Heritage program: Poll for A80 Supra parts (Mods)
Jellybean
If Mods can accommodate?
As many are probably aware , Toyota North America has sent out a Survey regarding the A80 /70 Supra parts heritage program, I asked Toyota UK if they had any intentions of doing the same here
Toyota UK Replied
We were made aware of this email yesterday. We have no information about one being sent out in the UK, but we have been asked to do some research internally. Please let us know the top 20 parts you would like to see go back into production, and we will let the team responsible for the project here at Toyota UK HQ know
I think so of the top parts required
  • Steering Rack
  • Interior Panels
  • Door Cards
  • Suspension Arms
Categorise by
Engine / Fuel
  • Engine
  • Water pump
  • Radiator
  • Alternator
  • Starter
  • Intake
  • Exhaust
  • Ignition
  • Injection
Powertrain / Chassis
  • Transmission
  • Driveshaft
  • Axle
  • Wheels
  • Brakes
  • Steering
  • Suspension
Body
  • Doors
  • Windows
  • Bumper
  • Fuel tank
  • Interior
  • Seats
  • Handles
Electrical
  • Battery
  • Air conditioning
  • Lights
  • Audio
  • Airbag
  • Mirror
Could be a big poll...Do you think they just want to know those categories or actual parts? I mean - transmission, people only really want the 6spd boxes right?
I guess if we look at the four main categories, ask people what they'd like out of those categories then create a poll for each of those - count up the votes and send them off.
So if for the moment people work on creating a list of parts - don't duplicate, then we get to vote on the ones we want?
Something like this - copy and paste, add your own. (I've added Bens above to this ). :
Engine / Fuel
- VSV
- Engine Mounts
- O2 sensors
- Coil packs
- 6 spd box
- Suspension arms (all models)
Electrical
- Facelift post 96/97 headlights
Body
- Window trims
- Brake lines
- Fuel lines
Edited by Pete (see edit history)
Yes ; I was thinking of breaking down the Category (i.e.Powertrain / Chassis) into top 5 parts like Steering rack, suspension arms
I Presume these may become discontinued if we dont ask for them now
Engine / Fuel
  • Alternator 12V 90A
  • Gasket Overhaul kit
  • Crankshaft
  • Oil Pump
  • Water Pump
  • VSV
  • Engine Mounts
  • O2 sensors
  • Coil packs
  • Clutch Master
  • Clutch release cylinder
  • Steering Rack
  • Power Steering Pump
  • Brake Booster
  • 6 spd box
  • Suspension arms (all models)
Body
  • Rear Quarter windows
  • Window Trims
  • Front Door cards
  • Driver seat panel for electric windows (74231-14120)
Electrical
  • AC/Heater controller
  • Engine loom
  • Front lights
  • Rear lights
  • Heater Matrix (87107-14190,88501-14240)
  • Brake lines
  • Fuel Lines
Edited by Jellybean (see edit history)
Need to be smart about what we ask for, as there are a lot of after market parts which are good so not necessarily required from Toyota if we only have a finite list of parts we can have made again.
Things like glass headlights, likely to get broken or chipped, suspension arm's as no way to replace the ball joints. ECU's as the capacitors are slowly degrading over time.. Front windscreens, vsv's...
My 20 items would be;
Airboxes
Pre vvti cam covers
Aircon radiator/condenser
Gearboxes
Body panels/ repair panels
All exterior lights
Suspension arms
Quarter windows
Stock wheels (not sure if still available?)
All rubber coolant pipes and formed vacuum pipes (a number of pipes are now discontinued)
Fuel and brake lines
Dash panels
Engine looms
Engine undertrays
ABS Sensors
Heater Matrix
Steering Rack
OEM seat covers
Carpets
Diffs
Just to tidy up the thread
Parts request -- I want to focus on mechanical items to keep the cars on the road , no point having the ability to buy an Aerial if you cannot drive your car due to a discontinued heater core/Matrix
Lexus 300 and 400 , if I missed parts/incorrect let me know
No Point requesting cross compatible Lexus Items, not sure if they are only applicable to Facelift A80 Model, please let me know ; please no hearsay , if you are 100% sure
List I came across on here
front lower control arms - identical
front upper control arms - identical
front spindles - identical
front swaybar - identical
rear upper control arm (identical)
rear lower camber control arm (2 bushings 1 ball joint) (INCOMPATIBLE) Supra's are shorter and the sway bar link location is slightly different
rear lower toe control arm (1 bushing 1 ball joint) (INCOMPATIBLE)
rear lower traction link (1 bushing and mates to only bushing on spindle) identical
rear spindles - Not identical according to *******.
