Results 1 to 12 of 12
Thread: Use Lq9/ls2 or VAG Coils with Aem v1?
  1. #1
    Work... what work? Club Member Silece2k6's Avatar
    Join Date
    Mar 2011
    Location
    Germany
    Posts
    229
    Feedback
    1 (100%)
    Is it possible to run vag or ls2 coils with the Aem v1 ecu?
    Gesendet von iPhone mit Tapatalk
    "Well, there's a straight-six engine at the front, a manual gearbox in the middle, and drive goes to the back. That's page one, chapter one from the petrosexual handbook." --Jeremy Clarkson
  2. #2
    - Club Member Big Mark's Avatar
    Join Date
    Jul 2007
    Location
    England - Oxfordshire
    Posts
    3,048
    Feedback
    23 (100%)
    Ask your mapper as he may have a preference.
    Mine fitted VAG ones. Tho he didn't even tell me there was an issue with my old ones until afterwards.
    Also, the cover will need to be modified as VAG coil packs are taller than OEM ones.
    Currently undergoing a major overhaul including: Engine rebuild by Littlenum, PHR Street Torque kit with PT 6266 turbo, Custom 3.5" exhaust, Whifbtiz DCT conversion, Syvecs S6+, Brembo Big Brake upgrade, Underbody treatment including powder coated subframes, modified rear arches for new wheels, Full respray in new colour. etc etc etc
  3. #3
    1.21 Gigawatts Club Member Wez's Avatar
    Join Date
    May 2002
    Location
    England - Berkshire
    Posts
    18,684
    Feedback
    37 (100%)
    Why are you changing the stock coils?
    Is it because the AEM v1 converts from direct fire to wasted spark, the old fix for this was a HKS ignition amp, I ran that setup on stock turbos and then again on a single up to 1.8bar using the stock coils.
    Supra: 1996 Silver, Syvecs S6 ECU, 500bhp & 500ft/lbs, 95ron Unleaded
    Porsche: 2002 Black 996TT, Syvecs S8 ECU, 630bhp
    Lexus: 2001 LS430, Toyota 3UZ-FE V8
    Odds: Dyno Plot | Turbos Compared | 2BarTuning | Engine Part Weights
    Steve Manley 01865 291300
    | Garage Clearout |
  4. #4
    Join Date
    Mar 2011
    Location
    Germany
    Posts
    229
    Feedback
    1 (100%)
    I have a Hks dli installed. The Problem is missfire above 1.5bar in higher gears 3-6. We tried new coils (oem denso and the red ones) with new plugs bkr8eix (gap 0.5) and bcp7r. All missfired. We tried coils and plugs from a 1xxx hp Supra running 2.2bar without any diffrence.
    Coilplug connectors are new ones. May I have to check the wirings from igniter to coils?
  5. #5
    Join Date
    May 2002
    Location
    England - Berkshire
    Posts
    18,684
    Feedback
    37 (100%)
    If the 1xxx hp Supra is running OK with the same stuff, have you compared the coil settings between the two cars, it does make a difference.
    | Garage Clearout |
  6. #6
    Join Date
    Mar 2011
    Location
    Germany
    Posts
    229
    Feedback
    1 (100%)
    Yes we tried other dwell Time if you mean that.
  7. #7
    Join Date
    May 2002
    Location
    England - Berkshire
    Posts
    18,684
    Feedback
    37 (100%)
    That is one of the settings yes, been a long time since I looked at AEM software
    | Garage Clearout |
  8. #8
    Join Date
    Mar 2011
    Location
    Germany
    Posts
    229
    Feedback
    1 (100%)
    So anyone know if Vag coils or lq9 work with Aem v1
  9. #9
    Join Date
    Jul 2007
    Location
    Posts
    3,048
    Feedback
    23 (100%)
    Just ask your mapper, he should be able tell you.
  10. #10
    Join Date
    Mar 2011
    Location
    Germany
    Posts
    229
    Feedback
    1 (100%)
    He isn‘t sure, since Aem 1 is a Longe Time ago.
    Je Said the vag coils and lq9 had to run waste and spark like the oem coils because the v1 ecu has only 5 ign Outputs...
  11. #11
    Join Date
    May 2002
    Location
    England - Berkshire
    Posts
    18,684
    Feedback
    37 (100%)
    AEM v1 always runs wasted spark on 2JZGTE.
    | Garage Clearout |
  12. #12
    Join Date
    Mar 2011
    Location
    Germany
    Posts
    229
    Feedback
    1 (100%)
    Sorry my fault, vag coils and lq9 are direct Fire i guess... and Aem v1 only can wasted spark
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
