Autobox oil cooler lines and dipstick
Parm_93
 Share
  • 3 weeks later...
  • 2 weeks later...
Parm,
Note that T.T. fluid lines are 18mm longer than those on N/A. (Due to longer bell-housing for the larger torque-converter)
With some "tweaking", either can be made to fit, but don't look quite as "pretty" as using the correct lines.
Also note that T.T. and N/A transmission dipsticks have marks at different levels, using the wrong one results with incorrect fluid level.
Edited by David P (see edit history)
Parm,
Also note that T.T. and N/A dipsticks have marks at different levels, using the wrong one results with incorrect fluid level.
Thanks for that info David, were told they are all the same so clarification certainly helps.
Fingers crossed you pick up the parts I need!
 Share
