Page 5 of 5 FirstFirst 12345
Results 61 to 73 of 73
Thread: Jonny's Supra Revival Project
  1. #61
    Me? Post? Never! Club Member Hammer's Avatar
    Join Date
    Oct 2009
    Location
    England - Isle of Wight
    Posts
    2,045
    Feedback
    7 (100%)
    It's alive
    Deep Jewel Green, Aero Top, Facelift.
    green aerotop awesomeness!!! (marcAB10)
    And in answer to adams green facelift aero, you will have better luck bumming megan fox before he sells (drift_bear)
    So nice to see a fantastic dark green aero with Recaro seats on a such a nice day. Whoever owns it should be proud. It's a stunner! (Delboy52)
  2. #62
    Terrible Club Member safcdixon's Avatar
    Join Date
    Jan 2009
    Location
    England - Durham
    Posts
    6,736
    Feedback
    15 (100%)
    Top work on this dude
  3. #63
    Me? Post? Never! Club Member Annabella's Avatar
    Join Date
    Feb 2016
    Location
    England - Lancashire
    Posts
    2,183
    Feedback
    0
    Excellent nice burble at the exhaust
  4. #64
    Supra/Silvia Club Member jonny mac's Avatar
    Join Date
    May 2007
    Location
    Scotland - Grampian
    Posts
    477
    Feedback
    5 (100%)
    put the new clutch master cylinder in, unfortuantely the original male nut on the pipe had a flat thread right at the begining
    rather than wreck the new aluminium threads inside the cylinder i decided to make a small joining piece with two brand new nuts on the end
    this way it screwed in with ease and had no issues and if it was going to destroy a thread when tightened up it would have only wrecked the female nut on my small copper pipe
    worked perfectly and holds pressure with no leaks
    211 by Jonny McIntosh, on Flickr
    feed pipe to slave from hose made up and bled clutch system to gain a fully operational pedal
    212 by Jonny McIntosh, on Flickr
    rolled outside for the first wash in a while
    213 by Jonny McIntosh, on Flickr
    replaced all 3 spark plug connectors and a length of the looms to each one, they had gone brittle and hard with heat causing cracking/green corrosion on a few of the cables
    214 by Jonny McIntosh, on Flickr
    ran wires for oil pressure and temp gauge to sensors on the dash
    for my own reference here really...ignore this bit
    red/black wires going into cab go to gauges, red is oil temp to gauge green input wire, black is oil pressure to gauge green input wire
    on oil pressure sensor at sandwich plate, wk stamped is ground, g stamped (tipexed white) is to black wire to gauge green input wire
    nearly ready to start
    215 by Jonny McIntosh, on Flickr
    renewed the gasket between the turbo oil return Y pipe and the sump, i had used an old one when assembling with some instant gasket, it had a slight damp oil mark around the bottom
    was enough for me to take advantage of dry pipes just now before engine was running
    old one off, new one in package beneath from toyota
    216 by Jonny McIntosh, on Flickr
    tested out reverse light wiring to make sure the new led bulbs worked
    218 by Jonny McIntosh, on Flickr
    was waiting for around 10 days for customs to release my aristo ecu
    finally got here
    217 by Jonny McIntosh, on Flickr
    plugged it in, cranked for oil pressure and checked gauge, all is well then first turn of the key:
    delighted
    then this happened:
    now moved away from the workshop so it's not in the way, it'll be stored for a short while until i can get my insurance and stuff sorted out,
    we are down to one wage at the minute as the wifes off work for a few months so it isn't priority to fire alot of money into insurance just now
    at least i know it runs sweet, i need to make sure the battery system is charging correctly, i had 12.5v on my multimeter but the battery had sat around for a while and had been cranked for oil pressure checks
    219 by Jonny McIntosh, on Flickr
    still got a jobs list to do before it goes on the road
    interior:
    fuel pump 12v constant mod at ecu boot wires
    secure aristo ecu into holder beneath dash
    rpm gauge to remove resistor in chip board to work with aristo igniter readings
    check batt light wiring
    under bonnet:
    carbon can hose
    boost gauge t piece
    tidy up wiring and secure loom
    add more earth points
    extend gearbox loom so speedo reaches
    secure lambda sensor wiring loom
    protect coolant top hose against rubbing fan shroud
    bleed coolant, check thermostat opens
    box propshaft seal replacement
  5. #65
    I'm addicted now! Club Member kwalker705's Avatar
    Join Date
    Oct 2009
    Location
    Scotland - Grampian
    Posts
    511
    Feedback
    3 (100%)
    well done johnny
