Looking for some OEM bits
nolizma
 Share
Still readily available from Toyota, also give TCB a try as they are often cheaper.
Try Paul at TCB - http://www.tcbparts.co.uk/contact_us.htm or Steve Manley [email protected] (https://www.inchcape.co.uk/toyota/) and ask both for a club discount.
Part numbers are below :)
Temperature (55905-14300)
RR-DEF (55905-14340)
REC/FRC (55905-14220)
AUTO (55905-14330)
OFF (55905-14320)
BLOW (55905-14310)
A/C (55905-14350)
FACE (55905-14360)
B/L (55905-14250)
FOOT (55905-14260)
F/D (55905-14270)
DEF (55905-14370)
These aren't cheap, bloody expensive actually - I bought a set in November 2017
55905-14200 - £5.98 + VAT
55905-14210 - £5.98 + VAT
55905-14220 - £5.15 + VAT
55905-14230 - £5.98 + VAT
55905-14240 - £5.12 + VAT
55905-14250 - £4.51 + VAT
55905-14260 - £4.49 + VAT
55905-14270 - £5.24 + VAT
55905-14280 - £5.12 + VAT
55905-14290 - £5.12 + VAT
55905-14300 - £7.10 + VAT
55905-14310 - £7.12 + VAT
I heard back from Steve Manley,
It is going to be 103 pounds for the ac buttons and knobs (according to Frank's part numbers).
I am a bit confused regarding the part numbers as frank's and rider's dont exactly match. Looking at the quote I got from Steve and the short descriptions next to the part numbers I am not sure if they are correct? It also seems a bit expensive as I can get a set from Australia on ebay for about 80 quid. Not including any import taxes though.
Yep, UK pricing doesn't surprise me. Try Amayama (https://www.amayama.com/en) despite what others say, many people, myself included always get an impeccable service from them. Sometimes you may have to wait a little longer than others for parts to arrive. Communication is spot on, usually a day to get a reply because of the time difference.
Also don't forget to factor in shipping, handling and import duty with any order you place. With the pound (£) gaining because of yesterdays election result it's also a good time to put in any orders as the prices will all be a little bit cheaper.
P.S.
Did you try TCB?
Edited by Frank Bullitt (see edit history)
Any luck on sourcing the spoiler/aero blade? Grams are making fibreglass and want a lot of money. I want the OEM rubber
/QUOTE]
The blade is plastic and doesn't take much to crack it/damage it
You could fit fibreglass and wrap in 3m clear tape which would help massively
/QUOTE]I had the fiberglass one from grams on my car. It broke when I hit a rabbit. When I removed it, it broke in two pieces.
Now if I manage to get another one I want to put some more time into figuring out how to fix it on the bumper, to make it as rigid as possible.
Sent from my F3211 using Tapatalk
  • 3 weeks later...
 Share
