HELP fitting new 272 cams
RZtwin
 Share
Correct me if I am wrong please!
This is what I'm still unclear about... After I have installed all the new seals, springs, retainers, locks and buckets do I, with T-belt off, put crank at -10 btdc so all pistons are slightly down, install new BC 272 cams, install cam gears, torque cams as per manual. Then turn crank clockwise to tdc notch, and turn cams to tdc notches too. Install t-belt?
Correct? Thank you!
Jay
Correct? Thank you!
Jay
You need to move your cams to tdc first before moving crank, otherwise your process is correct
- - - Updated - - -
Correct? Thank you!
Jay
 Share
