Apexi power FC d-jetro help
Goga
 Share
Hi all,
Just needed some expert advice on the following.
I am looking to do a digital dash conversion on my mk4 supra 1994. Now it currently has obd1 port but i tried a o d1 to obd2 converter with no luck.
I guess the question is can i get readings like speed, oil temp, water temp etc from the apexi power fc? If so what is required to extract these readings?
Thanks
Edited by Goga (see edit history)
Well the hand held Commander show these but whether the data format is proprietary or a common format I do not know. I would guess that finding out, capturing it and using to drivve a digi display could be possible, but well over my head. CanBus data is bad enough to extract, convert and use. if you could find out the data format it would be a big help, but is it worth it when you can buy a different ecu that will drive a digi dash directly?
The Apexi was OK in its day with a dedicated ECU for manual TT's but it's very outdated now and prices of better ECU's have fallen. Whilst I consider MOTEC the pinnacle taking reliability, features and most of all SUPPORT and number of competent MAPPERS into account, you will find the LINK ecu's exceptional value for money.
 Share
