Members banned from this thread: RobD, ray007, suprageek, zach42o1, Caesard, msmile, Reyft, Sausage and Dzowani
Results 1 to 13 of 13
Thread: 1993 Toyota Supra Aerotop V160 6 speed Single turbo 2JZ-GTE
  1. #1
    Me? Post? Never! Club Member Hitbox Junkie's Avatar
    Join Date
    Apr 2013
    Location
    England - Dorset
    Posts
    3,031
    Feedback
    4 (100%)
    Make: Toyota Supra Aerotop Black 202
    Model: 6Speed, Single Turbo Aerotop
    Year:1993
    Facelift: no
    Mileage: 110485 KM
    MOT remaining: 20th February 2019, ( it is going to SRD and will have a Fresh MOT )
    Service history: I bought this car as a non running shell and did not have any service history. It has been built at SRD and I have all the invoices from when i took the car, It is going in for its service with its mot in February.
    Car's location: Poole/Bournemouth
    Modifications: built from a NA AUTO aerotop shell to a 6speed (V160), Single Turbo 2JZ-GTE, UK Spec Auto Big case Diff with UK Spec brakes all round running EBC redstuff brake pads and EBC brake discs. Fully flocked interior
    Good bits: Built by SRD its ready to take and has been reliable.
    Bad bits: could do with audio being set up for it, Comes with a android head unit, needs front speakers. age related paint marks on the car. Paint does come up very well when cleaned and polished. previous person with the dash cut the middle bit to fit a double din and didn't do a very good job.
    PRICE: 32,000 offers welcome.
    Please PM for contact details.
    Project Thread: http://www.mkivsupra.net/vbb/showthr...Aurora-(PICS!)
    Spec:
    Body: 1993 Areotop NA Auto
    Engine:
    Boost logic manifold
    Precision 67 dual ball-bearing turbo
    3.1L 2JZ-GTE stock block, rebuilt by SRD becuase it was in a bad state when we opened it at srd .
    1000cc Apr injectors
    Gates Racing fanbelt
    Nur Sepc R exhaust
    Bore size: 87mm
    Running larger bearings
    The big ends are stock size
    Wiseco pistons
    Spool rods
    stock head thats been machined with Crower cams 264s
    ECU:
    Syvecs S6
    Sensors and Harness
    Toucan Display Unit
    Drive Train:
    6 Speed conversion getrag V160
    AUTO LSD
    Suspension:
    Chris Wilson suspension setup (I don't know specifically)
    Wheels:
    Volk Racing GTS wheels made by Rays Wheels
    UK Brakes with braided lines
    Parana front discs with ebc redstuff brake pads
    Mtec rear discs with ebc redstuff brake pads
    A list of all the bits that have been done in 2016 til late 2017 when it was finally completed and driving on the road.
    Skimmed block
    Oil squitter delete
    Toyota engine gasket kit Jspec
    Head work, Clean grind valves, cut valve seats, skim 0.006 Reshrim valve clearances
    Toyota Oil Pump OEM
    Toyota Core plug block 35mm
    Toyota water pump 2jz OEM
    Toyota Oil filter housing O ring
    Toyota modine O ring Large
    Toyota thermostat
    Toyota Locking Nut
    Toyota Oil filter
    Gates Kevlar Racing Belt
    Toyota Timing Belt Idler Wheel
    Paint/ and materials
    SRD Rebuilt 100amp alternator
    Toyota Coil Pack Connectors No wires
    T4 Divided Turbo Gasket
    Toyota Locking Nut
    Studs For Turbo
    Toyota PVC Grommet
    SRD Turbo Water Line Kit
    Top Water Neck Mod for single Turbo
    Used Toyota Timing Pulley
    Used Toyota Crank Pulley
    Bearing for Aux Pulley 2jz
    SRD Boost Solenoid Bracket
    Boost controller solenoid
    K&N Filter for IAVC
    Cam Breather Hose and covering
    Bosch Knock sensor for syvecs
    Thermal Sleeve and heat covering
    SRD Heater Matric Hose Kit
    Syvecs Pressure sensor loom and Pug
    Vac Hoses
    Toyota 5sp Flywheel Bolts
    Aux Belt 6PK1938 Stock 2jz
    Toyota PS Air Valve
    Precision V Band Clamp
    SRD E85 Safe Fuel system Lines and fittings -8 Feed, Billet -8 high flow fuel filter, Y Piece, Twin -6 Feeds to rail, -6 return from rail to FPR, -6 Return to tank.
