Results 1 to 7 of 7
Thread: Underseal and Corrosion removal/Protection
  1. #1
    Work... what work? Club Member griffsplace's Avatar
    Join Date
    Sep 2016
    Location
    Scotland - Grampian
    Posts
    126
    Feedback
    0
    After being somewhat disappointed about the state of the underneath of my Supra and wanting to make it last another few years, last winter i set off to clean it up and treat it, rear end first. Having read that nearly every product is rubbish or completely brilliant depending on who you listened to.
    I though it would be good to have a thread where like-minded people who have done this can report back on any pros and cons, and update on any degradation over time.
    I opted for:
    Body
    Strip back to bare metal where possible
    POR-15 3 stage (degrease, metal prep, 2 coats of clear)
    Hammerite Stonechip
    ABRO rubberized undercoat for the inside of the wheel arches.
    Small clips fittings etc just had black smooth hammerite spray, or silver hammer finish over the POR-15
    Cavities injected with Dinitrol 3125
    So far its still on axle stands in the garage, but i have noticed, as i begin reassembling that there seems to be very poor adhesion between the por15 and the undercoat which is very disappointing, but i am just going to live with it.
    Attached Images Attached Images
    Silver 1995 N/A 5 speed j-spec
  2. #2
    Me? Post? Never! Club Member Annabella's Avatar
    Join Date
    Feb 2016
    Location
    England - Lancashire
    Posts
    2,209
    Feedback
    0
  3. #3
    Join Date
    May 2009
    Location
    England - Shropshire
    Posts
    2,459
    Feedback
    0
    I only completed my Supra rear end underside project 18 months ago so it might be a little soon to comment on durability but the parts treated and coated in POR paint then top coated in acrylic are all good. I still have some bits to tackle like the bit in the middle running between the sills and the tunnel which is where undersealed has been applied in the past and as that is lifting little by little then surface rust is usually exposed. I'm just sanding these little imperfections, treating, applying zinc primer and top coat black acrylic painting the imperfections as they show themselves. I have the car on my ramp a couple of times a year so as things become evident they get tackled. The good thing about having spent well over 100 hours on the underside is that now the inspection leads more to a wash down with a damp cloth to get the surface dirt and dust off those nice new parts than it does tackling rust.
    With the POR adhesion a lot may come down to the prep work, I've seen videos were people complain they have applied POR straight onto rust and its lifted a few years later. I did a lot of sanding and chemical treatment before applying the POR and only time will tell whether that helps with the POR adhesion over time. You mention poor adhesion to the undercoat of the POR paint. Is that correct as the POR is designed to be applied directly to the metal surface or treated surface? The POR dries to an aerated plastic film which is impervious to air and moisture from what I've seen and dissected from the dried drip runs I removed, so the POR paint probably prefers a rough surface to adhere to over a smooth surface.
  4. #4
    Helpful Club Member Scooter's Avatar
    Join Date
    Aug 2002
    Location
    England - Surrey
    Posts
    10,550
    Feedback
    44 (100%)
    I think the OP is talking about adhesion between the 'undercoat' ABRO stuff which has been applied 'over' the POR15 which I 'think' has adhered well?
    Number 8 ...........doing my best to keep
    Number 9 ........been and gone!
    Number 10 ........on its way
  5. #5
    Join Date
    Sep 2016
    Location
    Scotland - Grampian
    Posts
    126
    Feedback
    0
    Quote Originally Posted by Scooter View Post
    I am totally happy with the POR15, i did meticulously follow the instructions for prepping prior to application so i am hoping that at least the base layer is fine. It is the hammerite stonechip that i sprayed over the top seems to come off too easily where I am bolting things back together on top of it.
  6. #6
    I'm No.1 Club Member Burna's Avatar
    Join Date
    Feb 2005
    Location
    England - West Midlands
    Posts
    7,248
    Feedback
    14 (100%)
    94 UK Single, Paddle Shift, Black
    Quote Originally Posted by Supragal View Post
    Bunra is more dangerous. I'm drawn to danger.
    Quote Originally Posted by TrickTT View Post
    You did well to keep up, there are few things faster in this world than Burna on the way to a pub
  7. #7
    Join Date
    May 2009
    Location
    Posts
    2,459
    Feedback
    0
    Quote Originally Posted by griffsplace View Post
    I sprayed black matt and black gloss acrylic over the silver POR15 and that adheres fine. So you can buy a can of Simonize spray paint to cover over any parts where the Hammerite flakes off.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
