Results 1 to 12 of 12
Thread: Speaker noise in time with revs
  1. #1
    Helpful Club Member Scooter's Avatar
    Join Date
    Aug 2002
    Location
    England - Surrey
    Posts
    10,258
    Feedback
    44 (100%)
    OK, I have had a low pitch whine from my car stereo that was only really noticeable with the volume down and I noted it was in time/tune to the revs.
    This morning I was in traffic on the way to work and it suddenly changed to being very loud, so loud that initially I thought the car had an issue to the point I'm pulled over in the engine bay blipping the throttle etc trying to see if the alternator or fan were whining. I heard nothing and sitting back in the car it was as loud as ever and I thought this isn't right as normally worrying noises inside are louder when out of the car/nearer the source. Anyway the penny dropped and I tried switching the stereo off and all was good (should never have doubted the old girl!)
    Anyway some google research gives the following. Now since I've not heard of issues before on here and the fact that it's got worse over time is there anything specific I can look at re the alternator, wiring grounding etc? any simple tests? My plan was to try the car without the belt or with the alternator disconnected to verify it is the culprit.
    Any advice if it is?
    "Speaker Whine From Alternators
    One of the most common causes of speaker whine comes from the vehicle’s alternator. If the noise changes in pitch or intensity when the engine RPM changes, then it’s a safe bet that you’re dealing with some type of engine noise, and interference from the alternator output is a likely source.
    "The issue at hand is that noise from the alternator is getting into your head unit via the power cables. You can deal with the problem in one of two ways:
    Install a noise filter between the alternator and the battery
    Install an inline noise filter in the head unit power cable
    In either case, the alternator will still be "generating noise" but it won’t be able to get into your head unit and cause the speakers to whine."
    Number 8 ...........doing my best to keep
    Number 9 ........been and gone!
    Number 10 ........on its way
  2. #2
    Did somebody say carbon? Club Member Ric's Avatar
    Join Date
    Jun 2006
    Location
    England - South Yorkshire
    Posts
    9,340
    Feedback
    34 (100%)
    Bad grounds usually.
  3. #3
    Join Date
    Aug 2002
    Location
    England - Surrey
    Posts
    10,258
    Feedback
    44 (100%)
    Cheers, fits with getting worse if the corrosion/connection has gone worse in time? just for a numpty we are talking the engine bay ones, or could it be behind the dash/stereo?
  4. #4
    Join Date
    Jun 2006
    Location
    Posts
    9,340
    Feedback
    34 (100%)
    Quote Originally Posted by Scooter View Post
    Ground for the alternator, battery, and stereo are where i would start but I've never experienced the problem myself on the supra.
  5. #5
    Join Date
    Aug 2002
    Location
    England - Surrey
    Posts
    10,258
    Feedback
    44 (100%)
    No worries, I'll start in the engine bay where I'm more familiar and hope that sorts it, thanks for the input.
  6. #6
    I'm part of the furniture Events Organiser Al Massey's Avatar
    Join Date
    Dec 2006
    Location
    England - Yorkshire
    Posts
    12,668
    Feedback
    62 (100%)
    Do you have an amp fitted?
    TRD widebody in need of carbon
  7. #7
    Join Date
    Aug 2002
    Location
    England - Surrey
    Posts
    10,258
    Feedback
    44 (100%)
    No, but the noise was definitely from the alternator as it failed on the way home from work tonight! AA to the rescue, my first ever Supra call out, so listen out for that in the future everyone.
  8. #8
    Join Date
    Dec 2006
    Location
    England - Yorkshire
    Posts
    12,668
    Feedback
    62 (100%)
    I was just wondering as you can also get these symptoms if an amp power cable is too close to speaker wires, it will cause an interference.
  9. #9
    Join Date
    Aug 2002
    Location
    England - Surrey
    Posts
    10,258
    Feedback
    44 (100%)
    Ta, it seems like the alternator has been dying a slow death for some time as the interference has been there for a while (wish I'd googled it back then) but didn't bother me, then on the way to work it literally jumped in volume (so much so at first I thought something on the car had broke/seized etc) which must be when it completely gave up, from then on I was simply draining the juice from the battery until breakdown.
  10. #10
    Join Date
    Aug 2002
    Location
    England - Surrey
    Posts
    10,258
    Feedback
    44 (100%)
    Ok inspired by this video I am going to try and replace my bushes, given the seemingly gradual demise of my (25 year old) alternator I'm suspecting the brushes?
    https://www.youtube.com/watch?v=I1vcdoP3PRQ
  11. #11
    Join Date
    Aug 2002
    Location
    England - Surrey
    Posts
    10,258
    Feedback
    44 (100%)
    Just to conclude I got some bushes and a regulator for £35 to repair mine but then saw and got a refurbed alternator from Germany eBay seller woospa for about £100. That's now on and a trip to Poole and back completed fine this weekend. I will attempt the refurb now on the original one, I may need a rectifier too which seem to be available from America only, this will be another £60 or so.
  12. #12
    I'm addicted now! Club Member Harrypm82's Avatar
    Join Date
    Jan 2013
    Location
    England - Greater Manchester
    Posts
    968
    Feedback
    1 (100%)
    Let us know. Mine does this with the alarm siren in the engine bay but only when the window buttons are pressed or the rear window heater is turned on. Strange
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
