FAQ: Oil, Fluid, Interval, Capacity, Steering, Brake, Coolant, Diff, Engine.
Alex
2JZ-GTE Engine Oil (TT Engine on a MKIV (UK or JDM))
Stock = 10w30 Semi Synthetic
I recommend Fully Synthetic 10w40/50
Dry Capacity 6.5L's
Change capacity 5-6L's (Have 6L's ready)
Regular Driving - BPU or Less
5w40 - Silkolene Pro S (Now Fuchs Titan Pro S), Castrol RS, Motul 300V Power
5w50 - Valvoline VR1 SynPower, AGIP PC5w-50
Regular Driving - BPU to Big Power
10w40 - Motul 300V Chrono, Royal Purple Racing 41
10w50 - Silkolene Pro S (Now Fuchs Titan Pro S)
10w60 - Castrol RS (NB Untested)
Track Oil
15w50 - Silkolene Pro R, Motul 300V
I'd recommend the 10w50 Silkolene/Fuchs Titan as it's Ester based.
NB: Mobil1 0wxx has been known to get passed the piston rings and cause excessive oil consumption. I would recommened ALL 0wXX oils are avoided. 5W is the lowest I would use.
See here for details on how to change your oil.
Interval = 3-9,000miles depending on use/power levels
2JZ-GE Engine Oil (NA (Non Turbo) Engine on a MKIV (JDM only))
Stock = 5w30 Semi Synthetic
I recommend Fully Synthetic 5w30-10w40
Dry Capacity 6.2L's
5w30 - Motul 300V
5w40 - Motul 300V, Silkolene Pro S (Now Fuchs Titan Pro S)
Change capacity 4.8-5.8L's
I'd recommened Silkolene Pro S 5w40.
Being less stressed that the GTE version any Fully Synthetic oil between a 5w30 and 10w40 should suffice.
Interval = 9-12,000miles depending on use
LSD Diff Oil
Stock = Unknown 75w90 Gear Oil
Capacity ~1.5L's (have 2L's Ready)
75w90 - Motul Gear 300 or Silkolene Syn5 (Now Fuchs Titan)
I recommened either of the two listed - both have been used without issue.
Interval = 2 Years / 30,000miles depending on use/power levels
See here for details on changing diff oil.
Manual 6-speed V160/161 Gearbox
Stock = Toyota V160 oil (PART No. 08885-01306)
Capacity 1.8l's when dry
Toyota V160 Oil (comes in 1L cans - require 2 cans)
Alternative:
Esso Dextron D21065
Royal Purple SynchroMax
BMW oil called MTF-LT-1 or LT-2
Castrol Transmax Z - Feedback required from testers
Mobil ATF 220 - Feedback required from testers
I recommend you stick with stock but in recent times this has been hard to get hold of, so it's the Esso now...
Automatic 4-speed A340E
Capacity = 8.2L's (But you can only really change what's in the sump of it and that is ~2L's)
Stock = Toyota Type-IV - 2L's for a quick change. Have 10L's ready for a full flush.
Recommended Oil = Toyota Type-IV / Fuchs Titan 4400 / Motul ATF 1A
Interval = 1 years / 15,000 miles per 2L quick change with heavy use. 2 years and 30,000miles if you're a light user.
NB: You only need to do a full flush if something is wrong....it could actually be harmful to do too many full flushes due to the additives in the oil.
5-Speed Manual W58 (NA only)
Capacity = 2.6L
Recommended Oil = Any 75w/90 Gear oil should be ok. Motul Gear300 is a good option.
Stock Oil = SAE 75W-90/API GL-5 Gear Oil
Interval = Check transmission fluid level every 15,000 miles or 24 months. Service interval is not available for vehicles operated under normal conditions. Replace transmission fluid every 15,000 miles or 24 months if used under severe / heavy conditions
Brake Fluid
Stock = Dot 4
I recommend DOT 5.1
Capacity ~1.5L's (Have 2L's ready)
DOT 5.1 = Motul RBF600, Castrol SRF
Interval = Every 12months (also after any track day!)
Power Steering Fluid
Stock Dexron III ATF
I recommend you stick with Dexron III oil but all makes should be suitable
Capacity
Interval = ???
