Speedo Problem
foggy147
 Share
Hoping someone can help. Left work tonight and the speedo / clock had stopped working. It was absolutely fine this morning, car had been sat in office car park and then tonight it's just stopped. All my other dials work just the speedo and clock.
Any idea what may of caused this and is it an easy fix
Thanks in advance.
Going by my old notes on a pre facelift, there is a Speed Sensor that works between the the Odo & Trip display and the Speedometer. (so would make some coincidental sense why both are inop)
The Speed Sensor has a Black 3 pin plug (Wire/ Pin No.: 1. Yellow, 2.Red, 3. Blue w/Red stripe) connector on the Drivers side of the Auto Transmission.
From there they run to an Orange 38 pin Plug on left side lower half behind the Passenger Glove box, near LH Fuse box (Wire/ Pin No.: 23.Yellow, 2.Blue w/Red stripe, 8.Red.
Then from there they run to the Combination meter unit on a Brown 13 pin Plug (Wire/ Pin No.: 13.Yellow) and Blue 13 pin plug (Wire/ Pin No.: 3.Red, 5.Blue w/Red stripe.)
INSPECT VEHICLE SPEED SENSOR OPERATION (W/ Speed sensor unplugged and removed from Transmission)
(a) Connect the positive (+) lead from battery to terminal 1 and negative (–) lead to terminal 2.
(b) Connect the positive (+) lead from tester to terminal 3 and negative (–) lead to terminal 2.
© Rotate shaft. (d) Check that there is voltage change from approx. 0 V to 11
V or more between terminals 2 and 3.
HINT: The voltage change should be 4 times for every revolution of the speed sensor shaft. If operation is not as specified, replace the sensor.
The Odo & Trip Display use a 7.5A Dome Fuse also (as well as 10A Gauge Fuse), if that Fuse has blown the interior roof light would be inop. Also Ground wire/ Earth for Odometer & Trip is (Pin 7) Brown wire to Drivers Kick panel/ Footwell, near fusebox.
On Facelift VVTI:
Speed Sensor is a 2 pin Plug on LH Side of Gearbox (Wire/ Pin No.: 1. Blue w/ Yellow stripe, 2. Red w/ Yellow Stripe) which run to the ECM ( 18 Pin plug No.: 5. Blue w/ Yellow stripe, 11.Red w/ Yellow Stripe)
Speed Sensor itself (unplugged & removed from Transmission) resistance 560 - 680 Ohms.
Reference check vehicle speed sensor’s function: Check voltage between terminals 1 and 2 of the vehicle speed sensor when a magnet is put close to front end of the vehicle speed sensor then taken away quickly. OK: Voltage is generated intermittently. HINT: Voltage generated is extremely low.
Also Check connections & wiring on the back of the Combination meter assy, as could be an aftermarket KPH to MPH converter at fault (if fitted).
Hope this Helps
Edited by GreaseMonkey (see edit history)
 Share
