Running lumpy (Fixed !)
mplavery
 Share
Hey peeps
So I’ve done a few jobs on the Supra over past few months
Done Spark plugs and coil connectors.. tested and ran fan after
Then done a oil and filter change
Ran fine after
Got it up on axle stands/ wheels off to clean inside out and out and to ACF-50 underneath..
Wheels back on and to the ground, started her up and let it warm up
About 5 min in it started running really lumpy
Notice a hissing noise, spotted a vacuum pipe split by the inlet manifold . Must of disturbed it when removing the filter
Worked for a few minutes but lumpy again
Replaced few more vacuum pipes but can’t seem to sort it.. might get it spot on for a minute or so then goes lumpy again
No doubt it’s a vacuum hose but struggling to see which one it is
Anyone else had this issue
I will have another look , might be the one under the manifold possibly.
Edited by mplavery (see edit history)
Just to update you guys it’s all sorted
Lee (SRD) said to try and disconnect the battery which I did over night.
Was 95% better
Then I cleaned the idle control valve following Geo how to guide here
http://www.mkivsupra.net/vbb/showthread.php?210956-How-To-Clean-Idle-Control-Valve-Cleaning-Aka-ICV-(IAC)&highlight=Idle+control+valve
Went for a spin, put new fuel on the tank as I only done about 100 miles this year and boom
Sorted
:cool:
 Share