To fully Flush it see here
Clutch Fluid
Stock = DOT3 Brake Fluid
Capacity = Under 1L??
Interval = ???
I recommend you stick with stock or use a DOT4/5.1 Brake Fluid.
Coolant
Stock = Toyota 4Life Red
Capacity ~9L
I recommend you stick with Toyota Coolant.
Interval = 30,000miles
This should help you with a coolant change.
NB: 4Life changes colour as it get older, when it starts to turn a more browny red compared to it's vibrant red when new then it needs to be changed. Also 4Life comes premixed and needs no other liquids mixed with it.
The authour and site take no responsibility for your action/inaction following your reading of this FAQ...it's here as a guide.
Keywords: Oil, Fluid, Interval, Capacity, Steering, Brake, Clutch, Coolant, Diff, Engine.
Edited by Alex (see edit history)
  • Replies 317
Posted Images
Silkolene PRO S comes in two viscosities:
Pro S 5w-40 - Stock road cars
Pro S 10w-50 - Modded/track cars
There is also Silkolene Pro R 15w-50 for dedicated tarck addicts!
Silkolene Pro S 5w-40 is available in 5L cans
Silkolene Pro S 10w-50 is available in 5L and 25L cans
Silkolene Pro R 15w-50 is available in 5L and 25L cans
Silkolene SYN 5 is available in 1L
Silkolene Boa 90LS (Diff only) in 1L
Motul 300V 5w-30, 5w-40 and 10w-40 in 2L or 25L
Motul 300V 15w-50 is available in 2L, 4L or 25L
Motul RBF 600 DOT 4 racing brake fluid in 500ml
Motul Gear 300 75w-90 available in 1L
All products can be seen here: http://www.opieoils.co.uk Club Prices (discounted) are in the Members Section to buy on line.
Cheers
Simon
Cheers
Simon
Ahh I though there was a 10w40 Pro S oops...editing.
Thanks for the input.
  • 3 weeks later...
  • 4 months later...
  • 1 month later...
Please can someone give me some urgent advice. Right now I am near Carlisle and I have over 300 miles to drive back to Hertfordshire. My dilemma is that I have a bit of oil left but not enough. The current oil is Valvolene VR1 Racing 5w50 but as I originally got this when i was at JPS, I know that Halfords dont have it as i had a quick look yesterday. Carlisle is barren of anything except Halfords on a Sunday i think ! SO please please can someone urgent suggest what oil can be safely mixed eg Mobil 5w40 etc??? I have to set off this afternoon!
my car is Supra Jap import JZ-GTE. Twin Turbo with lots of mods and just under 400bhp.
look forward to replies from any early risers on a Sunday! :rolleyes:
hi - yes its pretty much minimum. The warning light came on randomly when i drove up on Friday then hasnt come on but the oil really is almost minimum. what do you reckon about mixing oil if i have to?
can't see a problem with oil mixing if you have the correct type - i once used gtx magnetec (sp) was running low :blush: - had no problems with it (did over 400 miles before had the chance to change it for the good stuff )- no issues -BUT do change it when you have the chance!
You'll be ok mixing for a top up, but try to avoid mixing synthetic and mineral oil. I take it the Valvoline currently in the engine is synthetic?
Edit - You'll be ok with 5w40 (as long as the type ie mineral or synthetic is the same).
Was it your oil pressure warning light or oil level warning light which came on? if it's just the level, then no prob's. If it's the pressure warning light it could be something more serious.
Hope not though!
oil level is 'amber' in colour...........oil pressure is the red one.
Whilst not as bad if its the amber one it still needs checking out as this requires quite a bit of oil loss to come on and so you may have a leak somewhere.
Put in the spare oil you've got asap (as any mixing issues are minimal compared to running it when very low on oil) and then monitor the level daily is my advice :)
  • 4 months later...
Any chance of adding the Oil Filter part numbers to the first entry in this FAQ? Feel free to delete this post after doing so :)
IIRC there are two choices, a larger (Lexus?) one with a metal filter element, and the regular Supra one with paper filter and smaller capacity.
Edit:
These are from Paul E's helpful part no's thread:
Engine Oil Filter Stock Supra Turbo 08922-02011
Engine Oil Filter Lexus V8 90915-20004
  • 9 months later...
