Page 1 of 21 1234511 ... LastLast
Results 1 to 15 of 308
Thread: FAQ: Oil, Fluid, Interval, Capacity, Steering, Brake, Coolant, Diff, Engine.
  1. #1
    Subtle/Diplomatic Club Member Alex's Avatar
    Join Date
    Jun 2001
    Location
    England - Norfolk
    Posts
    15,833
    Feedback
    13 (100%)
    2JZ-GTE Engine Oil (TT Engine on a MKIV (UK or JDM))
    Stock = 10w30 Semi Synthetic
    I recommend Fully Synthetic 10w40/50
    Dry Capacity 6.5L's
    Change capacity 5-6L's (Have 6L's ready)
    Regular Driving - BPU or Less
    5w40 - Silkolene Pro S (Now Fuchs Titan Pro S), Castrol RS, Motul 300V Power
    5w50 - Valvoline VR1 SynPower, AGIP PC5w-50
    Regular Driving - BPU to Big Power
    10w40 - Motul 300V Chrono, Royal Purple Racing 41
    10w50 - Silkolene Pro S (Now Fuchs Titan Pro S)
    10w60 - Castrol RS (NB Untested)
    Track Oil
    15w50 - Silkolene Pro R, Motul 300V
    I'd recommend the 10w50 Silkolene/Fuchs Titan as it's Ester based.
    NB: Mobil1 0wxx has been known to get passed the piston rings and cause excessive oil consumption. I would recommened ALL 0wXX oils are avoided. 5W is the lowest I would use.
    See here for details on how to change your oil.
    Interval = 3-9,000miles depending on use/power levels
    2JZ-GE Engine Oil (NA (Non Turbo) Engine on a MKIV (JDM only))
    Stock = 5w30 Semi Synthetic
    I recommend Fully Synthetic 5w30-10w40
    Dry Capacity 6.2L's
    5w30 - Motul 300V
    5w40 - Motul 300V, Silkolene Pro S (Now Fuchs Titan Pro S)
    Change capacity 4.8-5.8L's
    I'd recommened Silkolene Pro S 5w40.
    Being less stressed that the GTE version any Fully Synthetic oil between a 5w30 and 10w40 should suffice.
    Interval = 9-12,000miles depending on use
    LSD Diff Oil
    Stock = Unknown 75w90 Gear Oil
    Capacity ~1.5L's (have 2L's Ready)
    75w90 - Motul Gear 300 or Silkolene Syn5 (Now Fuchs Titan)
    I recommened either of the two listed - both have been used without issue.
    Interval = 2 Years / 30,000miles depending on use/power levels
    See here for details on changing diff oil.
    Manual 6-speed V160/161 Gearbox
    Stock = Toyota V160 oil (PART No. 08885-01306)
    Capacity 1.8l's when dry
    Toyota V160 Oil (comes in 1L cans - require 2 cans)
    Alternative:
    Esso Dextron D21065
    Royal Purple SynchroMax
    BMW oil called MTF-LT-1 or LT-2
    Castrol Transmax Z - Feedback required from testers
    Mobil ATF 220 - Feedback required from testers
    I recommend you stick with stock but in recent times this has been hard to get hold of, so it's the Esso now...
    Automatic 4-speed A340E
    Capacity = 8.2L's (But you can only really change what's in the sump of it and that is ~2L's)
    Stock = Toyota Type-IV - 2L's for a quick change. Have 10L's ready for a full flush.
    Recommended Oil = Toyota Type-IV / Fuchs Titan 4400 / Motul ATF 1A
    Interval = 1 years / 15,000 miles per 2L quick change with heavy use. 2 years and 30,000miles if you're a light user.
    NB: You only need to do a full flush if something is wrong....it could actually be harmful to do too many full flushes due to the additives in the oil.
    5-Speed Manual W58 (NA only)
    Capacity = 2.6L
    Recommended Oil = Any 75w/90 Gear oil should be ok. Motul Gear300 is a good option.
