Page 1 of 8 12345 ... LastLast
Results 1 to 15 of 112
Thread: Big problems shock absorbers Bilstein B6
  1. #1
    Work... what work? Club Member
    Join Date
    Nov 2018
    Location
    England - Lancashire
    Posts
    145
    Feedback
    0
    Sorry to start a new thread about Bilsteins again but im in urgent need of help. I have fitted one Bilstein B6 shock with OEM spring and the ride height increased. After closer inspection it seems i had the lower spring seat the wrong way around. The problem is, when i turned the spring seat to the right way and put everything back togather, the spring is now loose on the shock absorber when i undo the spring compressors. I bought these shock absorbers on the impression that i could use the OEM springs but the spring is too short when fully extended.
    Is there anybody that is using OEM springs with these Bilstein B6 shock absorbers?
  2. #2
    Helpful Club Member Scooter's Avatar
    Join Date
    Aug 2002
    Location
    England - Surrey
    Posts
    10,552
    Feedback
    44 (100%)
    Pics might help?
    Just to clarify you are removing the whole top mount, shock and Spring assembly from the car to swap over the new shocks?
    If so are you saying with the spring on the seat and the top mount on and retaining top nut done up the spring is slack.
    Number 8 ...........doing my best to keep
    Number 9 ........been and gone!
    Number 10 ........on its way
  3. #3
    Join Date
    Nov 2018
    Location
    Posts
    145
    Feedback
    0
    Quote Originally Posted by Scooter View Post
    Pics might help?
    Yes, exactly that. When reassembled the spring is loose. These are standard springs and ive double checked the part numbers and the shocks are the right part. The only way i can get the spring to sit firmly is by turning the lower mounting seat upside down but then the ride height is too high (as i complained yesterday) and the spring then does not sit properly on the mount.
  4. #4
    Do Luck owning Club Member Swampy442's Avatar
    Join Date
    Feb 2006
    Location
    England - Lincolnshire
    Posts
    14,484
    Feedback
    51 (100%)
    If the spring is loose its no big deal, when you have 1700 kilos of car on it, it will be fine
    I would gladly pay you £10 to never log onto this forum again, and I am serious. Scott M
    Quote Originally Posted by Chris Wilson View Post
    I did terrible things to girls I had only just met, and they loved it.
  5. #5
    Join Date
    Nov 2018
    Location
    Posts
    145
    Feedback
    0
    Quote Originally Posted by Swampy442 View Post
    I did think this and hopefully the shock absorber should never fully extend during driving unless im doing jumps? Ill just have to make sure that if i jack the car up in future that the spring does not turn relative to the mounts otherwise it wont seat correctly. Ill send Bilstein an email and see what they say.
  6. #6
    Join Date
    Nov 2018
    Location
    England - North Yorkshire
    Posts
    153
    Feedback
    0
    The spring should never be loose. It will fail an MOT like that as is not road worthy.
    Sent from my iPhone using Tapatalk
  7. #7
    Join Date
    Nov 2018
    Location
    Posts
    145
    Feedback
    0
    Quote Originally Posted by Andy Ven View Post
    So whats the remedy? The website clearly says you can use stock springs with the B6 shocks. They have some minor scratches on them now from fitting so i cant send them back and i cant buy lowering springs because the car wont go in the garage.
    Is there anybody on here using stock springs with these shocks?
  8. #8
    Join Date
    Nov 2018
    Location
    Posts
    153
    Feedback
    0
    Pictures would really help with this. Can you take a pic of the bits and we can work it out
  9. #9
    What search button? Club Member
    Join Date
    Jul 2016
    Location
    England - Derbyshire
    Posts
    1,340
    Feedback
    9 (100%)
    My mates used to cable tie them back in the day (when they used to cut the springs to lower their cars!)
  10. #10
    Join Date
    Aug 2002
    Location
    England - Surrey
    Posts
    10,552
    Feedback
    44 (100%)
    It's not loose on he car, just when off and reassembled.
  11. #11
    Join Date
    Nov 2018
    Location
    Posts
    153
    Feedback
    0
    On an mot test, the front and rear are lifted off the floor independently. And items such as springs, shocks and top mounts are checked. If the spring is loose its not safe. This why some top end suspension has two springs. One as the main coil spring and a then a ‘helper’ spring which is used to take up the slack and keep the springs correctly seated when the wheels are off the floor
  12. #12
    Join Date
    Nov 2018
    Location
    Posts
    153
    Feedback
    0
  13. #13
    Join Date
    Aug 2002
    Location
    England - Surrey
    Posts
    10,552
    Feedback
    44 (100%)
    Ah got you, I just can't imagine once fitted its loose even on the fully suspension drop, but it's really not easy to picture and something sounds odd re this.
    In my experience there is not much compression in the springs once off the car, ie you don't need compressors to reattach the shock top bolt and I've certainly never lifted back in a shock spring and top mount that's had a loose Spring, somethings not quite adding up?
  14. #14
    Join Date
    Nov 2018
    Location
    Posts
    153
    Feedback
    0
    Both supra’s i have owned have had aftermarket suspension so cannot comment on the standard spring compression. Pictures mean a 1000 words abd we need pics
  15. #15
    Join Date
    Nov 2018
    Location
    Posts
    145
    Feedback
    0
    I dont have pics as i didnt take any. Will have to get some tomorrow but just imagine the strut all built up as per normal and the spring not long enough to touch the top and bottom mount at the same time. Theres a gap of about 5-10 mm between the spring and seat, the spring is not under any tension at all.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
