AGM Batteries
Jellybean
 Share
Had two Optima batteries , both died just out of the two year warranty ; they are on CTEK trickle charger
I am leaning towards the Yuasa ; the Exide has alot higher CCA
What do you recommended or what to avoid, it needs to be AGM as it in the cabin
it will not be used in a daily just a short blast now and then with minimum 6 month off the road
Brand Exide
Range Exide Start-Stop AGM
Voltage 12 Volts
Technology AGM
Capacity (C20) 50 Ah
CCA (EN) 800 A
Length 260 mm
Width 173 mm
Height inc. terms 206 mm
Guarantee 3 Years
Brand Yuasa
Product Code YBX9027
Range Yuasa YBX9000
Voltage 12 Volts
Technology AGM
Capacity (C20) 60 Ah
CCA (EN) 680 A
Length 242 mm
Width 175 mm
Height inc. terms 190 mm
Guarantee 4 Years
Got a Halfords one on my tt , been on now for 10 years, no problems , starts on the button, got a brand new Yuasa on my little daily , was flat after 2 weeks , work that one out ?
Daily was sat still while i had a chest infection, supra is sometimes left for months .
I have had 2 Oddessy AGM batteries die on me, both out of warranty. I used to keep them both on permanant trickle charge, but now only charge the third new battery once per week for 24 hours using the ctek on a timer. Holding charge just fine, I think the ctek gradually killed the other two
 Share