    Stock Oil = SAE 75W-90/API GL-5 Gear Oil
    Interval = Check transmission fluid level every 15,000 miles or 24 months. Service interval is not available for vehicles operated under normal conditions. Replace transmission fluid every 15,000 miles or 24 months if used under severe / heavy conditions
    Brake Fluid
    Stock = Dot 4
    I recommend DOT 5.1
    Capacity ~1.5L's (Have 2L's ready)
    DOT 5.1 = Motul RBF600, Castrol SRF
    Interval = Every 12months (also after any track day!)
    Power Steering Fluid
    Stock Dexron III ATF
    I recommend you stick with Dexron III oil but all makes should be suitable
    Capacity <4L's
    Interval = ???
    To fully Flush it see here
    Clutch Fluid
    Stock = DOT3 Brake Fluid
    Capacity = Under 1L??
    Interval = ???
    I recommend you stick with stock or use a DOT4/5.1 Brake Fluid.
    Coolant
    Stock = Toyota 4Life Red
    Capacity ~9L
    I recommend you stick with Toyota Coolant.
    Interval = 30,000miles
    This should help you with a coolant change.
    NB: 4Life changes colour as it get older, when it starts to turn a more browny red compared to it's vibrant red when new then it needs to be changed. Also 4Life comes premixed and needs no other liquids mixed with it.
    The authour and site take no responsibility for your action/inaction following your reading of this FAQ...it's here as a guide.
    Keywords: Oil, Fluid, Interval, Capacity, Steering, Brake, Clutch, Coolant, Diff, Engine.
    - Alex
    2012 BMW S1000RR Black
    ex - 1996 TT Gunmetal Facelift Auto, ex - 1998 RSP TT6 VVT-i BL-T61, ex - 1993 MSB TT6 w/ MINES ECU / BBS LM's, ex - 1995 S13 200SX Facelift
    ______________________________________
  2. #2
    Join Date
    Jun 2001
    Location
    England - Norfolk
    Posts
    15,833
    Feedback
    13 (100%)
    Please all check and help out with the ???'s or correct what's wrong.
    Thanks
    - Alex
  3. #3
    What search button? Authorised Trader oilman's Avatar
    Join Date
    Sep 2004
    Location
    England - Cornwall
    Posts
    1,494
    Feedback
    27 (100%)
    Silkolene PRO S comes in two viscosities:
    Pro S 5w-40 - Stock road cars
    Pro S 10w-50 - Modded/track cars
    There is also Silkolene Pro R 15w-50 for dedicated tarck addicts!
    Silkolene Pro S 5w-40 is available in 5L cans
    Silkolene Pro S 10w-50 is available in 5L and 25L cans
    Silkolene Pro R 15w-50 is available in 5L and 25L cans
    Silkolene SYN 5 is available in 1L
    Silkolene Boa 90LS (Diff only) in 1L
    Motul 300V 5w-30, 5w-40 and 10w-40 in 2L or 25L
    Motul 300V 15w-50 is available in 2L, 4L or 25L
    Motul RBF 600 DOT 4 racing brake fluid in 500ml
    Motul Gear 300 75w-90 available in 1L
    All products can be seen here: http://www.opieoils.co.uk Club Prices (discounted) are in the Members Section to buy on line.
    Cheers
    Simon
    Use the code M4SUPOC and get 10% Club Discount
    View Opie Oils Current Offers Here > >
    oilman's website: http://www.opieoils.co.uk/ - register for news and offers
    email: sales@opieoils.co.uk
    phone: 01209 202944
    http://www.opieoils.co.uk/images/ban...rum-banner.gif
  4. #4
    Join Date
    Jun 2001
    Location
    England - Norfolk
    Posts
    15,833
    Feedback
    13 (100%)
    Quote Originally Posted by oilman
    Cheers
    Simon
    Ahh I though there was a 10w40 Pro S oops...editing.
    Thanks for the input.
    - Alex
  5. #5
    I'm a newbie
    Join Date
    Dec 2005
    Location
    (Top Secret)
    Posts
    21
    Feedback
    0
    Could i ask why Red Line oil isn't listed on here ??
