Results 1 to 12 of 12
Thread: how to remove door weather strip
  1. #1
    learned the hard way Club Member renegade's Avatar
    Join Date
    Dec 2006
    Location
    Scotland - Grampian
    Posts
    251
    Feedback
    0
    what all has to be done to remove the door weather strip. does it just pull off? is there any screws
    Never Underestimate the intelligent of Stupidity
  2. #2
    Work... what work? Club Member P_Bazz's Avatar
    Join Date
    Dec 2012
    Location
    Netherlands
    Posts
    200
    Feedback
    3 (100%)
    Lower the windows and pull off the door cards, there are two screws that hold them to the door. Be sure to use the right size screwdriver as they will easily strip and you cannot replace them with normal bolts as they will hit/scratch the glass when going up and down. Another method is to make a notch with a small chisel and carefully hammer them in a anti-clockwise fashion if they do happen to strip. (Part no. 90154-60027)
  3. #3
    Join Date
    Dec 2006
    Location
    Scotland - Grampian
    Posts
    251
    Feedback
    0
    I have the new parts75720 and 75710. so take door cards off then?
  4. #4
    Join Date
    Dec 2012
    Location
    Netherlands
    Posts
    200
    Feedback
    3 (100%)
    Quote Originally Posted by renegade View Post
    Exactly. The part no. I mentioned was for the screws. Don't try and push the weatherstrips down to hard either, they always stick up a little bit. Just match them with the trim part on the rear quarter windows in height.
  5. #5
    Silent lurker... Club Member Rob W's Avatar
    Join Date
    Nov 2003
    Location
    England - Kent
    Posts
    1,403
    Feedback
    19 (100%)
    Yes remove the door card. 2 screws holding them on, 1 at each end IIRC.
    95 J-Spec TT BPU+
  6. #6
    Join Date
    Dec 2006
    Location
    Scotland - Grampian
    Posts
    251
    Feedback
    0
    got the drivers side done. other side not so good screws not moving put lots of wd40 on not sure if they will come out whole.
  7. #7
    Work... what work? MEMBERSHIP EXPIRED
    Join Date
    Aug 2017
    Location
    South Africa
    Posts
    353
    Feedback
    0
    Can you post a photo of the screw pls? Someone?
  8. #8
    Join Date
    Dec 2006
    Location
    Scotland - Grampian
    Posts
    251
    Feedback
    0
  9. #9
    Join Date
    Dec 2006
    Location
    Scotland - Grampian
    Posts
    251
    Feedback
    0
    got it out had to use centre punch
  10. #10
    Me? Post? Never! Club Member mwilkinson's Avatar
    Join Date
    Apr 2006
    Location
    England - Hampshire
    Posts
    4,366
    Feedback
    59 (100%)
    I've had the horror of those screws in the past. Ended up having to drill one out. Glad the punch worked for you.
    1996 Facelift J-Spec 6spd Single Turbo (600bhp) - Gunmetal
    Sold - 1995 Jspec 6 Speed Manual BPU (Lambo Grigio Avlon)
  11. #11
    Posting is my life! Club Member evinX's Avatar
    Join Date
    Sep 2009
    Location
    England - Northamptonshire
    Posts
    6,219
    Feedback
    29 (100%)
    All you gotta do is get a fitting phillips. Give them 2 good hits with a deadblow to 'crack em' and they come out normally.
  12. #12
    Wanting more carbon Club Member The Raven's Avatar
    Join Date
    May 2007
    Location
    England - Kent
    Posts
    11,300
    Feedback
    26 (100%)
    Out of interest how much where the parts
    Dr Jekyll
    dun worry bra. i dont insure my car either , they r all prooer muppets on ere
    We all know this is true
    'Theres nothing worth doing to an NA apart from setting fire to it'
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
