Built 3.1L with Precision 6466 Gen 2
Guest Budz86
 Share
Guest Budz86
Only taken 2 years to post this!
Engine Type - 2JZ GTE non vvti
Engine Spec - Fully built 3.1L, HKS 86.5mm pistons, JUN rods, JUN 272 cams, ASNU 1100cc injectors, twin Walbro 485s, 110mm throttle body
Turbo - Precision 6466 Gen 2 (1.0 a/r), HKS manifold, recirc'd HKS 60mm wastegate, 4"greddy intercooler, 4" pipework
Fuel Used - Shell V-Power with 60% ethanol mix
Exhaust - custom 4" downpipe into 5" midsection and rear box
Transmission - V160
ECU - Syvecs
Mapped By - SRD Tuning
Dyno Used - Abbey Motorsports Dynapack hub dyno
Power figure - 790
Torque figure - 627 ft/lbs
Boost Pressure - 1.66 barimage
Guest Budz86
Ooosht.. good power man!
Out of interest are you on standard valves? Just uprated cams in the head?
Standard size iirc, but not OEM
Guest Budz86
790 hp on 1.6 bar! that's impressive!
Cheers dude, makes almost 1.8 on the road at times [emoji41]. Meant to upgrade the wastegate spring just to see how much boost I could make as there's more in it I reckon but never got round to it
  • 3 weeks later...
 Share
