Krimi's Supra PTE 6766 "THE PUNISHER" (DYNO TIME!)
Krimi
 Share
Here is the Thread of my car, Bought in 2011.
Is a 1993 USA Spec with 60990 miles Manual and Targa.
MOD LIST at 06/01/2014 BPU++
Engine:
- New OEM Water Pump
- New OEM Oil Pump
- New Power Steering Pump
- TRD Oil Cap
- NGK Iridium BKR7EIX
- Gates Racing Timing Belt
- Brian Crower Adjustable Timing Pulleys
Turbocharger/Exhaust Components
- Whifbitz 3" Exhaust
- Whifbitz 2.5" Decat Pipes
- Optional 4" Straight pipe
- TTC mod
Intake/Cooling:
- K&N Intake filter
- SuperDuct Ram Air
- Whifbitz 3row Intercooler
- Whifbitz alluminium Radiator
- OEM Fan Shroud
- Whifbitz polished Upper Radiator pipe
- Whifbitz intercooler pipes
- Whifbitz oil cooler kit
- Whifbitz rad cap
- APR Cooling plate
- Whifbitz catch tank
Fuel system:
- New OEM Denso FP with 12V Mod
Engine Management/Electronics
- Blitz Dual SBC Boost Controller at 1,3 Bar
- AEM Wideband
- VDO Boost Gauge
- Greddy BCC
Drivetrain
- ACT HEAVY DUTY 6 Puck
- OEM Getrag V160 Transmission
Chassis/Handling/Brakes
- KW Variant 3 Coilovers
- Titan Front and Rear Sway Bars
Interior
- Seibon CF Door Panels
- Bride Gias Low Max
- Bride seat rails
- OEM black carpet
- TAKATA Racing Seat Bealts
Exterior/Body:
- XXR 521 18x10" & 18x8,5" w/ Michelin Pilot Sport 3 235/40/18 & 265/35/18
- RMM Front lip
- RMM Rear wing with carbon blade
- Top Secret Carbon fibre hood
- 1998 Style headlights
- 1998 Style front indicators
ACTUAL MOD LIST:
Updated mod list!
Engine/Ignition Components:
- Manley Heavy Duty Pistons 86,5mm 9.0:1
- Manley Upgraded Wrist pins
- Manley H-Tuff Rods (625+ Aged Rod bolts)
- ARP 625+ Main Studs
- ATI Damper Crank Pulley
- Titan Motorsports Oil Pump
- Titan Motorsports Main Caps
- ACL Main Bearings
- ACL Rod Bearings
- ACL Thrust Washer
- Gates-ATI Damper Aux-drive belt
- Gates racing timing belt
- PHR Modified timing gear
- PHR Tensioner Bracket
- TRD Engine Mounts
- TRD Gearbox Mount
- Toyota OEM Engine Gasket Kit
- Toyota OEM Water Pump
- Toyota OEM Power Steering Pump
- Chevy LQ9 Coilpacks
- Chevy Coil Clips & Wiring
- NGK BKR8EIX
Turbocharger/Exhaust Components:
- Precision 6766 0.96 A/R T4 Single Sroll
- Tial MV-R 44mm Wastegate
- PHR Manifold
- PHR Oil Drain Kit
- PHR Oil Feed Kit
- PHR 3" Downpipe
- PHR 4" Air Intake Kit
- PHR Screamer Pipe
- PHR Hot Side Intercooler Pipes
- RMM 3" Midpipe
- Whifbitz 3" Single Box Exhaust
Intake/Cooling:
- Whifbitz 3row FMIC
- Whifbitz Aluminium radiator
- Whifbitz Upper Radiator pipe
- OEM Fan Clutch
- OEM Fan Shroud
- RSP Turbo Blanket
- K&N idle valve filter
- APR Cooling plate
- 2.5" alluminium intercooler pipe to connect to the turbo
Fuel system:
- PHR STAGE 3 Fuel System
- PHR 17.5mm (-8AN) ID high-flow fuel rail kit
- PHR Dual Bosch Hanger
- PHR FPR Bracket
- Twin Bosch 044 fuel pumps
- Aeromotive fuel pressure regulator
- Liquid-filled fuel pressure gauge
- -6AN Stainless Steel braided feed lines
- -6AN Stainless Steel braided return line
- Hi-Flow Fuel Filters
- Injector Dynamics ID1000 Fuel Injectors
- Injector Dynamics quick release injector clips
Engine Management/Electronics:
- AEM EMS SERIES 2 Stand Alone
- AEM 5Bar MAP Sensor
