Steering rack, headlight lenses, alternator, starter, matrix, abs, relays, wiring ETC
Sean1933
 Share
***Prices updated - need gone asap as moving house end of Jan!***
Been sitting in my garage loft for the last 8 or 9 years and now selling the house so need the space.
Photos available upon request if you need them (links now added with majority of photos). OFFERS PLEASE on items not showing a price, as I'm totally out of touch on what these things are worth these days!
Came from my old 1993 Jap TT6 with approx 80k miles:
*Aftermarket clear headlight lenses, uncut. (bought on a group buy way way back when) £SOLD STC
Same as these but untrimmed (work out at over £360 with taxes/shipping)
https://www.ebay.co.uk/itm/Clear-Supra-Headlight-LENSES-without-Black-Edge-Line/273486769699?hash=item3fad14ee23:g:rkgAAOSwWqNa~PcQ
* Steering rack - no leaks (now with correct photo!) £SOLD
https://1drv.ms/u/s!ApCZm8cLfKOann9SQR_2PZywHi5a
* Wiring loom, main car including fuse boxes. Does NOT include engine loom and most of the relays etc shown in photo are be missing (I have separately) £offers?
https://1drv.ms/u/s!ApCZm8cLfKOann7ekw84HmhmwzWz
* 1 stock turbo, some modest cold side blade damage (inc actuator) £SOLD
* Alternator SOLD
* Starter motor £50
* ABS pump £60
* Master brake cylinder, reserve & Master servo £80
* Toyota original spark plug cover £100
https://1drv.ms/u/s!ApCZm8cLfKOannWLCuzslv_7anwX
* Heater matrix (some minor bent fins but other than that in good condition inside and out) £50
https://1drv.ms/u/s!ApCZm8cLfKOannTJcBBUmWBe-Kmd
https://1drv.ms/u/s!ApCZm8cLfKOannPYN-WsaG7WeDbL
* Odometer cluster inc mil/oil/battery/etc lights, hazard button etc. LEFT & RIGHT SIDES. (car had done 80k miles but cannot remember if displayed in kms or miles it has been that long - if anyone knows an easy way to power and check please let me know!) £ODO/LEFT SIDE SOLD. Only R/side left - offers
https://1drv.ms/u/s!ApCZm8cLfKOanmwUNwLLxL6kqd-7
https://1drv.ms/u/s!ApCZm8cLfKOanmpBW9WOGdeMdG6e
https://1drv.ms/u/s!ApCZm8cLfKOanmWz4XCg8b1Qczbm
* Upper glove box (square cut out of the inside rear forboost controller) £SOLD
https://1drv.ms/u/s!ApCZm8cLfKOannexqpn3jKlunz1r
* Lower glove box £30
* Central armrest glove box console £offer
* Electric window switches - BOTH SIDES. £90
https://1drv.ms/u/s!ApCZm8cLfKOanmI8mYiUfW9eheR_
* Electric mirror control switch £30
https://1drv.ms/u/s!ApCZm8cLfKOanl7ok-SdllJODHvE
* Power steering ECU 89650-14090 £offers
https://1drv.ms/u/s!ApCZm8cLfKOanmYsqZ1o6OlR1pJF
* ABS Deceleration Sensor unit 89441-14010 £offers
https://1drv.ms/u/s!ApCZm8cLfKOanmDQ_salXm1cRGde
* Door control unit 85980-14110 £50
https://1drv.ms/u/s!ApCZm8cLfKOanm1VbqBcjj9GVlXs
* Most relays / flasher unit etc - just ask
* Wiper/indicator stalk - £SOLD
* Rear mirror £offers
* ash tray with lid £20
* reading light £15
* valve stem seal replacement kits, unsure of brands (x2) £offers
* 2x door handles (custom grey colour so will need painting) £25 each
* Dash panels from J-spec, painted in gunmetal grey. Inc dash dimmer switch. No gear surround. Main panel left airvent hole has been cut to fit a slightly larger boost gauge (80mm?). £150
https://1drv.ms/u/s!ApCZm8cLfKOanxPZr1wMkGg7ReXg
Harnesses? I am looking for the one in the boot that connects to a plug for the window wiper motor at the trunk lid and the top or third brake lamp? Can you tell me if the harness connectors from engine side to body interior loom are there or how will I obtain that as I don't have an oem engine harness but an Aristo GTE harness
Im really sorry but I cant remember exactly where the loom covered, other than I know it wasnt the engine - its been nearly a decade since I removed it from the car!
the rack sells for different prices. Anywhere from $100 or less to more than $400. All depends on overall condition of operation, smooth turning and rack ends being fine but only you can determine that or the buyer can further inspect it.
The harness, can you take close up photos and send them to me. Those are a bit far off and I cant see much from that pls
  • 1 month later...
  • 2 weeks later...
  • 4 weeks later...
  • 2 months later...
 Share
