Page 1 of 30 1234511 ... LastLast
Results 1 to 15 of 436
Thread: Krimi's Supra PTE 6766 "THE PUNISHER" (DYNO TIME!)
  1. #1
    Canary Rocket!! Club Member Krimi's Avatar
    Join Date
    May 2011
    Location
    Spain
    Posts
    422
    Feedback
    0
    Here is the Thread of my car, Bought in 2011.
    Is a 1993 USA Spec with 60990 miles Manual and Targa.
    MOD LIST at 06/01/2014 BPU++
    Engine:
    - New OEM Water Pump
    - New OEM Oil Pump
    - New Power Steering Pump
    - TRD Oil Cap
    - NGK Iridium BKR7EIX
    - Gates Racing Timing Belt
    - Brian Crower Adjustable Timing Pulleys
    Turbocharger/Exhaust Components
    - Whifbitz 3" Exhaust
    - Whifbitz 2.5" Decat Pipes
    - Optional 4" Straight pipe
    - TTC mod
    Intake/Cooling:
    - K&N Intake filter
    - SuperDuct Ram Air
    - Whifbitz 3row Intercooler
    - Whifbitz alluminium Radiator
    - OEM Fan Shroud
    - Whifbitz polished Upper Radiator pipe
    - Whifbitz intercooler pipes
    - Whifbitz oil cooler kit
    - Whifbitz rad cap
    - APR Cooling plate
    - Whifbitz catch tank
    Fuel system:
    - New OEM Denso FP with 12V Mod
    Engine Management/Electronics
    - Blitz Dual SBC Boost Controller at 1,3 Bar
    - AEM Wideband
    - VDO Boost Gauge
    - Greddy BCC
    Drivetrain
    - ACT HEAVY DUTY 6 Puck
    - OEM Getrag V160 Transmission
    Chassis/Handling/Brakes
    - KW Variant 3 Coilovers
    - Titan Front and Rear Sway Bars
    Interior
    - Seibon CF Door Panels
    - Bride Gias Low Max
    - Bride seat rails
    - OEM black carpet
    - TAKATA Racing Seat Bealts
    Exterior/Body:
    - XXR 521 18x10" & 18x8,5" w/ Michelin Pilot Sport 3 235/40/18 & 265/35/18
    - RMM Front lip
    - RMM Rear wing with carbon blade
    - Top Secret Carbon fibre hood
    - 1998 Style headlights
    - 1998 Style front indicators
    ACTUAL MOD LIST:
    Updated mod list!
    Engine/Ignition Components:
    - Manley Heavy Duty Pistons 86,5mm 9.0:1
    - Manley Upgraded Wrist pins
    - Manley H-Tuff Rods (625+ Aged Rod bolts)
    - ARP 625+ Main Studs
    - ATI Damper Crank Pulley
    - Titan Motorsports Oil Pump
    - Titan Motorsports Main Caps
    - ACL Main Bearings
    - ACL Rod Bearings
    - ACL Thrust Washer
    - Gates-ATI Damper Aux-drive belt
    - Gates racing timing belt
    - PHR Modified timing gear
    - PHR Tensioner Bracket
    - TRD Engine Mounts
    - TRD Gearbox Mount
    - Toyota OEM Engine Gasket Kit
    - Toyota OEM Water Pump
    - Toyota OEM Power Steering Pump
    - Chevy LQ9 Coilpacks
    - Chevy Coil Clips & Wiring
    - NGK BKR8EIX
    Turbocharger/Exhaust Components:
    - Precision 6766 0.96 A/R T4 Single Sroll
    - Tial MV-R 44mm Wastegate
    - PHR Manifold
    - PHR Oil Drain Kit
    - PHR Oil Feed Kit
    - PHR 3" Downpipe
    - PHR 4" Air Intake Kit
    - PHR Screamer Pipe
    - PHR Hot Side Intercooler Pipes
    - RMM 3" Midpipe
    - Whifbitz 3" Single Box Exhaust
    Intake/Cooling:
    - Whifbitz 3row FMIC
    - Whifbitz Aluminium radiator
    - Whifbitz Upper Radiator pipe
    - OEM Fan Clutch
    - OEM Fan Shroud
    - RSP Turbo Blanket
    - K&N idle valve filter
    - APR Cooling plate
    - 2.5" alluminium intercooler pipe to connect to the turbo
    Fuel system:
    - PHR STAGE 3 Fuel System
    - PHR 17.5mm (-8AN) ID high-flow fuel rail kit
    - PHR Dual Bosch Hanger
    - PHR FPR Bracket
    - Twin Bosch 044 fuel pumps
