulkhead. I've given myself enough cable so that I can tape it to the floor of the boot so it won't catch on anything:-
    http://img.photobucket.com/albums/v6..._1878Large.jpg
    http://img.photobucket.com/albums/v6..._1876Large.jpg
    I also fitted the fuel feed up to the fuel filter and produced an exact list of components that I've used for my fuel line set-up that I'll post later.
    2Tlicense, can you help me plz:
    I am going to do smth the same on my Evo and I found almost all parts of the connector, but I cant find how to fix the terminal in fuel pump hanger. can you please check picture of what I need (marked red), may be you ciuld give me a tip where to get it.
    also is there any "gasket" supplied with
    thanks a lot,
    Misha
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
