Results 1 to 2 of 2
Thread: Low level clutch fluid sensor
  1. #1
    Metal Wide Arch 13J Club Member Noz's Avatar
    Join Date
    Nov 2010
    Location
    England - Devon
    Posts
    7,348
    Feedback
    100 (100%)
    Going to install one. My hydraulic release bearing failed so my fluid ran out without me knowing. Until it was empty.
    I can install my own sensor. I've found a non contact external fluid level sensor for through plastic measurements.
    But is there anything more oem available? Curious if any supra ever had this function.
    Brake fluid also.
  2. #2
    Trigger Happy Moderator Tyson's Avatar
    Join Date
    Aug 2010
    Location
    England - Derbyshire
    Posts
    9,282
    Feedback
    5 (100%)
    Quote Originally Posted by Noz View Post
    Brake fluid also.
    Well it already has a brake one so you could just tap into that for a stand alone one rather than the master warning light.
    Could you not use the same one for the clutch fluid ? They are both hydraulic systems so should work the same ?
    I can’t see that there is any Toyota with a clutch fluid level sensor from the factory.
    95' Black TT6 UK Spec . UK spec Supra register LINK if you have a UK spec send me a pm or post on the thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
