Aerotop bolts coming loose
MrGRT
 Share
I would think it's just wear and tear at the age they are. Try cleaning the bolts and sockets up, if that fails get new bolts. That's all I can suggest I'm afraid, no doubt someone with more and better knowledge than me will come along with some better ideas.
I always found that using the OE wrench would never tighten them enough and eventually broke. For years ive been using a strong aftermarket wrench with the oe head. Tightens harder and un does the bolts easier to. Make sure you follow the tightening sequence as i had the bolt come unloose for weeks until i figured it out lol
Could you share the sequence? Didn't know that although I have tried different ones already. I am using an Allen key
  • 1 month later...
I think evinX wanted to post this here:
90901-09004
You need 2 of them. These rarely go bad and if the threads on yours are stripped then the captive nuts inside the roof have had it to. Which would mean...new roof panel and 2 new front bolts.
I've had my Aerotop about 10 years now and yes the front 2 are always coming loose unless you really tighten them (but do not overtighten them!)
Link here for bolt change and part number
http://www.mkivsupra.net/vbb/showthread.php?194788-how-to-change-front-aerotop-roof-bolts&highlight=AEROTOP+BOLTS
ChrisH, this was really helpful. I have changed the bolts now, hopefully don't have to change the roof panel like evinX mentioned.
Gotta take the car out and see
 Share