rear swaybar - Not identical but requires mkiv rear subframe mounts to be compatible.
brake lines - identical
calipers/rotors - identical
A80 LIST for Toyota (Discontinued Parts)
Items with no alternative but A80 OE -- you are at the mercy of trying to find good 2nd hand item
Mechanical
ABS sensors 89543-14020;89542-14020;89545-14010;89546-14010
Engine loom 82121-14800;89656-14010(earth);
Heater Matrix(Heater Core) -- 88501-14240 ; 87107-14190
Steering Rack 44250-14210
Rear lower control arms (shock and knuckle attach to) Discontinued 48730-14030;48740-14060
V160/V161 Gearbox 33030-0w212
V160/V161 Gearbox Gears & Bearings
  • 33370-0W010 HUB ASSY, SYNCHRONIZER, NO.2
  • 90069-10011 BEARING
  • 90069-10019 BEARING
  • Counter shaft assembly 33421-0W060 [ discontinued ]
  • 6TH gear Counter 33429-0W010 [ discontinued ]
  • 5th gear Counter 33428-0W030[ discontinued ]
  • 1st gear driven 33032-0W030[ discontinued ]
Non Essential
Rear Quarter windows 62720-14260; 62710-14260
Front Lights (Glass)
RHD Firewall Heat shield 55223-14030
Dash/Console Interior Panels
Center rear console 58911-14120-C0
Center rear console lid 58905-14080-C0
Center console front 58802-14060-C0
Driver front armrest panel 74231-14120
Passenger front armrest panel 74232-14110-C0
Front Door Pull 74813-14010-C0; 74814-14010-C0
Front Armrest 74210-14120-C0; 74220-14130-C0
Sun Visor 74310-14610-B0; 74320-14680-B0
Center Instrument Panel 55405-14120
Instrument Cluster 55420-14030; 55420-14030
Instrument Cluster No.2 55404-14510
Instrument Cluster Top 55410-14500
Cylinder Lock set 69005-14680 (Front doors, boor, ignition)
Front Door Handle 69210-14100; 69220-14110
Will add in the Non essential items when we have covered the Mechanical
If some of the parts above are not discontinued please let me know , I dont have time to check everything
To prioritise:
1) Rear lower control arms (shock and knuckle attach to) Discontinued 48730-14030;48740-14060
2) Steering Rack 44250-14210
3) ABS sensors 89543-14020;89542-14020;89545-14010;89546-14010
4) Engine loom 82121-14800;89656-14010(earth);
5) Heater Matrix(Heater Core) -- 88501-14240 ; 87107-14190
6) Center Instrument Panel 55405-14120
7) Instrument Cluster 55420-14030; 55420-14030
8) Instrument Cluster No.2 55404-14510
9) Instrument Cluster Top 55410-14500
10) Rear Quarter windows 62720-14260; 62710-14260; 62720-14270; 62710-14270
11) Rear Quarter panels 61611-1B120; 61612-1B090
12) V160/V161 Gearbox Gears & Bearings
13) RHD Firewall Heat shield 55223-14030
14) Center rear console 58911-14120-C0
15) Center rear console lid 58905-14080-C0
16) Center console front 58802-14060-C0
17) Driver front armrest panel 74231-14120
18) Passenger front armrest panel 74232-14110-C0
19) Front Door Pull 74813-14010-C0; 74814-14010-C0
20) Front Armrest 74210-14120-C0; 74220-14130-C0
21) Sun Visor 74310-14610-B0; 74320-14680-B0
22) Cylinder Lock set 69005-14680 (Front doors, boot, ignition)
23) Front Door Handle 69210-14100; 69220-14110
24) V160/V161 Gearbox 33030-0w212
25) Dash Console 55401-14500-C0
