"Angel White"
Club Member
Clutch replacement for 95 NA manual
Hi all,
I've recently experienced over revving whilst flooring it in mid to high gears then when easing off the gas pedal it catches on, I suspect a slipping clutch to be the culprit.
So I am now starting to source for a replacement but would like people's input on the best upgraded clutch that could handle a future NA-T conversion. I don't want to spend mega bucks so a reasonably priced one is what am looking for.
Cheers
"Angel White"
Club Member
Work... what work?
Club Member
I have a spec stage 3+ with 500 miles on it if you are interested? I upgraded to v161 so no longer needed. It's a great feeling clutch, much better than the competition stage 4 i had before it! It will handle na-t power no problem.
"Angel White"
Club Member
Thanks , I was in Newton Stewart last week as well .
I've managed to source a new one , stage 3 competition clutch from Auto extreme, but wondered how these after market clutches handle with stock flywheel?
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
