Urgent coolant help appreciated
swiftstu
 Share
Hi all,
Just on a long journey and notice my coolant reservoir is virtually empty.
I’ve found a Halfords: what coolant can I get from there please that would be suitable?
Do you refill at the reservoir at the front of the engine bay, or into the radiator please? The internet has confused me.
Thanks in advance!
When you've topped both up, run the engine with the rad cap off to help it bleed out any air, do it with the heater
on max hot, have some rags around the rad neck as coolant will bubble out, needs to be hot enough to get the stat to open
so around 80c, top the rad up and fit the cap
Check the pipe from the rad neck that goes to the reservoir is clear, also have a look at the rad cap, is it the original one ? they are a common cause of coolant problems,
Halfords might have one and its a cheap part to replace
 Share
