Page 1 of 2 12 LastLast
Results 1 to 15 of 28
Thread: Urgent help needed
  1. #1
    Snowboard Man Club Member cainhead's Avatar
    Join Date
    Dec 2005
    Location
    England - Greater London
    Posts
    627
    Feedback
    5 (100%)
    Urgent help needed
    Hello,
    Just on my way to visit my sister in hospital when I noticed the car seemed to be over revving. It wasn't too apparent until i pulled up to some lights and the car was revving to about 2500 on its own. I check the pedal wasn't stuck and it was fine. I managed to get the car to the hospital. The AFR shows 10 whilst its revving as I guess the extra throttle is making it inject more fuel. I disconnected the battery just to see if the ECU (AEM V2) was having a funny five minutes but when tried to start it again it nearly fired but didnt until i pushed down a little on the gas pedal. I cant see anything in the engine like a disconnected pipe or anything but have noticed a very slight coolant drip from the main pipe right behind and just about the block.
    Could it be the idle control? Im pretty stuck as I cant leave the car here and i live about 7 miles away.
    Any ideas very much appreciated.
  2. #2
    Me? Post? Never! Club Member
    Join Date
    May 2009
    Location
    England - Shropshire
    Posts
    2,384
    Feedback
    0
    I'd start with the Throttle Position Sensor. The link gives a procedure with screwdriver, ohm meter and feeler gauges to test it out. Here is an easy to follow video to check the feed and variable signal voltage from the TPS.
  3. #3
    Join Date
    Dec 2005
    Location
    Posts
    627
    Feedback
    5 (100%)
    Quote Originally Posted by rider View Post
    thanks for the link, thats a good start. Just a thought, is it common for this to just change mid drive?
  4. #4
    Join Date
    Dec 2005
    Location
    Posts
    627
    Feedback
    5 (100%)
    Just got the car home. Had a little look around and the throttle body and the the throttle stop lever (circled in picture) seems to have a lot of play. It spins and doesn't seem secure. I take it the throttle stop screw touches the lever pushing it down slightly when throttle is closed.
    I'll do the multi metre check in a second.
    Attached Images Attached Images
  5. #5
    Do Luck owning Club Member Swampy442's Avatar
    Join Date
    Feb 2006
    Location
    England - Lincolnshire
    Posts
    14,369
    Feedback
    50 (100%)
    You'd expect if it was holding revs at 2500 the AFRs would be at 14 odd, not 10, 10 is max boost full throttle stuff. Id say thats a start point
    I would gladly pay you £10 to never log onto this forum again, and I am serious. Scott M
    Quote Originally Posted by Chris Wilson View Post
    I did terrible things to girls I had only just met, and they loved it.
  6. #6
    Join Date
    Dec 2005
    Location
    Posts
    627
    Feedback
    5 (100%)
    Quote Originally Posted by cainhead View Post
    Quote Originally Posted by Swampy442 View Post
    Sorry I don't follow. Are you saying the AFR is reading wrong therefore sending the wrong signal to the ECU.
    - - - Updated - - -
  7. #7
    Join Date
    Feb 2006
    Location
    Posts
    14,369
    Feedback
    50 (100%)
    14 is the ideal fuel/air ratio, anything less than that, say 10 is rich, anything above that, say 16, is running lean.
  8. #8
    Join Date
    Dec 2005
    Location
    Posts
    627
    Feedback
    5 (100%)
    okay still pretty lost, the car starts really lumpy for about 10 seconds then smooths out and idles fairly normally, but AFR is constantly reading 10 until i blip the throttle and it rises to about 12 then goes back to 10. i connected the ecu to my tablet (standard aem software) and noticed with the engine off when i press the accelerator down the throttle percentage rises and falls as you would expect which says to me the ecu is getting a normal throttle reading.
    could the wide band sensor have gone? Why would the afr read as if im on full throttle/boost?
  9. #9
    Me? Post? Never! Club Member Style's Avatar
    Join Date
    Jul 2011
    Location
    England - Tyne and Wear
    Posts
    2,566
    Feedback
    6 (100%)
    Sounds like a sticky idle control valve. Cars just pissing in fuel as it has no air control and can’t hit its targets?
    '96 SZ-R 6 Speed.
    Whifbitz NA-T
    Project Thread Here
  10. #10
    Join Date
    Dec 2005
    Location
    Posts
    627
    Feedback
    5 (100%)
    Quote Originally Posted by Style View Post
    Sounds like a sticky idle control valve. Cars just pissing in fuel as it has no air control and canít hit its targets?
    yes its firing out black smoke whilst it trying to settle so its certainly seems to be over fuelling. Just found a guide to cleaning the IACV so ill try that first
  11. #11
    Join Date
    Dec 2005
    Location
    Posts
    627
    Feedback
    5 (100%)
    Managed to clean the IACV and no joy. It's there anyway to test these?
  12. #12
    Join Date
    Jul 2011
    Location
    Posts
    2,566
    Feedback
    6 (100%)
    Is the ECU showing anything for it when plugged in? I think it’s meant to make a clicking sound when you turn off the engine. Maybe see if you can hear it doing that to rule it in our out?
    '96 SZ-R 6 Speed.
    Whifbitz NA-T
    Project Thread Here
  13. #13
    Join Date
    Dec 2005
    Location
    Posts
    627
    Feedback
    5 (100%)
    Is the ECU showing anything for it when plugged in? I think itís meant to make a clicking sound when you turn off the engine. Maybe see if you can hear it doing that to rule it in our out?
    Not sure on the clicking my exhaust is pretty loud (hks ti) plus it's in my garage so doubles the echo. Car is really spluttering and firing out a lot of black stuff.
  14. #14
    Join Date
    Jul 2011
    Location
    Posts
    2,566
    Feedback
    6 (100%)
    o2 sensor may be on the way out like you say. I'm having a sort of similar problem y'see so it would be good to get to the bottom of it for both our sakes lol
    '96 SZ-R 6 Speed.
    Whifbitz NA-T
    Project Thread Here
  15. #15
    I can post! Club Member Sooty's Avatar
    Join Date
    May 2013
    Location
    England - Avon
    Posts
    82
    Feedback
    0
    Could be a stuck open injector - you should be able to test the injector outputs with the ecu software.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
