OsGiken Street Master Clutch Hard (GT2CD)
Jellybean
 Share
Car: 2JZ-GTE MTM 6 Speed
Mileage: 1000 KM or less
Price : 799 gbp
Everything is supplied for installation
Clutch:
- Brand: OS GIKEN
- Product: Street Master Clutch Kit - Twin-Metal Hard
- Part Num: GT2CD (TY031-BQ6)
- Rated to Approx 575 ft-lb (600 - 650 HP)
Additional Parts Supplied
- Movement Kit included.
- Sleeve release bearing included.
- OS Giken Flywheel bolts
Clear up any Confusion
The clutch is marketed as
Street master in JDM (Japan) ,
https://www.osgiken.co.jp/pro_clutch/clutch/gt2cd.html?fbclid=IwAR1wMK4dhTEeYyluDylWDyyqreSwVIeQI3GWlcfCiE5QwicgfzfOyvxToec
Grand touring in the US market (USDM)
https://osgikenusa.com/collections/clutch1/products/ty031-bq6?fbclid=IwAR2ot5yKp2nMUcfS2Xk4AjbMoRSeprBZVMvyfcEbIMrkGc0qJOT8FhUNWSo
Both have the same part number GT2CD (TY031-BQ6)
OS Giken Grand Touring Twin Plate Clutch for an V160 6-speed transmission on a 2JZ engine, type GT2CD. This model clutch uses OS Giken's special "floating pressure system" technology to make this a quiet, rattle-free twin plate clutch! This version also has a firm spring so pedal pressure is a little more then stock, but the power handling is rated at 600-650HP. This is a great street car clutch, with enough power handling for modified single turbo engines. This twin plate clutch/flywheel kit includes the movement alteration kit that changes it from a pull to a push type clutch.
https://www.driftmotion.com/TY031-BQ6-p/dm2563.htm?fbclid=IwAR2ot5yKp2nMUcfS2Xk4AjbMoRSeprBZVMvyfcEbIMrkGc0qJOT8FhUNWSo
Installation
she installs and uses all OEM components( i.e. OEM slave cylinder); first impressions on startup is noise, it is none existent on Idle , cruising and WOT . The Pedal has a really nice feel, sprung enough to allow easy modulation (Slippage) but light enough to not impede drivability , if I was to put a number versus stock 10% heavier pedal.
The biting point would be on par with OEM , slow speeds all smooth , not grabby; Just a pity it will not suit my power levels
To date I would highly recommend this clutch , car is a pleasure to drive and in comparison to an OEM clutch the feel on the pedal with this clutch in my opinion results in a nicer drive.
Ex Customs and VAT
Edited by Jellybean
More pics (see edit history)
  • 1 month later...
  • 2 weeks later...
  • 2 weeks later...
  • 4 weeks later...
  • 1 month later...
  • 3 months later...
 Share