    you can store the supra at mine if you want.....I'll take very good care of it
  6. #66
    Join Date
    May 2007
    Location
    Scotland - Grampian
    Posts
    477
    Feedback
    5 (100%)
    Quote Originally Posted by kwalker705 View Post
    well done johnny
    haha, I'm sure a plain supra 2j with bolt ons would get boring after 5 minutes compared to your car
  7. #67
    Join Date
    Oct 2009
    Location
    Scotland - Grampian
    Posts
    511
    Feedback
    3 (100%)
    Quote Originally Posted by jonny mac View Post
    I've not seen mine since january so I'll take what i can get. hahahaha
  8. #68
    Join Date
    May 2007
    Location
    Scotland - Grampian
    Posts
    477
    Feedback
    5 (100%)
    well insurance is starting on the car next month now so that's pretty exciting
    done a few small bits over the weekend, led headlight bulbs are now in, whifbitz expansion tank is now in also but that's up the side of the battery now rather than behind the headlight as the bulbs have big cooling units on the back of them
    still have a few odd jobs left to finish on the car but it's getting there! I reckon another evening of work and it'll be fully road ready again
    then I can start looking at single turbo manifolds and some gtx or precision 6266 goodness
  9. #69
    :-D Club Member PJJ's Avatar
    Join Date
    Mar 2017
    Location
    England - Staffordshire
    Posts
    236
    Feedback
    0
    That made for excellent lunchtime reading. Well done on saving another classic.
  10. #70
    Join Date
    May 2007
    Location
    Scotland - Grampian
    Posts
    477
    Feedback
    5 (100%)
    soooooooooooooo
    insured it, tomorrow morning is my first drive to work in the car and technically my first road test haha, wish me luck
    tomorrow after I finish working i'll be spending some of my afternoon finishing the remaining jobs on the car
    connect up the boost guage
    change the power source for the oil gauges
    connect the gbox speed sensor and reverse switch as that part of the loom is tied up in engine bay
    check all the levels again
    fit spark plug cover
    I need to work out how to fit my boost controller bleed valve with the twins
  11. #71
    Join Date
    May 2007
    Location
    Scotland - Grampian
    Posts
    477
    Feedback
    5 (100%)
    so this is a delayed update
    bled the coolant properly, ran it up to temp and chcecked all fluid levels
    set of led headlight bulbs and 501 sidelight bulbs
    220 by Jonny McIntosh, on Flickr
    221 by Jonny McIntosh, on Flickr
    back on the road it's one week in, i've driven the car gently to bed in the new clutch and so on
    loving it!
    then the first day out for some road testing after a few jobs were finished
    i managed to take a blurry pic...
    222 by Jonny McIntosh, on Flickr
    so the door speakers had always annoyed me as i knew they needed replaced
    bought some of these on ebay, 30 quid and they are 350mm deep which suits the surpa door cards nicely
    223 by Jonny McIntosh, on Flickr
    224 by Jonny McIntosh, on Flickr
    225 by Jonny McIntosh, on Flickr
    finished the vacuum lines and had to get a few extra fittings from demon tweeks, main one i was stuck for was a 8-6mm adapter for the fuel breather
    226 by Jonny McIntosh, on Flickr
    227 by Jonny McIntosh, on Flickr
    battery system is charging perfectly
    the gauges were a good investment, the oil temp sits at a safe 90 degrees and the oil pressure is around 2 bar when warm
    228 by Jonny McIntosh, on Flickr
    here's the mileage, this is after 100km running in so just for reference that's the shell mileage during conversion, car still in km's and it'll remain that way
    229 by Jonny McIntosh, on Flickr
    water temp also sits bang on where it should
    230 by Jonny McIntosh, on Flickr
    delighted
    231 by Jonny McIntosh, on Flickr
    under the bonnet is also a great place to be now haha
    232 by Jonny McIntosh, on Flickr
    this is the oil i run all my cars on, the nissan and the supra both get this stuff
    233 by Jonny McIntosh, on Flickr
  12. #72
    Join Date
    May 2007
    Location
    Scotland - Grampian
    Posts
    477
    Feedback
    5 (100%)
    and that's the car sold, payment taken tonight, it's off to spain!
    will upload some of the new pics of the car over the last few weeks
  13. #73
    is a broke Club Member Fitz's Avatar
    Join Date
    Jan 2008
    Location
    England - Greater London
    Posts
    5,901
    Feedback
    8 (100%)
    That was unexpected
    Go On...Test your Strength
    My Psychiatrist says I have a pre-occupation with vengence.......we'll see about that
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
