Help, na engine problem
boostman
 Share
Started the car this morning and the engine is vibrating and shaking,
It sounds ok (but rougher), so don't think it's a miss fire.
Could it be the crank pully?
It was fine yesterday did 300 miles and didn't miss a beat.
If there's anyone near Rugeley that could help diagnos this that would be amazing as this is my daily.
Thanks a lot!
Do the tipex test on the pulley
Inspect the cap and leads on the dizzy, take the cap off and check the rotor arm and inside the cap
If it has a missfire you can possibly narrow it down to a cylinder by removing each plug lead from the dizzy cap one at a time
and seeing if that affects the tick over.
If it has a missfire you can possibly narrow it down to a cylinder by removing each plug lead one at a time
OK so the middle steel part will become detached from the pully?
/QUOTE]
Eventually the pulley where the belt sits will separate from the steel center part which will stay bolted
to the crank
Put a line across and run the engine, if the line separates your pulley is shot
Thanks, is that a dampened pully?
It's much cheaper than a toyota one, is febest a reputable make?
/QUOTE]
I wouldn't even consider that pulley. OEM is the way forward, even if you get a good used one off keron or somebody on here..
Alternatively there is more expensive after market ones from Titan etc
On my old NA engine, I once had the throttle coolant pipe come loose and fill my spark plug wells with coolant. The moment the engine got hot the engine misfired like crazy.
Potentially oil could create the same affect.
Crank pulley coming loose should not cause a misfire. Typically it will cause all the auxillary systems like water pump/alternator etc to start acting dodgy.
Start by replacing your cam cover seals, clean out your spark wells and clean your spark plugs at HT leads.
OK so got the plugs out and 1-5 are ok but number 6 has a hard rough coating. Check all for continuity and It and there in good condition.
Cleaned them up and put them back in, now changing the cam cover gasket.
Any idea what number 6 plug is indicating?
Thanks image
 Share