  6. #6
    Join Date
    Jun 2001
    Location
    England - Norfolk
    Posts
    15,833
    Feedback
    13 (100%)
    Quote Originally Posted by jasonc
    For what? If you say the 6-speed gearbox you will be fired out of the nearest available cannon
    - Alex
  7. #7
    I'm a newbie
    Join Date
    Dec 2005
    Location
    (Top Secret)
    Posts
    21
    Feedback
    0
    Alex: Yes for the 6-Speed joke..joke. For Engine Oil on the TT's
  8. #8
    I'm addicted now! Club Member BASHTHEBISHOP's Avatar
    Join Date
    Apr 2006
    Location
    England - Avon
    Posts
    1,798
    Feedback
    1 (100%)
    Nice post Alex. Lots of useful info especially for the 'posess no car knowlegde' people like myself
    I had been looking into oils recently and having always used Castrols, i checked out there site:-
    http://www.ew2.lubesinfo.com/framese...=1156&langid=1
  9. #9
    Join Date
    Jun 2001
    Location
    England - Norfolk
    Posts
    15,833
    Feedback
    13 (100%)
    Castrol is supposed to be less advanced than Silkolene...according to Simon (OILMAN) of Opie Oils.
    But I used the 10w60 RS and found no issues in the short term with it.
    - Alex
  10. #10
    Join Date
    Sep 2004
    Location
    England - Cornwall
    Posts
    1,494
    Feedback
    27 (100%)
    Depends what castrol you are talking about.... some are very good such as the 0w-30's longlife oils, and gear oils.
    However the likes of the RS 10w-60 and the Magtnatec are very overated in terms of quaulity.
    Cheers
    SImon.
    phone: 01209 202944
  11. #11
    Work... what work? MEMBERSHIP EXPIRED
    Join Date
    Feb 2006
    Location
    (Top Secret)
    Posts
    1,105
    Feedback
    0
    Or Amsoil..?.....
    http://planetsoarer.com/OilAnalysis/Amsoil.htm
  12. #12
    I can post! MEMBERSHIP EXPIRED
    Join Date
    Dec 2003
    Location
    England - Hertfordshire
    Posts
    65
    Feedback
    0
    Warning Help - urgent oil crisis
    Please can someone give me some urgent advice. Right now I am near Carlisle and I have over 300 miles to drive back to Hertfordshire. My dilemma is that I have a bit of oil left but not enough. The current oil is Valvolene VR1 Racing 5w50 but as I originally got this when i was at JPS, I know that Halfords dont have it as i had a quick look yesterday. Carlisle is barren of anything except Halfords on a Sunday i think ! SO please please can someone urgent suggest what oil can be safely mixed eg Mobil 5w40 etc??? I have to set off this afternoon!
    my car is Supra Jap import JZ-GTE. Twin Turbo with lots of mods and just under 400bhp.
    look forward to replies from any early risers on a Sunday!
  13. #13
    I'm addicted now! Club Member SUPRASUZUKI's Avatar
    Join Date
    May 2006
    Location
    England - Norfolk
    Posts
    1,604
    Feedback
    14 (100%)
    When you say a bit of oil left, I take it you mean you're on min on the dip stick?
    Get in. Sit down. Shut up and hang on!
  14. #14
    Join Date
    Dec 2003
    Location
    Posts
    65
    Feedback
    0
    oil crisis
    hi - yes its pretty much minimum. The warning light came on randomly when i drove up on Friday then hasnt come on but the oil really is almost minimum. what do you reckon about mixing oil if i have to?
  15. #15
    has the BIGGEST Club Member penguin's Avatar
    Join Date
    Jan 2005
    Location
    (Top Secret)
    Posts
    5,214
    Feedback
    4 (100%)
    Quote Originally Posted by Batgirl
    can't see a problem with oil mixing if you have the correct type - i once used gtx magnetec (sp) was running low - had no problems with it (did over 400 miles before had the chance to change it for the good stuff )- no issues -BUT do change it when you have the chance!
    1993 Jspec Supra TT - Sold
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
