Page 1 of 3 123 LastLast
Results 1 to 15 of 41
Thread: Bit more of an update on the "affordable" single turbo kits
  1. #1
    What search button? Authorised Trader
    Join Date
    Jul 2012
    Location
    England - Worcestershire
    Posts
    1,153
    Feedback
    15 (100%)
    Its been a while, i've been plugging away in the background on the 2 turbo kits i plan to offer, so i thought i'd share the fruits of my labours.
    There is 2 kits being developed which i call the following, "BPU Max Kit" and a "Street Max Kit"
    The idea behind the BPU Max kit is an affordable single setup that is the last stage in the BPU tuning process, running on the oem fuelling injectors and system, and the OEM ecu with using lower boost or a simple piggyback for higher (testing will give more information on this) Its going to be priced to compete with owners who need to rebuild there OEM twins because of age or moving to a hybrid twin upgrade, but giving much more midrange torque. I plan to run a garrett GTX3076r turbocharger package with a reworked internal wastegate exhaust housing. Capable of the 450-475bhp range with near instant response.
    It will retain the OEM exhaust manifold with a tubular adaptor manifold mated to this to suit a single T3 exhaust flange. The prototype of this has been completed and is in thickwall mild steel, but the finished item will be in a 3.8mm wall thickness stainless steel so guaranteed never to crack. It will also come with a 3" tubular downpipe upto the beginning of the 2nd decat flange.
    The Exhaust housing will be offered in either 0.63/0.82 or 1.06 options although i beleive the 0.82 is the smallest you really want to go. Its a genuine garrett exhaust housing but reworked on the CNC to massively open up the wastegate port from the oem 28mm flapper to a huge 44mm flap.
    This is how far i've gotten so far with this, with updates coming in regularly
    - - - Updated - - -
    The other kit is what i'm calling the "Street Max Kit"
    Which again is designed at road going supras, using either a GTX3582r or the larger GTX4088r turbocharger, the smaller of the 2 is well used on the supra making 600bhp and full boost by little over 3000rpm. Personally on an all weather, street supra this is about as far as you want to go. To make the most of this kit your talking about a clutch upgrade, fuelling and some means to control the fuelling.
    Its going to be using a extensive ported and polished cast log manifold, CNC wastegate plate for a larger 44mm external wastegate and again a full 316l stainless downpipe to the start of the 2nd decat flange. Options for this will come in both reroute and screamer pipe options.
    TB Developments, Toyota specialist tuner
    West Midlands, 07779415207
    Facebook Blog: https://www.facebook.com/tbdevelopments
  2. #2
    I'm part of the furniture Club Member tooquicktostop's Avatar
    Join Date
    Jul 2006
    Location
    England - Warwickshire
    Posts
    11,755
    Feedback
    43 (100%)
    Its an interesting option, I think I took one of my cars to BPU Max with rebuilt Hybrid turbos, 550 injectors from a Uk spec, Syvecs ECU, FMIC, bigger fuel pump etc and was disappointed with the result (440BHP), that little lot cost well over 4000 fitted so would be interested to see what this costs
    Good work
  3. #3
    Join Date
    Jul 2012
    Location
    Posts
    1,153
    Feedback
    15 (100%)
    well if your already at BPU so its just the turbochargers that are letting it down, this kit will be in the sub 2500 range delivered. And if required you will want a piggyback only, no need for a full standalone.
  4. #4
    Say Ello 2 My Little ...> Club Member Pudsey's Avatar
    Join Date
    Apr 2009
    Location
    England - Devon
    Posts
    2,419
    Feedback
    95 (100%)
    Look forward to the finished article.
    Be interested to see where the turbo charge outlet feeds/ clears towards intercooler charge point.
    Great idea though using the existing manifold
    Of course I talk to myself. Sometimes I need expert advice.