    Billet roll over valve and all Teflon lines with fittings
    Air con Service
    SH77mm Hose joiner Black
    Horn Hi note
    Horn low note
    Walbro 450/485 in tank filter
    Bonnet cables and catches
    Fuel pump relay and plug
    SH100mm Hose joiner
    All bumper fixings, bars, seal and number plate surround
    HKS Blanking cap pair 10mm
    Tyre fitting and balancing
    Toyota uk spec read disc
    Full uk spec brake rebuild includes all parts paint and stickers
    Brake pads UK spec front
    Brake pads UK spec rear
    Battery for supra
    Used Toyota master brake cylinder 2 port
    Prestone AF Premix
    Millers CRO10w40 Running Oil
    brake lines an fittings for master cylider
    Toyota Diff Bush 1 bolt
    R453 Fog light Bulb
    Toyota Rear brake pipe T Piece non ABS
    Toyota Front to B brake pipe non ABS
    Toyota Rear brake pipe NS no ABS
    Toyota rear brake pipe OS no ABS
    Toyota Read brake pipe clamp
    SRD Alloy Expansion Tank
    Toyota UK Spec shim kit front
    Toyota UK Spec shim kit rear
    Toyota brake pins front
    Toyota brake pins Rear
    Toyota UK Spec anti rattle spring rear
    Clear side indicators
    Toyota UK spec AR Spring front
    Number plate Large JAP
    Bride RO Rail JZA80 L
    Bride RO Rail JZA80 R
    Toyota Washer Jets
    LL Remote locking
    Used Wiper arm set
    Bosch 21"wiper with spoiler
    Bosch 20" wiper
    Toyota over flow cap assembly
    Toyota bonnet seal rear clip
    Dipped and main bulbs
    Black car matts
    Used Toyota ECU Cover
    Petrol
    Used Drivers Door Card
    Used Toyota Brake light switch
    Parts for rear fog light
    MOT TEST
    Syvecs 3.5 bar to NPT
    SRD Toucan Mount Plate
    Toucan Display
    Toyota Oil Pump OEM
    Cleveite bearing set 2jz
    Toyota FMS
    Toyota oil strainer gasket
    Toyota oil filter large
    DEI T4 Titiaum heat shield
    Millers CFS 10w60NT +
    Running in mineral oil
    Restone AF Premix
    Harness adaptor Toyota PC2-174
    Mapping & Dyno time
    Toyota Boot rubber stop
    Toyota Boot rubber screws
    Toyota 6sp shifter Cradle
    Toyota 6sp shifter lower bush
    Toyota 6sp shifter lower bush O ring
    Toyota 6sp shifter seat
    Millers CFS 10w60 5Ltr
    Toyota Oil filter large
    Toyota Drain plug gasket
    Toyota V160 Cover NS
    Toyota V160 Cover OS
    MOT TEST
    2JZ head with Crawler Cams
    HKS Twin plate clutch
    - - - Updated - - -
    reserved for pictures
  2. #2
    Join Date
    Apr 2013
    Location
    England - Dorset
    Posts
    3,031
    Feedback
    4 (100%)
  3. #3
    The indecisive Events Organiser drift_bear's Avatar
    Join Date
    Jul 2009
    Location
    Scotland - Grampian
    Posts
    11,264
    Feedback
    16 (100%)
    No way! Didn't think you would actually go through with this dude Being 25 i would offer it up to the US market for that price as it would be snapped up i think
    1995 - Deep Jewel Green Pre-facelift TT Auto - At Last
    "Dude I Almost Had You" Paul Walker 1973 - 2013
  4. #4
    Join Date
    Apr 2013
    Location
    England - Dorset
    Posts
    3,031
    Feedback
    4 (100%)
    Quote Originally Posted by drift_bear View Post
    Not sure how to offer it to the us market, and yeah not a easy decision but I would like to free up the money in this to buy a property as they are so expensive and see what other cars to buy.
    No rush to sell though.
  5. #5
    I'm addicted now! Club Member
    Join Date
    May 2016
    Location
    England - Bedfordshire
    Posts
    533
    Feedback
    2 (100%)
    I know the feeling, in March I'll be selling my bone stock TT to fund a house purchase.. wish I didn't have to, but it's the only way
    1994 Stock TT Supra & N/A 5 soon to be NA-T 6 speed
  6. #6
    TT Tiptronic Club Member MRX's Avatar
    Join Date
    Nov 2004
    Location
    England - Dorset
    Posts
    2,118
    Feedback
    10 (100%)
    Shame you have to sell mate as i know how much has gone in to this build, but good luck with the sale!
    - Rob -
    Quicksilver TT Tiptronic
  7. #7
    😎 SUPRA FOREVER 👍 Club Member FAMILY MAN's Avatar
    Join Date
    May 2013
    Location
    Northern Ireland - County Antrim
    Posts
    190
    Feedback
    0
    Good luck with the sale , car is a cracker great build
    THE FAMILY MAN .
  8. #8
    Join Date
    Apr 2013
    Location
    England - Dorset
    Posts
    3,031
    Feedback
    4 (100%)
    Quote Originally Posted by FAMILY MAN View Post
    Cheers dude.
  9. #9
    Me? Post? Never! Club Member Style's Avatar
    Join Date
    Jul 2011
    Location
    England - Tyne and Wear
    Posts
    2,471
    Feedback
    6 (100%)
    Quote Originally Posted by Hitbox Junkie View Post
    JM Imports should be able to export the car for you. They may even be able to advertise it. If you're on Instagram or something then that might be a good place to start with just reaching out to US followers
    '96 SZ-R 6 Speed.
    Whifbitz NA-T
    Project Thread Here
  10. #10
    What search button? Club Member K's Supe's Avatar
    Join Date
    Oct 2014
    Location
    England - Greater London
    Posts
    1,329
    Feedback
    2 (100%)
    No way! You spent years finding a car and getting it to this stage. Big shame mate. Glws. Being that our cars are quite similar spec, I will be very interested to see what this fetches
    Sent from my iPhone using Tapatalk
    1993 Aerotop 6 Speed Single
    Follow me on Instagram @bayside_supra
  11. #11
    Posting is my life! Club Member evinX's Avatar
    Join Date
    Sep 2009
    Location
    England - Northamptonshire
    Posts
    6,166
    Feedback
    29 (100%)
    WOW. Shocker to say the least. After all that graft!
  12. #12
    Join Date
    Apr 2013
    Location
    England - Dorset
    Posts
    3,031
    Feedback
    4 (100%)
    Quote Originally Posted by K's Supe View Post
    Quote Originally Posted by evinX View Post
    Yeah its not a light decision, in no rush to sell but at the same time I'd like to have the money to now go into a property.
  13. #13
    Join Date
    Apr 2013
    Location
    England - Dorset
    Posts
    3,031
    Feedback
    4 (100%)
    Fresh MOT no advisory's, now just having service etc so will be back with me hopefully at the weekend.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
