Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 43
Thread: Car sat for 5 years - My plan / Suggestions welcome
  1. #16
    The Non-PC Club Member Frank Bullitt's Avatar
    Join Date
    Jan 2008
    Location
    (Top Secret)
    Posts
    4,593
    Feedback
    12 (100%)
    Quote Originally Posted by Harris25 View Post
    Ok trying to have a look at the brakes and fell at the first hurdle. For love nor money can not get the pins out to release the pads.
    I've give then a good dose of penetrating lube but they still will not budge.
    Any guru advice? Or am I resigned to cutting them?
    They will have rusted in place, carefully cut them out and replace them with CW’s superior S/S versions.
  2. #17
    Work... what work? Club Member
    Join Date
    Mar 2006
    Location
    England - South Yorkshire
    Posts
    404
    Feedback
    0
    Ye thought so. Already spoke to Chris about a kit. Wanted to check the pistons first tho. Thanks
  3. #18
    Join Date
    Jan 2008
    Location
    (Top Secret)
    Posts
    4,593
    Feedback
    12 (100%)
    No problem, you can’t go wrong with CWs kit.
  4. #19
    Helpful Club Member Scooter's Avatar
    Join Date
    Aug 2002
    Location
    England - Surrey
    Posts
    10,257
    Feedback
    44 (100%)
    The only things you can try on the brakes is trying to get something behind the mushroom/dome head of the pin. If you have some pliers like you use to snip bathroom tiles, you can pop each side over the dome and clamp down forcing the plier teeth into the space behind. With luck the teeth taper pull the pin out a tiny bit, if it does move you can try other levers, also you could grind the middle section to give flat sides that you could then mole grip and try and rotate as you also try and slide them.
    But if you have tapped/hammered the non domed end already you may have splayed/flared the end too much and it'll never come through in which case skip to the drill
    Number 8 ...........doing my best to keep
    Number 9 ........been and gone!
    Number 10 ........on its way
  5. #20
    Join Date
    Jul 2015
    Location
    England - East Anglia
    Posts
    176
    Feedback
    0
    Good thread. Nice to hear about one 'coming back from the dead' for a change
    Former GTR owner....... Nobody's perfect
    96 TT Auto RZ-S
  6. #21
    Join Date
    May 2015
    Location
    England - Surrey
    Posts
    299
    Feedback
    0
    If you have the time I would persist with the normal freeing options - Plusgas, WD40, heat etc. A good drift of the right dimension is good too. I had this on a Merc once and got there eventually. Good luck.
  7. #22
    Join Date
    Mar 2006
    Location
    Posts
    404
    Feedback
    0
    Thanks for the advice but as Scooter said. I have flared one of them. Irrelevant to that though they do not want to move with as much heat and lube prior to excessive elbow grease. Im resigned to getting my cut on and ordered a drill bit as I did not have one the right size.
    Nothing ventured nothing gained
    So long and thanks for all the fish
    1994 RZ TT BPU 6speed Manual
  8. #23
    I'm part of the furniture Club Member Dnk's Avatar
    Join Date
    Apr 2005
    Location
    England - West Midlands
    Posts
    22,006
    Feedback
    15 (100%)
    I'd take the calipers off and drill them on something like a Bridgeport turret milling machine
    Dunk
  9. #24
    Join Date
    Mar 2006
    Location
    Posts
    404
    Feedback
    0
    Quote Originally Posted by Dnk View Post
    I have actually been just stood next to 4 Bridgeports. Not sure if the company would let me put my calipers in there tho. I work as a H&S consultant and do a variety of engineering firms but its generally for medical or aerospace.
    So its going to have to be a DIY job unfortunately
  10. #25
    Join Date
    Mar 2006
    Location
    Posts
    404
    Feedback
    0
    Any opinions on the Air con delete.
    Im looking at how its stacked up at the front. There is a my FMIC then the aircon rad before the radiator. It cannot be good for it, or am I overthinking it? Thing is I think I would use the air con but the car is going to be second car rather than a daily driver like it was before so maybe I would do without.
  11. #26
    Join Date
    Apr 2005
    Location
    Posts
    22,006
    Feedback
    15 (100%)
    Never had any issues with my car with a silly big HKS R spec in the front
    Dunk
  12. #27
    Join Date
    Mar 2006
    Location
    Posts
    404
    Feedback
    0
    Ye Once I had typed it and submitted I did a bit of reading and came to the conclusion it should be fine. Just wants all the spiders cleaning out of it
  13. #28
    Join Date
    Jan 2008
    Location
    (Top Secret)
    Posts
    4,593
    Feedback
    12 (100%)
    I don’t think there is any need for that but if you were concerned (is in so much that it bothers you) fit a SMIC and keep the air con. I wouldn’t get rid of the air con to keep a FMIC.
  14. #29
    Join Date
    Apr 2005
    Location
    Posts
    22,006
    Feedback
    15 (100%)
    What condition is the rad in, is it original or been replaced at some point ?
    Dunk
  15. #30
    Join Date
    Mar 2006
    Location
    Posts
    404
    Feedback
    0
    It looks original, I would say it looks worse than it is. Until I make an effort to clean it I can not really say.
    Its on my job list for the weekend as well as getting the rear calipers off.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