    - Aeromotive fuel pressure regulator
    - Liquid-filled fuel pressure gauge
    - -6AN Stainless Steel braided feed lines
    - -6AN Stainless Steel braided return line
    - Hi-Flow Fuel Filters
    - Injector Dynamics ID1000 Fuel Injectors
    - Injector Dynamics quick release injector clips
    Engine Management/Electronics:
    - AEM EMS SERIES 2 Stand Alone
    - AEM 5Bar MAP Sensor
    - AEM IAT Sensor
    - AEM Boost Control Solenoid
    - AEM UEGO Wideband
    - AEM Boost Gauge
    - AEM EGT Sensor
    Head:
    - Ported and Polished
    - GSC S1 Cams 269/269
    - Brian Crower Adjustable Cam Gears
    - Brian Crower Valvesprings Retainers
    - Brian Crower STD size valves
    - Ferrea Valve Seals
    - Ferrea Valve Lockers
    - ARP 625+ Headstuds
    - Toyota OEM Headgasket
    Drivetrain:
    - Toyota Clutch master cylinder
    - Toyota Clutch slave cylinder
    - TRD Big Case Diff
    - ARP Flywheel bolts
    - PHR Braided Clutch line
    - PHR 3.5" Driveshaft
    - Royal Purple Synchromax
    - AP Engineering Solid Shifter bushings
    - RPS Carbon/Carbon Twin Clutch
    Chassis/Handling/Brakes:
    - Titan Sway Bars
    - Hel Black Braided lines
    - Motul RBF660 Fluid
    - Performance Friction brake pads
    Interior:
    - OEM Seats Re-Trimmed in black leather
    - OEM Black carpet
    - OEM Floor carpets
    - OEM Dash panels
    - OEM Black leather back seats
    Exterior/Body:
    - RAYS VOLK TE37 "18x10,5" "18x9,5" w/ Michelin PS3 235/40/18 & FEDERAL595RS-R 285/30/18
    - RMM Front lip
    - RMM Wing carbon side caps
    - OEM USA bonnet (Optional: Top Secret bonnet)
    - Rear fenders rolled
    - 1998 OEM Headlights
    - 1998 OEM Front indicators
    - 1998 OEM Rear tail lights
    Here pictures when the Sup arrives to my Island:
    I disliked the Bomex front bumper and Veilside sideskirts, and the 20" rims... Then I decided to remove them from my Supra, after I placed an order with the original parts.
    Here a pic of the 2JZ
    Without the bomex front bumper and ready to cleaning the FMIC .
    The Supra after the look change:
    Continue...
    Click to see my 93' USA SPEC 6766
    RPS Twin|PTE 6766|TiAL|Whifbitz|PHR Stuff|GSC S1|ID1000's|AEM V2|Brian Crower|KW
  2. #2
    Join Date
    May 2011
    Location
    Spain
    Posts
    422
    Feedback
    0
    Seibon Door Panels
    And bonus pics
    - - - Updated - - -
    After a days I recieve two orders.
    The first from MVP motorsports its content,
    -RMM FRONT LIP
    -TOYOTA SUPRA STOCK FLOOR MATS
    -CARBON FIBRE SUPRA KEYCHAIN
    The second order comes from UK, Garage Whifbitz.
    -FACELIFT FRONT INDICATORS OEM 96-98
    -APR CARBON COOLING PLATE
    -WHIFBITZ 3" SINGLE BOX SUPRA EXHAUST
    -WHIFBITZ ALLUMINIUM RADIATOR SUPRA
    -WHIFBITZ BILLET RADIATOR BRACKETS
    -WHIFBITZ ALLUMINIUM TOP HOSE
  3. #3
    Join Date
    May 2011
    Location
    Spain
    Posts
    422
    Feedback
    0
    With the new cover
    - - - Updated - - -
    This week I fit my Whifbitz exhaust.
    Without the catback
    I have to cut a screw because it is hot-welded.
    And here the result
    Videos:
    And a short pull because the exhaust its recently fitted
  4. #4
    Join Date
    May 2011
    Location
    Spain
    Posts
    422
    Feedback
    0
    The previous owner (Its a piece of $#@! LOL) have installed white bulbs, I dislike that, then, I remove these.
    White bulbs.