- AEM IAT Sensor
- AEM Boost Control Solenoid
- AEM UEGO Wideband
- AEM Boost Gauge
- AEM EGT Sensor
Head:
- Ported and Polished
- GSC S1 Cams 269/269
- Brian Crower Adjustable Cam Gears
- Brian Crower Valvesprings Retainers
- Brian Crower STD size valves
- Ferrea Valve Seals
- Ferrea Valve Lockers
- ARP 625+ Headstuds
- Toyota OEM Headgasket
Drivetrain:
- Toyota Clutch master cylinder
- Toyota Clutch slave cylinder
- TRD Big Case Diff
- ARP Flywheel bolts
- PHR Braided Clutch line
- PHR 3.5" Driveshaft
- Royal Purple Synchromax
- AP Engineering Solid Shifter bushings
- RPS Carbon/Carbon Twin Clutch
Chassis/Handling/Brakes:
- Titan Sway Bars
- Hel Black Braided lines
- Motul RBF660 Fluid
- Performance Friction brake pads
Interior:
- OEM Seats Re-Trimmed in black leather
- OEM Black carpet
- OEM Floor carpets
- OEM Dash panels
- OEM Black leather back seats
Exterior/Body:
- RAYS VOLK TE37 "18x10,5" "18x9,5" w/ Michelin PS3 235/40/18 & FEDERAL595RS-R 285/30/18
- RMM Front lip
- RMM Wing carbon side caps
- OEM USA bonnet (Optional: Top Secret bonnet)
- Rear fenders rolled
- 1998 OEM Headlights
- 1998 OEM Front indicators
- 1998 OEM Rear tail lights
Here pictures when the Sup arrives to my Island:
http://img217.imageshack.us/img217/1120/nomatricula2.jpg
http://img208.imageshack.us/img208/9148/nomatricula1.jpg
http://img202.imageshack.us/img202/1558/img20110924113131.jpg
I disliked the Bomex front bumper and Veilside sideskirts, and the 20" rims... Then I decided to remove them from my Supra, after I placed an order with the original parts.
http://img197.imageshack.us/img197/3517/img20111019100912.jpg
http://img851.imageshack.us/img851/9827/img20111020185113.jpg
http://img847.imageshack.us/img847/7732/img20111020185155.jpg
http://img689.imageshack.us/img689/5691/img20111020185138.jpg
http://img819.imageshack.us/img819/5130/img20111022190659.jpg
Here a pic of the 2JZ
http://img687.imageshack.us/img687/1892/img20111019175451.jpg
Without the bomex front bumper and ready to cleaning the FMIC .
http://img833.imageshack.us/img833/6056/img20111105000526.jpg
The Supra after the look change:
http://img834.imageshack.us/img834/9223/nomatricula5.jpg
http://img703.imageshack.us/img703/2953/nomatricula3.jpg
http://img7.imageshack.us/img7/78/img20111215171739.jpg
http://img836.imageshack.us/img836/5633/img20111215171724.jpg
http://img861.imageshack.us/img861/4048/nomatricula4.jpg
Continue...
Edited by Krimi (see edit history)
  • Replies 435
Posted Images
Seibon Door Panels
http://img7.imageshack.us/img7/171/20120201172734.jpg
And bonus pics
http://img26.imageshack.us/img26/1277/nomatricula6.jpg
http://img853.imageshack.us/img853/7751/nomatricula7.jpg
http://img600.imageshack.us/img600/5014/nomatricula8.jpg
- - - Updated - - -
After a days I recieve two orders.
The first from MVP motorsports its content,
-RMM FRONT LIP
http://img192.imageshack.us/img192/1357/20120312195326.jpg
-TOYOTA SUPRA STOCK FLOOR MATS
http://img856.imageshack.us/img856/2520/20120113000104.jpg
-CARBON FIBRE SUPRA KEYCHAIN
http://img822.imageshack.us/img822/9594/20120112132710.jpg
The second order comes from UK, Garage Whifbitz.
