Loads of Parts After Going Single
Cam27
 Share
I have a load of parts that I no longer need after going single, hopefully can be of use to someone.
Blitz BOV & joiner for stock location £40 *sold*
TT6 flywheel £80
Oem power steering lines and cooler £50 *sold*
GTE 100 amp alternator £50
GTE stock fuel rail, injectors and regulator £40
O2 (lambda) sensors x2 £15 each
HKS fuel cut defender (with original packaging, instructons etc) £40 *sold*
HKS EVC-S boost controller £90
TT6 pre vvti J spec ECU £250
Vacuum pressure tank £20
Oem MAP sensor £20
W58 shifter tripod £35
Sard radiator cap £10
Exhaust restrictor ring £8
Carbon coil pack cover, cut to fit with clear cam cover £50
New oem vacuum hose no.8 x2 (small 90 degree vacuum hoses down the back of vacuum hard lines) £10 each
Silicone GTE top radiator hose £10 *sold*
Oem fuel tank cover £80 *sold*
Water temp sensor £10
AC condensor £40 *sold*
Brake booster £30
New oem cam cover gaskets (pair) £15 *sold*
New oem rear crank seal £30 *sold*
New oem timing cover gasket set x2 £15 each *1 set sold*
New oem full set of valve stem seals £50 *sold*
New oem camshaft seals (pair) £15 *sold*
New oem GTE head gasket £100 *sold*
New oem full set of injector seals £30
I also have the hybrid turbos, pipework, vsvs etc but will make a seperate post for that.
I will try add any pictures that are missing later today.
Cheers,
Cam
Edited by Cam27 (see edit history)
 Share
