Double Decat Question
KamaSupra
 Share
Hi,
Going to fit a decat pipe tomorrow, so my Supra will be double decated with a 1 bar restrictor ring fitted.
Will it need a fuel cut defender does anyone know or will it be ok as the restrictor ring is to 1 bar? I won’t fit it until I have a fuel cut defender if it’s going to cause any issues.
It’s a Jspec TT, thanks!!
You may struggle with sustained motorway pulls with the RR ring, mine doesn't make 1 bar with the RR in.
I would say you are ok with out the Fuel pump for 1 bar and below boost. I would however strongly recommend your future does involve a FCD, Fuel Pump and Boost controller as there is a noticeable difference between 1bar and 1.2bar
 Share