-FACELIFT FRONT INDICATORS OEM 96-98
http://img190.imageshack.us/img190/4039/20120312195015.jpg
-APR CARBON COOLING PLATE
http://img715.imageshack.us/img715/176/20120312194911.jpg
-WHIFBITZ 3" SINGLE BOX SUPRA EXHAUST
http://img844.imageshack.us/img844/1255/20120312194753.jpg
-WHIFBITZ ALLUMINIUM RADIATOR SUPRA
http://img718.imageshack.us/img718/3227/20120312195038.jpg
-WHIFBITZ BILLET RADIATOR BRACKETS
http://img59.imageshack.us/img59/8518/20120312201930.jpg
-WHIFBITZ ALLUMINIUM TOP HOSE
http://img853.imageshack.us/img853/5467/20120312194954.jpg
http://img811.imageshack.us/img811/5022/20120312194614.jpg
With the new cover :D
http://img7.imageshack.us/img7/2800/pic4lzh.jpg
http://img513.imageshack.us/img513/4260/20120324225528.jpg
http://img845.imageshack.us/img845/1218/20120324225510.jpg
- - - Updated - - -
This week I fit my Whifbitz exhaust.
Without the catback
http://img32.imageshack.us/img32/9374/20120327214814.jpg
I have to cut a screw because it is hot-welded.
http://img826.imageshack.us/img826/7995/20120327225334.jpg
And here the result
http://img29.imageshack.us/img29/8484/20120327225217.jpg
http://img16.imageshack.us/img16/7585/20120327225204.jpg
http://img267.imageshack.us/img267/8466/20120327223601.jpg
Videos:
And a short pull because the exhaust its recently fitted
The previous owner (Its a piece of shit LOL) have installed white bulbs, I dislike that, then, I remove these.
White bulbs.
http://img96.imageshack.us/img96/6743/20120401183619.jpg
Removing the dash
http://img268.imageshack.us/img268/3460/20120401203850.jpg
OEM toyota Tachometers im Km/h
http://img585.imageshack.us/img585/7488/20120401202102.jpg
I dislike the green illumination, then I changed these bulbs for white LEDs.
Here you can see a test for the new LEDs.
- - - Updated - - -
The inside of the car was very deteriorated because the previous owner gave poor treatment to the leather, then I decided to restore it.
Here the deteriorated shift knob
http://img687.imageshack.us/img687/5600/20120402141608.jpg
http://img403.imageshack.us/img403/2780/20120402153148.jpg
And start to restore it!
http://img571.imageshack.us/img571/9564/20120403173323.jpg
http://img832.imageshack.us/img832/6199/20120402154232.jpg
http://img21.imageshack.us/img21/1938/20120402155024.jpg
http://img444.imageshack.us/img444/2824/20120403133000.jpg
Sanding knob
http://img26.imageshack.us/img26/9238/20120403141647.jpg
http://img16.imageshack.us/img16/591/20120403150116.jpg
http://img688.imageshack.us/img688/3703/20120403173247.jpg
And now just tint knob
http://img685.imageshack.us/img685/6784/20120403173353.jpg
The result
http://img577.imageshack.us/img577/3305/20120403170704.jpg
http://img12.imageshack.us/img12/624/20120403170802.jpg
Continue...
Refitting the power steering cooler, the previous owner don't know where those are fitted :confused: ...
http://img822.imageshack.us/img822/6811/20120404220618.jpg
Electrical installation was done for the new front indicators.
http://img688.imageshack.us/img688/7869/20120404230742.jpg
http://img696.imageshack.us/img696/4669/20120404224037.jpg
RMM Lip and Facelift front indicators fitted!
http://img19.imageshack.us/img19/2444/nomatricula13.jpg
Entire interior restored.
