Brake calliper pin grease
Glover
 Share
Stainless steel pins will stop you having to worry about grease getting on the friction surfaces. I see stainless steel pins :) And pistons...
Eventually I should be going down that route? Do you sell the items for this, and do you do an actual refurb service, 99% certain you’ll do a better job that I will!!
I make and sell stainless steel pistons for all Supra calipers as well as any others if I have a pattern piston tp look at. I also do stainless steel pad locating pins for the UK type Supra calipers. I also sell seal kits that do a pair of calipers, be they fronts or rears, Jap or UK spec. Whilst I will rebuild calipers I domn't want to get into show finish powder coating, all I offer is Kephos coating in satin black. It's what F1 used on suspension parts before most were made in carbon fibre instead of steel.
Do you have a pic of the finish Chris, kephos
 Share