  5. #5
    Join Date
    Jul 2012
    Location
    Posts
    1,153
    Feedback
    15 (100%)
    the outlet of the turbo will clear the suspension turret then there will be a short hose to connect to the oem sidemount location, this pipe will be an optional extra as alot of people have fmic etc
  6. #6
    I'm addicted now! Club Member jonc's Avatar
    Join Date
    Nov 2005
    Location
    England - Devon
    Posts
    593
    Feedback
    4 (100%)
    Nice touch if it works well and plums in ok. There is probably a big market for this as our turbos get older
    JonC
    "living the dream"
    Supra VVTI TT Tiptronic
    MGZT 190
  7. #7
    JDL BODYKIT Club Member andz222's Avatar
    Join Date
    Aug 2011
    Location
    (Top Secret)
    Posts
    225
    Feedback
    0
    nice work
  8. #8
    Join Date
    Jul 2012
    Location
    Posts
    1,153
    Feedback
    15 (100%)
    thats the idea guys, then there is the Street max, setup if you want a little more before going down the route of full tubular manifold and big money
  9. #9
    Work... what work? Club Member
    Join Date
    May 2016
    Location
    England - Bedfordshire
    Posts
    365
    Feedback
    2 (100%)
    Interested in this, look forward to seeing the dyno numbers!
    1994 Stock TT Supra
  10. #10
    Me? Post? Never! Club Member squiffy's Avatar
    Join Date
    Mar 2006
    Location
    England - Hampshire
    Posts
    2,405
    Feedback
    9 (100%)
    You sir, have my attention!
    Subscribed, and I'll be keeping an eye on this
    Sent from my SM-G950F using Tapatalk
    N/A manual supra, TT auto supra, TT auto soarer converted to manual (x2), TT auto Aristo, N/A auto GS300,
    TT 6spd Supra...........FINALLY!
  11. #11
    The Cake Is A Lie Club Member MattP's Avatar
    Join Date
    Mar 2009
    Location
    England - Durham
    Posts
    3,925
    Feedback
    25 (100%)
    I also like this Idea its only a matter of time before stock twins start dying I would be interested in a lower power end kit.
  12. #12
    I'm part of the furniture Club Member j_jza80's Avatar
    Join Date
    Jun 2008
    Location
    England - North Yorkshire
    Posts
    19,369
    Feedback
    13 (100%)
    Nice
    I run the GTX3576R turbo (which I bought from you), even on a HKS tubular manifold this is realistically as quick spooling as the car can cope with, and thats on a tiptronic with a TRD LSD. on a manual with a log manifold the GTX30 setup would be savage. Wouldn't running such a small turbo result in a lot of surge? And similarly, a small turbo with an integral wastegate would presumably exacerbate this?
    This would be worth a look at re: your log manifold, nicest log manifold I've seen for these cars; http://fsrmotorsports.com/index.php?...mart&Itemid=87
  13. #13
    Faffing Club Member Supra-love's Avatar
    Join Date
    Mar 2008
    Location
    England - Buckinghamshire
    Posts
    818
    Feedback
    3 (100%)
    Subscribed, will be interested in the max kit, after all testing and numbers are settled.
    In the words of sir Winston Churchill, Never, Never, Never, Give Up.
  14. #14
    Join Date
    Jul 2012
    Location
    Posts
    1,153
    Feedback
    15 (100%)
    well my street max kit is going to be using a GT35 based turbocharger with a cast log manifold after extensive cnc porting.
    the idea behind this kit is from the power house amuse kit that used a HKS gt30r which looking at the specs is basically the same as the gt3076r.
    the internal wastegate i assume you mean boost creep as this is the only thing that the wastegate would effect, but this is why i've done a total redesign on the wastegate ports of the housing, pictured above.
    heres a video of there setup.
    https://www.youtube.com/watch?v=aal9kG-EXeY
    Tim
    TB Developments
  15. #15
    Join Date
    Jun 2008
    Location
    Posts
    19,369
    Feedback
    13 (100%)
    Boost creep is exactly what I meant (in the middle of an essay and my head is still buried ) Was it the Amuse kit that utilised the stock exhaust manifold using an adaptor, as you have above? I remember those, think they were discontinued many years ago.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
