Page 1 of 3 123 LastLast
Results 1 to 15 of 37
Thread: N/A first start up in 2 years - Checklist of things to do
  1. #1
    Me? Post? Never! Club Member Mike2JZ's Avatar
    Join Date
    Dec 2010
    Location
    England - Kent
    Posts
    2,128
    Feedback
    12 (100%)
    So the N/A I bought recently is getting to the stage where sometime this weekend I will be starting her up for the first time in about 2 years.
    My checklist of things to do is the following, can anyone confirm if I'm on the right track or if there is anything else that would be recommended to do.
    1) Install new battery
    2) Siphon old fuel out of tank, replace with new fuel
    3) Try starting car, if engine fires and runs go to next step, if not then diagnose issue
    4) Full service of fluids
    5) New oil filter
    6) Done?
    Cheers
  2. #2
    Do Luck owning Club Member Swampy442's Avatar
    Join Date
    Feb 2006
    Location
    England - Lincolnshire
    Posts
    14,309
    Feedback
    50 (100%)
    Before you try and start it up, prime it first. Pull the lead off the coil, turn it over to build some oil pressure up, circulate it a bit and get the fuel pressure up.
    I would gladly pay you 10 to never log onto this forum again, and I am serious. Scott M
    Quote Originally Posted by Chris Wilson View Post
    I did terrible things to girls I had only just met, and they loved it.
  3. #3
    Join Date
    Dec 2010
    Location
    England - Kent
    Posts
    2,128
    Feedback
    12 (100%)
    Quote Originally Posted by Swampy442 View Post
    Just to clarify, by disconnected the coil packs, ignition won't happen. But turning the key will still make the engine crank? Which in turn leads to increased oil pressure + circulation?
  4. #4
    I'm part of the furniture Club Member Dnk's Avatar
    Join Date
    Apr 2005
    Location
    England - West Midlands
    Posts
    22,161
    Feedback
    15 (100%)
    Just pull the center coil lead out the dizzy, your car wont start then.
    As you turn the engine over you are turning the oil pump thus pushing oil round
    the engine, you should see the oil light go out on the dash, when it does pop the
    lead back on the dizzy and fire it up, don't rev it though and let it tick over for a while
    I'd check the oil level first using the dipstick and check the rad is full of coolant and the
    expansion tank is approx half full, check the state of the rad cap too, the seal on the underside
    tend to fail with age.
    Don't forget to change the brake fluid and check all the calipers are free and working correctly
    Dunk
  5. #5
    Join Date
    Feb 2006
    Location
    Posts
    14,309
    Feedback
    50 (100%)
    Quote Originally Posted by Mike2JZ View Post
    Excactly, plus you have an NA so no coil packs
  6. #6
    I'm part of the furniture Authorised Trader Chris Wilson's Avatar
    Join Date
    Nov 2001
    Location
    England - Shropshire
    Posts
    31,929
    Feedback
    108 (100%)
    Just fire it up, 2 year old fuel isn't very old. I have fired barn finds up on 14 year old fuel, maybe older.
    Regards, Chris Wilson. No PM's PLEASE, use e-mail!
    Race and performance road car servicing and preparation in north Shropshire. Race and road car engine building and tuning.
    Suspension development and geometry specialist, Supra work and other cars too! 07971-952084
    chris@chriswilson.tv
  7. #7
    Join Date
    Dec 2010
    Location
    England - Kent
    Posts
    2,128
    Feedback
    12 (100%)
    Alright thanks for the advice guys, much appreciated. Will take some video's just in case it all goes tits up and laughs can be had.
  8. #8
    Wine Club Member Scott's Avatar
    Join Date
    Jan 2007
    Location
    Scotland - Strathclyde
    Posts
    32,188
    Feedback
    106 (99%)
    Put the key in.... turn key.
    That's what I did with my 3 year project and it's fine. The only heart in mouth part I had was waiting on the oil to start spurting from the tubby oil feed
  9. #9
    Join Date
    Dec 2010
    Location
    England - Kent
    Posts
    2,128
    Feedback
    12 (100%)
    So spent the morning prepping the car to start, once I turned the key the following happens:
    So I guess the engine is cranking? But doesn't seem to do much else
    I guess my next step is to check the spark plugs and give them a clean if needed.
    Any other thoughts on what could be causing the issue? I don't think it's the security system, I've overridden it with a fob every time I've tried to start the car thus far
  10. #10
    Terrible Club Member safcdixon's Avatar
    Join Date
    Jan 2009
    Location
    England - Durham
    Posts
    6,736
    Feedback
    15 (100%)
    Sounds like an alarm/immobiliser cutting in too me, does it have one?
    Are you getting fuel? Can you here the pump priming if so
  11. #11
    I'm addicted now! Club Member WayneW's Avatar
    Join Date
    Nov 2011
    Location
    Belgium
    Posts
    588
    Feedback
    0
    Could be the temperature sensor, maybe a bit unplugged or smth like that.
    Had the similar case on my last TT6.
    Did not start at cold, well at warm temp.
  12. #12
    I'm part of the furniture Events Organiser Al Massey's Avatar
    Join Date
    Dec 2006
    Location
    England - Yorkshire
    Posts
    12,687
    Feedback
    62 (100%)
    Does sound like it's not even trying to start.
    I'd make sure fuel was getting there.
    And there's a spark.
    Are the leads in the correct way?
    King lead connected?
    TRD widebody in need of carbon
  13. #13
    Join Date
    Dec 2010
    Location
    England - Kent
    Posts
    2,128
    Feedback
    12 (100%)
    Quote Originally Posted by safcdixon View Post
    It does have one, but I'm not 100% sure of how it works. I've contacted the last owner to see if he can shine any light on the topic. Makes sense to rule out if this is the security kicking in or an actual mechanic issue before I go any further.
    Quote Originally Posted by WayneW
    Thanks will check over that
    Forgive my ignorance but where can I find the king lead?
  14. #14
    Join Date
    Dec 2006
    Location
    England - Yorkshire
    Posts
    12,687
    Feedback
    62 (100%)
    The king lead is the centre lead in the distributer and comes across to the wing into a little box
  15. #15
    Join Date
    Nov 2001
    Location
    Posts
    31,929
    Feedback
    108 (100%)
    Pull the air filter trunking off, squirt Easy Start into the engine side of it, crank engine. Does it fire? Yes? You have a no fuel issue. No? You have a no or (very very) weak spark issue. Halves the potential issues with one squirt.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
