Results 1 to 6 of 6
Thread: Code 34
  1. #1
    What search button? Club Member ben_harmer32's Avatar
    Join Date
    Oct 2012
    Location
    England - West Sussex
    Posts
    1,294
    Feedback
    3 (100%)
    Code 34
    I've been getting error code 34 coming up when boosting the car (not all the time).
    Checked all VSV and vac lines and all seem good. The car has a boost controller fitted but it is not on.
    I went to my friends and using his Supra as a guide put all the vac lines back to stock and removed the solenoid for the boost controller. Still have the same issue.
    So decided to check the ECU and discovered my car doesn't have an FCD fitted (despite having a receipt for the part and for the fitting from the previous owner). I speak to him regularly and he was as shocked as me.
    I'm guessing/hoping the error code 34 is down to the stock boost cut? (Happens at around 15.8 psi which is essentially just over 1 bar) Car has double decat and a restrictor ring fitted.
    Does this sound about right? Should the car be running that much boost using the stock VSV's just from having decats?
    Thanks in advance!
    Attached Images Attached Images
    1st Supra = N/A Manual (Silver) - Killed by a drunk drivier - http://www.mkivsupra.net/vbb/showthr...-s-first-supra
    2nd Supra = Facelift TT auto (White) - Sold - http://www.mkivsupra.net/vbb/showthr...s-Second-Supra
    3rd Supra = TT Auto Aerotop (Silver) - Sold - http://www.mkivsupra.net/vbb/showthr...en-s-3rd-Supra
    4th Supra = N/A Auto Aerotop Fast and Furious Replica (Orange) - Sold - http://www.mkivsupra.net/vbb/showthr...rious-Replica)
    5th Supra = TT Auto (Silver) - Current toy - http://www.mkivsupra.net/vbb/showthr...1-My-5th-Supra
    PLEASE READ
  2. #2
    Do Luck owning Club Member Swampy442's Avatar
    Join Date
    Feb 2006
    Location
    England - Lincolnshire
    Posts
    14,477
    Feedback
    51 (100%)
    Normally you get a code 14 (ignition) if you've hit boost cut, not familiar with 34
    I would gladly pay you 10 to never log onto this forum again, and I am serious. Scott M
    Quote Originally Posted by Chris Wilson View Post
    I did terrible things to girls I had only just met, and they loved it.
  3. #3
    Join Date
    Oct 2012
    Location
    Posts
    1,294
    Feedback
    3 (100%)
    Quote Originally Posted by Swampy442 View Post
    Ah damn! I hate turbo cars lol
    PLEASE READ
  4. #4
    The Non-PC Club Member Frank Bullitt's Avatar
    Join Date
    Jan 2008
    Location
    (Top Secret)
    Posts
    4,819
    Feedback
    12 (100%)
  5. #5
    Join Date
    Oct 2012
    Location
    Posts
    1,294
    Feedback
    3 (100%)
    Thank you.
    Found this in one of the threads
    Quote Originally Posted by Ian C View Post
    Well that error code means you are overboosting as far as the ECU is concerned, you'll get it logged every time you hit fuel cut. If you reset the ECU and drive so you go on boost but don't go over say 0.8bar then check the codes again, you'll probably find the error isn't there. Hit 1.2bar then and recheck and it'll probably be back.
    -Ian
    PLEASE READ
  6. #6
    Join Date
    Oct 2012
    Location
    Posts
    1,294
    Feedback
    3 (100%)
    Hoping I found the issue. Plug to the waste gate vsv had a broken wire. Could have been barely holding on and fully snapped when I removed the plug causing a dodgy connection? But hopefully that'll resolve it. Will go for a test drive in a bit!
    PLEASE READ
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
