Part numbers for belts, tensioner etc
Thomas.B
 Share
Hi!
I will be replacing my cambelt, ac belt, tensioner and if there are other things that are good to replace at the same time?
Does anyone have the toyota numbers for the parts needed, would be greatly appreciated!
Found the following:
Engine Drive Belt tensioner (TT 6spd) 16620-46070
Engine Drive Belt tensioner (NA - TT Auto) 16620-0W025
Thanks! :)
Edited by Thomas.B (see edit history)
Hi,
Depends how far you want to go on replacing parts, but I'd be putting on a new water pump while I had access, and also inspecting the crank pulley for signs of the rubber splitting and replacing it if neccessary, then a new pulley bolt, cam cover gaskets etc.
For part numbers I use japan-parts.eu see link below. It's fairly straightforward to use, you can change/ select the variant of your car in tabs towards the top of the page.
http://japan-parts.eu/toyota/eu/1994/supra/jza80r-ajpvzw/3_291230_009_/tool-engine-fuel
 Share