    Removing the dash
    OEM toyota Tachometers im Km/h
    I dislike the green illumination, then I changed these bulbs for white LEDs.
    Here you can see a test for the new LEDs.
    - - - Updated - - -
    The inside of the car was very deteriorated because the previous owner gave poor treatment to the leather, then I decided to restore it.
    Here the deteriorated shift knob
    And start to restore it!
    Sanding knob
    And now just tint knob
    The result
  5. #5
    Join Date
    May 2011
    Location
    Spain
    Posts
    422
    Feedback
    0
    Continue...
    Refitting the power steering cooler, the previous owner don't know where those are fitted ...
    Electrical installation was done for the new front indicators.
    RMM Lip and Facelift front indicators fitted!
    Entire interior restored.
    Before
    After
    Steering Wheel restored
    Dash mounted
    All this would not have been possible without
  6. #6
    Join Date
    May 2011
    Location
    Spain
    Posts
    422
    Feedback
    0
    Continue
    RMM Lip without wings!
    New look of the 2JZ
    My new KW V3 Suspension!!
    Brand new VDO Boost gauge.
    Fitted
    Bonus pics with my friends.
    Here you can see MKII Supra, and the two only MKIV in the 7 islands.
  7. #7
    Join Date
    May 2011
    Location
    Spain
    Posts
    422
    Feedback
    0
    All the Supra Fluids and changed!
    -Motul 300V 10w40
    -Motul M660 DOT 4
    -Castrol Automatic TQ-D (Dexron II to Power Steering)
    -Castrol Syntrax 75w90 (Diff)
    -Castrol Transmax Z for the Getrag V160
    -Oil Filter
    -Fuel Filter
    Under the Sup looks pretty! 0 oxides or impacts, looks new...
    Getrag Full antirust and heat covered
  8. #8
    Join Date
    May 2011
    Location
    Spain
    Posts
    422
    Feedback
    0
    Thanks to Paul Whiffin,
    -Decat Pipes
    -New cam cover ventilation hoses
    -NGK Iridium
    Next days I received the wheels!
    The choice are the XXR 521 in 18x8,5 and 18x10 ET25 all arround.
    Here you can see the deep of the lip!!
    And the tires,
    -Michelin Pilot Sport 3 265/35-18
    -Michelin Pilot Sport 3 235/40-18
    Pics of my car!
    Rear
    Front wheel:
    I need to readjust the KW V3 with a setup for the 18", pics soon.
  9. #9
    420 Club Member jim's Avatar
    Join Date
    Aug 2006
    Location
    Northern Ireland - County Down
    Posts
    2,776
    Feedback
    14 (100%)
    Very nice mate!
    =team-beard=
  10. #10
    Join Date
    May 2011
    Location
    Spain
    Posts
    422
    Feedback
    0
    Get it LOW!!
    Im going to the circuit for the first time with the sup, sooooo funny for me, I earned a lot of confiance with the car handling, nothing compare to my old Silvia S14 SR20 2.2L Stroker GT30.
    And my car in a local EXPO, with the stock exhaust to pass the MOT.
  11. #11
    Join Date
    May 2011
    Location
    Spain
    Posts
    422
    Feedback
    0
    - - - Updated - - -
    Quote Originally Posted by jim View Post
    Very nice mate!
    Thanks Jim
  12. #12
    Got my dream car :D Club Member Jord's Avatar
    Join Date
    Apr 2010
    Location
    England - Warwickshire
    Posts
    1,742
    Feedback
    3 (100%)
    Nice thread. Nicely done and well restored.
    White UK Spec Auto
    Club steam group - http://steamcommunity.com/groups/MKIVSupranet
  13. #13
    Join Date
    May 2011
    Location
    Spain
    Posts
    422
    Feedback
    0
    One funny pic hahaha Taken by my Girlfriend, its hard to accept from her that I love the supra more than her hahahahaha.
  14. #14
    Join Date
    May 2011
    Location
    Spain
    Posts
    422
    Feedback
    0
    At this point I started to participate in more track days to test new mods like cam pulleys, decats, blitz boost controller, new ACT clutch etc...
    Here some pics:
    Here my friend with his 2JZ swaped Silvia, swaped in my workshop
  15. #15
    Join Date
    May 2011
    Location
    Spain
    Posts
    422
    Feedback
    0
    Quote Originally Posted by Jord View Post
    Thanks Im trying to keep the good work always, and bring the best to my Supra.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
