NA Running issues
evinX
 Share
Im getting these symptoms, changed out the ECU or a good condition one, could it be the code 42? not getting any codes come up or flash for that matter, i did the pink wire mod years ago, what else should i be looking at?
*NEEDLE SEEMS LIKE IT WANTS TO STAY AROUND 40MPHS SOMETIMES
*NO OVERDRIVE SOMETIMES
*OVERDRIVE LIGHTS DOES NOT WORK BUT MANU MODE DOES
*ODD TRANSMISSION GEAR CHANGES AROUND 40MPHS
*SLIGHT HUNTING IN PARK AT 1K REVS
*WHEN COLD USUALLY AT 1K REVS THE ENGINE OR EXHAUST THUDS
*WARM IDLE AT 800RPM IS FINE
This ones doing my head in
*GETTING UP TO SPEED OR DRIVING FAST + ACCELERATING HARD AT SPEED GIVES BACKFIRE/ EXHAUST POPPING -
DUE TO TRANSMISSION NOT CHANGING GEAR?
Have had new plugs last year, new distributor cap and arm this year, new distributor coil, did the waterpump and the timing is good, even on idle and driving it purrs fine most of the time. New Walbro GSS342 fuel pump. Spoke with Keron, another culprit seems to be a speedo converter
 Share
