Wiring specialist needed - Open door indicator
Mgrene
 Share
Good day Forum.
Reallly hope that someone can give me some advised regarding this.
The “door open indicator” in the display and thereby also the interior dome light and key ignigtion light does not activate when I open the drivers door. It works fine with the passenger door and bootlid.
I have quickly checked the wiring behind the door sensor. I see there are three wires (red with white thread and two pink dots, red with black thread and two pink dots & white with black thread with two pink dots).
I have checked the wiring behind the display also and found nothing loose.
So instead of tearing the whole car apart (including removing the whole dash) I want to know if I can just run new wires from the sensor, og course it will require that I know where each color goes (assume one is for ground, positiv and signal to display or if I can run wires to the passenger side and plug into that circut ?
Anyone who knows what wire(s) behind the display goes to the drivers sensor?
 Share
