Aem ems series 2 2jzge BRAND NEW
Adamcole123
 Share
Selling this ecu as no need for it atm. Life calls for changes and need the money to help it along. Brand new. Never been out the box. Still got warranty seal on to show it’s not been used at all.
1300 but open to offers.
Not letting upload pictures but can email them over if needed :)
  • 3 months later...
Still for sale. Open to offers. Can send picture over but still not letting me upload of my phone.
AEM Series 2 Plug & Play Engine Management System for the 2JZ-GE Non Turbo Supra.
AEM's Series 2 EMS is a complete engine control system that plugs into the factory harness and uses the factory sensors. This means you do not need to replace any parts of the harness or sensors, just plug the EMS into the harness and begin tuning! The Series 2 EMS for the 2JZ-GTE allows you to control every aspect of your 2JZ. From VVTi to rev limit, timing, bigger injectors, boost control, nitrous injection, individual cylinder fuel and timing trims and for you drag racers there's even anti-lag! Get total control for your 2JZ-GTE with the Series 2 from our new tuning software - AEM Tuner.
Outputs
Injector Outputs 12 Peak & Hold
Coil Outputs 6
Selectable direct drive or 0-5V Coil Output Yes
Direct plug in, no jumper harness required Yes
General purpose LS outputs 11
General purpose HS outputs 2
Individual cylinder ignition trims Yes
Individual cylinder fuel trims Yes
High/Low speed fuel pump support Yes
Inputs
Trigger inputs (Ref/Sync) 4
Analog voltage inputs 14
Configurable Analog/RTD/Thermister inputs 4
Switch inputs 5
Lambda inputs 2x
Knock sensors 2
User adjustable knock sensor center frequency Yes
Communication
USB comms Yes
RS232 comms Yes
Communication cables included Yes
Fully enabled editing/logging software included Yes
CAN bus equipped Yes
RS232 datastream output 19 ch
CAN datastream output 32 ch
Communicates with AIM Dash/Dataloggers Yes
Communicates with Racepak Dash/Dataloggers Yes
DATA Acquisition
Internal data logging 1 MB
Maximum internal logging rate (per channel) 250 Hz
PC logging Yes
Data analysis using AEMLog Yes
Functions and Features
All channels/maps/tuning options unlocked Yes
Boost control Yes
Groundspeed based boost target Yes
Nitrous injection Yes
Staged injection Yes
Ground speed limiting Yes
Rate of Acceleration Control Yes
Overrun boost enhancement (anti-lag) Yes
Gear change ignition cut (shift-without-lift) Yes
Stepper motor idle control Yes
Password protected calibrations Yes
Fuel & Ignition rev limiters Yes
"In cockpit" global fuel trim capability Yes
Gear dependent shift light Yes
Evap/Purge function Yes
DC Motor control 2 Ch
Software definable "virtual" switch inputs 2
EGT Based fuel trims Yes
Maximum boost limit None
Basic automatic transmission control No
Advanced automatic transmission control No
Physical Dimensions
Length 203 mm
With 178 mm
Height 41 mm
Finish Black Anodized
 Share