Before
http://img10.imageshack.us/img10/4062/20120404195723.jpg
After
http://img843.imageshack.us/img843/8721/20120404200358.jpg
Steering Wheel restored
http://img571.imageshack.us/img571/7651/20120405041643.jpg
Dash mounted
http://img822.imageshack.us/img822/7045/20120405140732.jpg
All this would not have been possible without
http://img825.imageshack.us/img825/5645/20120404235715.jpg
:yum:
Continue
RMM Lip without wings!
http://img839.imageshack.us/img839/9610/20120413203348.jpg
http://img13.imageshack.us/img13/8804/20120413203355.jpg
New look of the 2JZ
http://img838.imageshack.us/img838/7338/20120421193521.jpg
My new KW V3 Suspension!!
http://img651.imageshack.us/img651/2707/20120423200250.jpg
http://img694.imageshack.us/img694/6081/20120423200538.jpg
http://img542.imageshack.us/img542/7175/20120423202911.jpg
Brand new VDO Boost gauge.
http://img266.imageshack.us/img266/382/20120526160015u.jpg
Fitted
http://img571.imageshack.us/img571/2521/20120529224805.jpg
Bonus pics with my friends.
http://img807.imageshack.us/img807/1484/nomatricula10.jpg
http://img832.imageshack.us/img832/2154/nomatricula11.jpg
Here you can see MKII Supra, and the two only MKIV in the 7 islands.
http://img577.imageshack.us/img577/5014/nomatricula8.jpg
http://img228.imageshack.us/img228/7751/nomatricula7.jpg
http://img838.imageshack.us/img838/8328/nomatricula9.jpg
http://img268.imageshack.us/img268/4760/nomatricula12.jpg
All the Supra Fluids and changed!
-Motul 300V 10w40
-Motul M660 DOT 4
-Castrol Automatic TQ-D (Dexron II to Power Steering)
-Castrol Syntrax 75w90 (Diff)
-Castrol Transmax Z for the Getrag V160
-Oil Filter
-Fuel Filter
http://img88.imageshack.us/img88/9665/20120717172959.jpg
Under the Sup looks pretty! 0 oxides or impacts, looks new...
http://img442.imageshack.us/img442/4228/20120717181106.jpg
http://img684.imageshack.us/img684/7357/20120717181653.jpg
Getrag Full antirust and heat covered :)
Thanks to Paul Whiffin,
-Decat Pipes
-New cam cover ventilation hoses
-NGK Iridium
http://img338.imageshack.us/img338/4320/20120730234821.jpg
http://img37.imageshack.us/img37/5482/20120730234440.jpg
http://img21.imageshack.us/img21/3331/20120730234539.jpg
http://img802.imageshack.us/img802/3463/nomatricula14.jpg
http://imageshack.us/a/img580/7716/40646448683214467425585.jpg
Next days I received the wheels!
The choice are the XXR 521 in 18x8,5 and 18x10 ET25 all arround.
http://imageshack.us/a/img842/7355/20120926153745.jpg
http://imageshack.us/a/img820/7352/20120926154006.jpg
http://imageshack.us/a/img534/8260/20120926154557.jpg
Here you can see the deep of the lip!!
http://imageshack.us/a/img715/1948/20120926154608.jpg
And the tires,
-Michelin Pilot Sport 3 265/35-18
-Michelin Pilot Sport 3 235/40-18
http://imageshack.us/a/img811/4030/20120927142030.jpg
Pics of my car!
Rear
http://imageshack.us/a/img845/1065/20120928143700.jpg
http://imageshack.us/a/img607/4981/20120928143714.jpg
http://imageshack.us/a/img534/9638/20120928143735.jpg
Front wheel:
http://imageshack.us/a/img560/8584/20120928143750.jpg
I need to readjust the KW V3 with a setup for the 18", pics soon.
http://imageshack.us/a/img854/6941/20120928143913.jpg
http://imageshack.us/a/img850/7885/20120928143939.jpg
http://imageshack.us/a/img843/5851/20120928143956.jpg
http://imageshack.us/a/img855/2031/20120928194513.jpg
http://imageshack.us/a/img839/4320/nomatricula21.jpg
http://imageshack.us/a/img15/6515/nomatricula22.jpg
https://fbcdn-sphotos-h-a.akamaihd.net/hphotos-ak-frc1/v/t34/803471_10200635619723559_1808064173_n.jpg?oh=b0d3bf57c4609d4facf78f5ec91db2eb&oe=53200493&__gda__=1394616683_b51923bef21ae48ae54d3e3cbd7aa433
- - - Updated - - -
Very nice mate! :cool:
Thanks Jim ;)
At this point I started to participate in more track days to test new mods like cam pulleys, decats, blitz boost controller, new ACT clutch etc...
