Page 5 of 8 FirstFirst 12345678 LastLast
Results 61 to 75 of 107
Thread: Big problems shock absorbers Bilstein B6
  1. #61
    Work... what work? Club Member
    Join Date
    Nov 2018
    Location
    England - Lancashire
    Posts
    118
    Feedback
    0
    Quote Originally Posted by Frank Bullitt View Post
    Why don't you just contact Chris Wilson, take your suspension to him and get him to look at it.
    http://www.mkivsupra.net/vbb/member.php?54-Chris-Wilson
    Who is he, does he have a garage or something?
  2. #62
    Office Monkey Club Member Iky's Avatar
    Join Date
    Apr 2010
    Location
    England - West Yorkshire
    Posts
    1,970
    Feedback
    32 (100%)
    Theres a little spacer type thing on top of the rod. Is this correctly fitted?
    Attached Images Attached Images
    STOCK BODY 1996 GUNMETAL FACELIFT TT AUTO BPU
  3. #63
    The Non-PC Club Member Frank Bullitt's Avatar
    Join Date
    Jan 2008
    Location
    (Top Secret)
    Posts
    4,777
    Feedback
    12 (100%)
    Quote Originally Posted by Johnm400 View Post
    Chris is found in deepest Shropshire in his garage or the pub. He is an authorised forum trader who has been the resident suspension development and geometry specialist forever. Call him on 07971-952084 or email him on chris@chriswilson.tv
    Don't PM him, he doesn't do PM's
  4. #64
    Join Date
    Nov 2018
    Location
    Posts
    118
    Feedback
    0
    Yes, that holds the bump stop to the top of the rod. Ive had it all apart and checked 3 times and the Bilstein dampers definitely lower to car by about 15mm when using the original springs so with lowering springs, the drop must be about 35mm
  5. #65
    Join Date
    Nov 2018
    Location
    Posts
    118
    Feedback
    0
    Ah i see, ill give Bilstein until next week to come back to me, if not ill contact him and see what he suggests. Thanks for the help!
  6. #66
    Join Date
    Nov 2018
    Location
    Posts
    118
    Feedback
    0
    Quote Originally Posted by Iky View Post
  7. #67
    What search button? Club Member Spunkmeyer's Avatar
    Join Date
    Aug 2011
    Location
    England - Cheshire
    Posts
    1,971
    Feedback
    8 (100%)
    Can you post up your actually ride heights to the underside of the outer edge of the arch for all corners. What profile tyre are you using also all corners
    Sorry if itís a repeat comment but are your sure the old springs are OEM supra parts
    Sent from my iPhone using Tapatalk
    2002 VVTi TT Auto BPU 202 Black - JM Supplied
    1996 TT Auto BPU 202 Black - Sold
  8. #68
    I'm addicted now! Club Member jonc's Avatar
    Join Date
    Nov 2005
    Location
    England - Devon
    Posts
    717
    Feedback
    4 (100%)
    Mate
    I forgot I was going to send you the numbers on my shocks which were supplied last year.
    fronts - 24-017930 followed by B46 1793
    This was an assembled front unit ready to fit. You can see the spring compressor fitted and the spring compressed so I could get the strut with OEM springs compressed to get the strut in place.
    IMG_20190130_203641 by Jon Christie, on Flickr
    I dont have a picture of the rears which shows the part number
    I got my sets from https://www.europerformance.co.uk/pa...sub_category=1
    Hope this helps
    JonC
    "living the dream"
    Supra VVTI TT Tiptronic
    MGZT 190
  9. #69
    Join Date
    Nov 2018
    Location
    Posts
    118
    Feedback
    0
    Quote Originally Posted by Spunkmeyer View Post
    Sorry if it’s a repeat comment but are your sure the old springs are OEM supra parts
    Will do when i get chance tomorrow night. Tyres are 35 profile. Theres deffo a drop of about 15mm from just changing the shocks from standard KYB to the B6's. I cant even get the trolley jack under to jack it up now and i wouldnt really bother but now i cant get over the ramp out of the garage without a major scrape.
