Results 1 to 1 of 1
Thread: How To: Refurbish electrical connectors
  1. #1
    I'm part of the furniture Club Member Ian C's Avatar
    Join Date
    May 2001
    Location
    England - East Anglia
    Posts
    15,114
    Feedback
    13 (100%)
    Technical How To How To: Refurbish electrical connectors
    With the constant plugging and unplugging of some connectors in the Supraís electrical system, be it the main ECU or the aircon controls or some other area you are modifying/troubleshooting, there can come a point where you start experiencing random and intermittent electrical connection faults.
    These can be a real pain to diagnose, but if you can get changes in behaviour of the troublesome electrical system just by prodding the wires where they go into the multiplug, chances are the pins are making a poor contactÖ
    The main place, and worst, to get this is the main ECU plugs. A word of advice is Ė if you go down this route of refurbing the troublesome pins, do every last one of them in the connector, otherwise youíll never know if youíve covered all the dodgy ones of not.
    The ECU connectors are different to most of the others scattered around the Supra. They have a water resistant rear seal and no locking bar on the plug, so getting the pins out is a tricky proposition.
    First off, the weather shield is a rubber sheet that is attached by tabs onto the connector housing. Use a small flat blade screwdriver to pop it out from these tabs. (see Plug weather shield tabs picture)
    Work the weather shield up the wiring loom. Be careful as you do this because the little yellow blanking plugs can pop out easily.
    Now you can see the back of the plug properly. (see rear of plug picture)
    The connectors are held in the plug by a locking tab situated on the bottom of the connector (see Connector locking tabs picture). To extract the pin you need to use a very small flat blade watchmaker screwdriver. You go in from the front of the plug, underneath the connector, and once itís in about 5mm or so (you wonít get it in any further), you need to push the locking tab up with the screwdriver whilst pulling the connector out by itís wire on the rear of the plug.
    (see removing the connector from the plug picture)
    Please note, the picture for this step isnít of the ECU plug, itís a spare bit of wiring loom I had kicking around because I wasnít going to pull my own ECU plug apart for shots I didnít take when I originally refurbed mine The principle is the same, and yes, you do have to hold the plug still, pull back on the wire, and prise upwards with the screwdriver all at the same time, while in the footwell of your car. It gets easier after 20 or so pins as you get the hang of it Hey, if I can take a photo while demonstrating the methodÖ
    Once the connector pops out, remove it from the rubber weather shield as well. Now youíll have a wire with a metal connector on the end. Needless to say, do one pin at a time otherwise youíll never know which pin goes back in which hole
    This connector is a box shape to house the pin on the ECU side of things. It also has a springy tab inside it that presses on the pin once itís inside the connector. (see Front of the connector picture)
    This is the bit that gets loose and causes the bad connection problems. You can check the state of a connector by pushing it onto a pin on the ECU. There should be some grip/drag on the pin, but not overly tight. You may well find some of them are extremely loose, and these are the problem onesÖ We are going to re-spring up the springy bit to fix that.
    Looking at the connector from the rear we can see the rear edge of the spring tab (see Rear of the connector picture)
    We are going to use the small watchmaker screwdriver to push on that rear edge and thus bow out the springy tab. This will close up the gap and make a good connection on the ECU pin again.
    Have the screwdriver blade at about 45 degrees from the springy tab as the small diagram top right shows (see Ajusting the springy tab picture). This stops the blade from slipping above or below the tab. Push on the tab with the screwdriver Ė the amount of force required is moderate. Check the connector visually afterwards, you are looking for a closed up gap (see Tighter connector picture). Test your gap on the ECU pin again, you should notice it grips far more than before.
    Push the connector back through the weather shield and into the ECU plug again. It will click home once itís all the way in. Itís difficult to line it up incorrectly or upside down as the natural set of the wire will drop it into place.
    Congratulate yourself on a job well done and move to the next of 80+ wires
    -Ian C
    Attached Images Attached Images
    I love my job. It pays for my Supra.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