Here some pics:
https://scontent-a-ams.xx.fbcdn.net/hphotos-prn1/t1/540250_625729974117804_1291415334_n.jpg
https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-ash2/t1/935068_625734054117396_846864576_n.jpg
Here my friend with his 2JZ swaped Silvia, swaped in my workshop :)
https://scontent-b-ams.xx.fbcdn.net/hphotos-ash3/t1/1011514_10200852434690372_2001589510_n.jpg
https://scontent-b-ams.xx.fbcdn.net/hphotos-prn1/t1/22013_563087423749029_2007534305_n.jpg
https://scontent-b-ams.xx.fbcdn.net/hphotos-frc3/t1/15051_648863225125659_1473949789_n.jpg?lvh=1
https://fbcdn-sphotos-f-a.akamaihd.net/hphotos-ak-ash3/t1/1016791_151067848430241_1359493797_n.jpg
https://scontent-a-ams.xx.fbcdn.net/hphotos-ash3/t1/1014340_10200492648066149_677772232_n.jpg
https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-ash3/t1/1012605_10200492654426308_1804650007_n.jpg
Night meet to do some highway "cruises" hahaha
https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-prn1/t1/563348_10200583447496078_660756106_n.jpg
https://scontent-b-ams.xx.fbcdn.net/hphotos-frc1/t1/1013286_10201489087366281_1311544437_n.jpg
https://scontent-a-ams.xx.fbcdn.net/hphotos-frc3/t1.0-9/1150285_10201489084646213_2003613830_n.jpg
And why not to use a Supra to buy some hot Bread and take them fast to your home? LOL
https://scontent-b-ams.xx.fbcdn.net/hphotos-prn1/t1/1017708_10200437526968156_36977310_n.jpg
Lovely car mate, and tasteful work you've done to it.
The track you have looks like a great setting :cool:
Thanks Marcus ;)
The track is pretty nice! 4.2km course.
Very nice!
any videos of the drifting?
Only in my mobile phone and gopro vids in the computer, If I have time today I will try to upload some videos ;)
New exterior mods done! Black 1998 style Headlights, and the black painted wheels.
https://scontent-a-ams.xx.fbcdn.net/hphotos-ash3/t1/546941_10200719060086308_530706542_n.jpg
https://scontent-a-ams.xx.fbcdn.net/hphotos-ash3/l/t1/1170869_10200702168504029_1335349976_n.jpg
And few days next, I receive the Seibon Top Secret CF Bonnet (Going to paint it in black) and RMM rear wing.
https://fbcdn-sphotos-d-a.akamaihd.net/hphotos-ak-ash4/t1/1230040_10200747404474900_1427981643_n.jpg
https://scontent-a-ams.xx.fbcdn.net/hphotos-prn2/t1/1229964_10200747405354922_267339523_n.jpg
https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-prn2/t1/1239630_10200772190414533_520202604_n.jpg
https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-frc3/t1/1236128_10200789081036788_560749500_n.jpg
https://fbcdn-sphotos-h-a.akamaihd.net/hphotos-ak-prn2/t1/1382306_10200911374054037_2052453509_n.jpg
https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-frc3/t1/1384131_10200987313552477_1022512941_n.jpg
https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-prn2/t1/1452360_10201176660806040_484599482_n.jpg
https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-ash3/t1/1378615_10200879842025756_2131045443_n.jpg
https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-frc1/t1/995268_10201344164993540_211230584_n.jpg
Another exterior mod, Bride gias low max, takata racing seat belts, Nardi steering wheel...
https://fbcdn-sphotos-d-a.akamaihd.net/hphotos-ak-ash4/t1/1472027_10201330942222979_1196895639_n.jpg
https://fbcdn-sphotos-d-a.akamaihd.net/hphotos-ak-prn1/t1/1497562_10201469237360271_268499182_n.jpg
very sexual mate :eyebrows:
Car looks lovely mate :thumbs:
Could you get back to me with regards to the seats and wheel please :)
Thanks mate. ;)
Look at the post, the Brides for sale are sold, a guy comes here and collect them. The Nardi is still available if you want :)
 Share