    Springs are 100% OEM standard springs.
  10. #70
    Join Date
    Nov 2018
    Location
    Posts
    118
    Feedback
    0
    Quote Originally Posted by jonc View Post
    Mate
    http://www.mkivsupras.co.uk/imports/2019/06/90.jpgIMG_20190130_203641 by Jon Christie, on Flickr
    Hope this helps
    That shock in the pic is the rear mate.
    The part numbers are correct as ive checked with Bilstein. They sent me a diagram of the shock with measurements and all those are correct too. I can only assume that the Bilsteins do in fact lower the car a little and are designed to do so but adding lowering springs with them must give a fairly large drop as you get the lowering effect of the spring and the shock combined. This is all well and good but the reason i bought the Bilsteins was because i was under the impression they keep the standard ride height when using standard springs.
    Im also now in a catch 22 situation with the rears. I was going to buy the rears so they are all matching but the last thing i want to do is lower it at the rear too. I really could do with a 15mm sleeve that sits between the circlip and spring seat to lift it back to standard height.
  11. #71
    Join Date
    Nov 2018
    Location
    Posts
    118
    Feedback
    0
    Just to also add, the strangest thing happened when i jacked the car up. The spring was now tight with the weight off. It seems the rod does not extend as far straight after there has been weight on the car but when left overnight the spring became slack again so im not too concerned with the spring being slack anymore, its the lowering effect thats now bothering me.
  12. #72
    Join Date
    Jan 2016
    Location
    England - Norfolk
    Posts
    626
    Feedback
    2 (100%)
    https://www.fahrwerke-stossdaempfer....-b6-front.html
    Got mine here. Depending on the exchange rate, it worked out a bit cheaper this way. Delivery was only a couple of days. Paid €500 delivered for all 4
  13. #73
    Join Date
    Nov 2018
    Location
    Posts
    118
    Feedback
    0
    So the update on this is that the Bilsteins will lower the car by 15mm if you were using the original Toyota KYB shock absorbers. They only keep the standard ride height if you are swapping from factory Toyota Bilstein shocks. Supras with Bilsteins from the factory must of been 15mm lower than Supras with the KYB shocks unless the springs that came with the factory Bilsteins were different/longer?
    Bilstein say making a 15mm collar to sit under the spring seat wont work (ive no idea why not as surely any rise in the spring seat will also lift the car) and the only option is for me to return the shocks and have them machine a new groove into the shock body 15mm higher up and then fit another circlip for the spring seat to sit on.
    This has now become a PITA! Im sick of taking them off and putting them back on and now ive got refit the old shocks to send the Bilsteins back and await them altering them then refit them all over again. I also have the exact same problem facing me when i buy the rear shocks.
    I looked into just selling the Bilsteins at a loss to get some money back and then buying some coilovers but HSD say their coilovers will lower the car by 20mm on the highest setting so im assuming no coilovers will give standard ride height but ive also emailed BC Racing to see if their kit is the same. The only other option is air suspension so i can lift the car as i drive into the garage but i really do not want to go down that route.
  14. #74
    Do Luck owning Club Member Swampy442's Avatar
    Join Date
    Feb 2006
    Location
    England - Lincolnshire
    Posts
    14,409
    Feedback
    51 (100%)
    Buy a coil over kit for the JZS147 Aristo or Soarer, same shocks just longer
    I would gladly pay you £10 to never log onto this forum again, and I am serious. Scott M
    Quote Originally Posted by Chris Wilson View Post
    I did terrible things to girls I had only just met, and they loved it.
  15. #75
    Join Date
    Nov 2018
    Location
    England - North Yorkshire
    Posts
    123
    Feedback
    0
    If you want a lift spacer machining up let me know. I can turn one up on my lathe. Its practically the same as moving the groove for the clip.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
