W58 gearbox + conversion parts
Josh42
 Share
Hi All,
- MKIV remote shifter W58 gearbox, complete with 2JZ bell housing, gearbox mount, reverse sensor and speed sensor. The box was rebuilt in May 2016, with all new bearings by Agency Transmissions.
- Clutch release fork and OEM release bearing (covered approximately 5k miles).
- RPS Max clutch with street disc. This has been fitted for circa 10,000 miles, however, it still has plenty of life and the friction disc is OEM Toyota and therefore is easily replaced.
- 2JZ OEM solid flywheel
- MKIV manual prop shaft
- Clutch slave cylinder
- Master to slave hardline
- Shifter (this will be the R154 shifter which will fit, but will sit slightly taller than a stock W58 shifter).
What’s not included to complete the conversion:
- transmission tunnel panel (available from Toyota)
- manual gear surround
- Clutch and brake pedal
- master cylinder
- bell housing bolts
Offers around £1200image
Very good box this drives lovely best of luck with your sale josh
/QUOTE]
Thanks Rob, it does drive lovely - in many ways actually feels better than the R154 replacing it!
Sent from my iPhone using Tapatalk
  • 4 weeks later...
  • 4 weeks later...
 Share
