BPU TT6 Dyno run
Jellybean
 Share
Engine Type - TT
Engine Spec - 264 Tomei Cams & Greddy intercooler
Turbo - Stock
Fuel Used - 95 Pump fuel
Exhaust - HKS Hi power Silent & First decat, 2nd aftermarket cat is in (Brand unknown)
Transmission - V160
ECU - Stock with Sard Analyse ROM
Power figure - 400hp
Torque figure - 376 ftLb
Boost Pressure - 1.2 bar
As expected Fuelling is all over the place, running very rich on Idle, a little lean on partial load and a little rich on Full Load; the out come over time will be Borewash (Fuel Contamination in the oil resulting in eliminating the lubrication of oil from critical components like the trust, big end bearings)
Time to pull the trigger on a full standalone ECU with O2 Wideband sensor to get fuelling spot on
Some Pics
[video=youtube;uhBRJGNRl-M]
  • 11 months later...
Spec:
OEM 2JZ block and head.
Standard Twin Turbos
6 Speed Manual
264 9.5mm Tomei Poncams
Siemens Dekra 890 cc
Billet Fuel Rail
Bosch Motorsports FRP
One De-cat and 2nd sport cat
HKS Exhaust
OEM air box with K&N Panel Filter
255 Walbro Fuel pump
Motec M130
Motec LTC Wideband controller and Bosch LSU 4.9
Running in Sequential
Final Run was 424hp @ 1.3 Bar and 431.9 ftlb Torque, Rev limit set to 7100 from Stock 6800rpm on 95 octane fuel
Edited by Jellybean (see edit history)
 Share
